Question about RCA RS2041 CD Shelf System
I have a RS2041 CD Shelf System that now has a loud buzzing noise coming from the speakers...
When I play a CD I get a buzzing sound. The sound starts as soon as I hit the play button (and before the CD is actually moving.) It gets louder once the CD starts playing. The sound is coming through...
Buzzing is usally AC line noise leaking into an un-shielded cable somewhere or a floating ground. If the AC plug is reversible, try that. Sometimes the buzz is from an attached device. Make sure all audio cables are plugged in tightly at each end and routed away from or at right angles to any power cords and away from other sources of strong magnetic fields like TV's. I've also seen variable track lights induce noise but it's usually minor.
Mar 19, 2011 | Teac MC-DX20B CD Shelf System
Where do i plug in the Aux cable
On the back of this system, do you see a group of RCA plug outlets? Marked IN and OUT? Phono IN? Phono OUT? Speaker IN? Speaker OUT? CD IN? CD OUT? Look for the one marked AUX IN or AUX OUT. AUX IN lets you connect a separate device, could be colored Blue, Green, White. Usually paired one over the other, RED over WHITE, YELLOW over WHITE, ect. If this system will accept an auxillary unit, player, ect, then it will have an AUX RCA type plug on the back.
Sep 26, 2009 | RCA RS2041 CD Shelf System
SOUND KEEP COMING IN AND OUT,LOUD HISS FROM SPEAKERS
theres a short in the wires either inside the box where the speakers are or the channels are blown.
Jun 07, 2009 | Panasonic SC-AK78 CD Shelf System
Owners Manual
http://www.retrevo.com/support/RCA-RS2041-manual/id/402ci677/t/2/
The above link takes you to a website where the PDF manual can be downloaded.
Hope that works!
Apr 29, 2008 | RCA RS2041 CD Shelf System
Buzzing noise
Of course it will stop buzzing when you mute the speakers. From the limited description, it could be anything from a power supply to loose wires in the system between the speaker leads and the motherboard. Best bet is to take it in to a technician and get a pro's answer. If he wants to charge more than what it's worth to you, get a new one.
Jun 19, 2007 | RCA RS2640 CD Shelf System
Rear Speaker problems
The delay is normal as it's designed to create a spacious large room sound. The buzz however, is not. It sounds like the power supply is bleeding into the amp and should be serviced.
Jun 01, 2007 | Aiwa NSX-DS55 CD Shelf System
Sound and speakers
Check the speakers connections. The speaker cables may be shorted. Turn the unit off, check and correct the connections and turn the unit on. good luck :-)
Jan 11, 2006 | Panasonic SC-AK66 CD Shelf System
Something spinning
1. Check all cable connections to make sure they're secure. 2. Replace the cable connecting the CD unit to your receiver. 3. Clean the contacts on the player and receiver with electronics-grade contact cleaner. good luck
Jan 06, 2006 | RCA RS2041 CD Shelf System
RCA RS2041 CD Shelf System Logo
35 people viewed this question
Top RCA Audio Players & Recorders Experts
Gyula Lacz
Are you a RCA Audio Player and Recorder Expert? Answer questions, earn points and help others
