Question about Kenmore 73952 Gas Dryer
Dryer won't start
I have quite and old Speed Queen electric dryer. When I turn the start switch, it only hummmmms. I think it might be a capacitor. If you think so, where is it located and how do I get at it to replace it? Thanks
  • 1 more comment
  • Webdawg Mar 25, 2008
    My kenmore gas dryer model #110 706 22990, when the start button is pushed, the dryer only hummmmms. Can you help me please?
  • Don Covey
    Don Covey Oct 29, 2013
    model #sdg909wf hums when pushing the start button if u turn the drum it starts rolling ?
  • Don Covey
    is there a capasitor in this commercal sq model?
  • 209 Answers
Capacitors are generally located quite close to the motor, and are easily changed, once you have gained access to the inside of the machine, that i can not help you with, it does sound like a capacitor but it could have also damaged the motor by trying to run it repeatedly, stop trying to use the appliance and change the capacitor, change with one the right size only, work with safety remove plug when working on appliances, if i have helped rate me please
Posted on Sep 26, 2007
  • Don Covey
    no visible
SOURCE:
Dryer wont heat
The only thing left to check is the voltage at the heating coil. IF it is not present then the timer or relay is bad.
Jul 22, 2013 | Speed Queen AES17AWF Electric Dryer
Speed Queen Heavy duty Dryer appears to shut down because of over heating. We have had this dryer for quite awhile and the kids are all gone now so we actually don't use it as much. It doesn't...
The cycling or operating thermostatis often the problem when a dryer runstoo hot, but there are also other things that can make it run hot also.
Here is a tip that I wrote that gives more details about why a clothes dryer will get too hot.
Clothes Dryergetting too hot
heatman101
Aug 14, 2011 | Speed Queen AES28AWF Electric Dryer
My dryer wont turn on its a couple yrs old not sure what to check
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Jun 24, 2011 | Speed Queen AES17AWF Electric Dryer
My speed queen AGS17AWF isn't getting any heat, a friend said that it could be the ignitor or fuse but I cannot find the fuse on diagrams and I don't know how to get to it based on the diagrams, any help...
Hi, If you have a gas dryer2_bing.gif.
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
Gas Dryer2_bing.gif not Working Gas Dryer2_bing.gif Not Heating
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If your dryer2_bing.gif is electric2_bing.gif..
There could be a number of different problems...
Check out this tip that I wrote about this problem...
Dryer2_bing.gif Troubleshooting2_bing.gif Electric2_bing.gif Dryer2_bing.gif won t Heat
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
Jun 05, 2010 | Speed Queen AGS17AWF Gas Dryer
Dryer does not heat. Electric ignition does not "spark" lighting
Gas Dryer2_bing.gif not Working Gas Dryer Not Heating
If your dryer is electric2_bing.gif..
Dryer Troubleshooting2_bing.gif Electric2_bing.gif Dryer won t Heat
heatman101
May 04, 2010 | Speed Queen AGS28AWF Gas Dryer
Speed Queed Dryer Motor makes humming noise when starting.
motor is no longer strong enough to turn drum,soory-mike
Jan 24, 2010 | Speed Queen AES28AWF Electric Dryer
Dryer Does not turn on when pushing the button
hello is the door making the switch if thats ok check wires see if they are loose if thats ok . at the bottom of the dryer next to the motor theres a part called a capacitor its got 2 wires coming off it. this can stop the dryer working.i hope its works
shaun
Jan 29, 2009 | Speed Queen Dryers
Dryer won't start
belts, as in 2?? you do have an old speed queen. did you make sure the blower is able to turn freely?
if so then you most likely have a bad winding in the motor. it is costly to replace and you should go out and get a new dryer. too much money to fix this old unit.
by the way the model number is under the front panel in the center, on a metal plate.
doesnt matter since you know its 25 years old and its time to update.
Jan 22, 2009 | Dryers
Kenmore 73952 Gas Dryer Logo
99 people viewed this question
Top Kenmore Dryers Experts
Marvin
Marvin
jimorris77
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
