Question about HP LaserJet 1020 Printer
My laser printer shows a paperjam after half of the paper has exited the printer. please help
  • HP Master
  • 1,121 Answers
1. Remove right,left & back covers, clean sensors & check flag spring My laser printer shows a paperjam after half of - b1a3ef63-09f0-401a-942c-d096aff6de2d.jpgposition as shown in fig..
Posted on Oct 12, 2013
Soulvisitor
  • 1113 Answers
SOURCE: Hp laser jet 1020 paper jam and not printing
REmove cartridge, and open rear door, might be all scrunched in very back fuser unit, if you can't remove it without damaging the rollers then it will need to be pulled to bits
Posted on Dec 27, 2007
1alexh
  • 484 Answers
SOURCE: PAPER JAME CODE 13
Try looking for the jam from the rear of the printer. Also, using one of those compressed air cans, blow all the paper dust our of your printer, because the sensors usually are photo-electronic sensors, and paper dust wil register a paper jam, even when no paper is in the printer.
Posted on Jun 19, 2009
Shah_Sheh
  • 81 Answers
SOURCE: paper logjam
There is a line of sensors along the paper path, if any of these are obscured by even the smallest scrap of paper you will get the messasge, re check the paper path again it only needs a scrap of paper, if you can spot any of the sensors give them a blow with some compressed air (paper dust build up), last but worth a try unplug for 2 minutes to allow residual power to drain and then try power up and see if the message has cleared
Posted on Sep 11, 2009
  • 44 Answers
SOURCE: Laser jet 1600 printer high pitched squeal
It proberly has dust in the printer near the spool (the picture below)
seeker5211
  • 1089 Answers
SOURCE: Laser Jet 4200 Main Motor doesn't spin
Remove tray 1 feeder assembly and check the paper flag sensor. It's probably jammed. Free it up with your finger.
Posted on Apr 29, 2010
Paper jam printer
kindly check it what shows in the display:
"paperjam 0" , its related to pick up roller related problem.
"paperjam 1", its related to cartridge unit, kindly re inserted the cartridge.
"paperjam 2", its related fuser unit, kindly open the rear cover of printer, ther you can see the fuser unit. check the one liver from fuser unit to HVPS .
kindly check all these things and contact
Jan 29, 2014 | Samsung SCX 4521F All-In-One Laser Printer
I have a Lexmark E240n printer. It keeps jamming at the same spot each time I try to print. Checked and tested the entry and exit switches. Checked good. All gears are turning smoothly. The paper jams...
does the exit switch stick up in the back of the fuser into the paper path? I've had to replace lots of the exit sensor flags because the top half was broken off while clearing a paper jam.
Apr 07, 2011 | Lexmark E240 Laser Printer
Paper Jam
You'll probably have to replace the exit sensor. Go to YouTube and watch this video: 5fJHykzkfww
You can get the part on eBay for about $10 and it's a fairly simple 15 minute fix.
May 02, 2010 | Samsung CLP 315 Laser Printer
My Samsung CLP 315w refuses to print a whole A4 page. Stops half way then message comes up paper jam but when I open back / front, paper not jammed and when I close it document continues printing then...
most likly hood is your exit sensor is faulty. The printer work in this way. if it does not print out all the document. it will print again. that is why you kept getting this same issue after a jam open and close door it will print again.
replace the exit sensor it will help.
Apr 16, 2010 | Samsung CLP-315W Laser Color Printer
CLX 2160 - paperjam
There is probably a jam in the paper feed area. Pull the paper tray out and stick your hand in to find and remove any paper stuck there. Then reinstall the paper tray and open and close the front door of the printer. The jam should be cleared.
If it is still showing paper jam, pull the tray out again and look to make sure you didn't miss any paper, then check the other areas of the printer (starting with the exit area) for paper.
Oct 24, 2009 | Samsung CLX-2160N All-In-One Printer
Paper jam, but no paper in the machine
This one is easy, its yoru exit sensor, the only sensor in the scanner "looking" up, so dust sits on it untill it thinks its paper. slide in a cotton bud or blow air in the small recess between the 2 black exit rollers visable where the paper exits from.
let me know how you get on.
Jul 15, 2009 | Panasonic KV S2026C Path-Through Scanner
Mar 20, 2009 | HP LaserJet 4200 Printer
Lexmark x215 paperjam #2
The exit sensor is defective if the paper has left the printer
completely but it appears
paperjam #2.
Once the paper has left completely, the exit actuator
must return to the original position to close photo sensor. Sometimes takes
more time than it had and it does not return.
The actuator can be deformed by the temperature.
Sep 23, 2008 | Lexmark X215 MFP All-In-One Laser Printer
Papaerjam lite stays on, no paper jam
It is possible that there may still be a small piece of paper blocking or lodged in the exit sensor area. It is also possible that when removing the jammed paper that the sensor arm became dislodged and thus creating a false jam code.
Jun 25, 2008 | Sharp AL-1641CS All-In-One Laser Printer
HP LaserJet 1020 Printer Logo
37 people viewed this question
Seeker5211
Seeker5211
