Kenmore Washer Oasis Model 110.28042700 doesnot have the autowater level option anymore and will not drain when holding the spin and drain button. Also on small loads will not spin all the water out.
4 Suggested Answers
SOURCE: Kenmore Oasis HE won't drain
I had the exact same problem last night.
Here is what I did and it fixed it with NO PARTS or SERVICE CALL.
First, I took the drain hose and Blew through it with my mouth... I got air bubbles to come up in the wash bason, this told me the drain pump and hoses were not "Clogged"..
Next I took a shop vac and a 5 gallon bucket and used the vac to **** on the drain hose to start a siphon into the bucket...worked like a champ... I had it drained in less than 3 mins....
I Took the back cover off and then the drain pump off and took the 4-5 screws out of the mounting bracket and took the pump cover off.
What i found when I did this was that there was a VERY SMALL FLAT ROCK stuck between the impellor and the pump casing.
WIth a small screw driver I flicked out the rock and the impellor was free again... HOWEVER, When you do this, the impellor will turn half way and stop... half way and stop, half way and stop...etc.........IT WILL NOT SPIN FREELY like a top. When the motor is still attached to the pump, the armiture in the motor still gives reisitance to the impellor...This I PRESUME this to be normal..
I ended up putting it ALL back together except the back cover to test it...I turned it to a wash cycle and let it run for a few mins. Then i hit stop twice to cancel that wash request. Then i started a second wash cycle and the drain pump kicked right on to drain the water left in the basin from the first test wash..... So far she's purring like a kitten..... Fingers Crossed of course...
Posted on May 18, 2008
SOURCE: 90 Series Kenmore Washer Not going to spin cycle not draining water
I've had the same problem...you can purchase a replacement lid switch at your local appliance parts store for about $35. Fortunatly, the sales person at the appliance store had diagrams and provided instructions to replace the switch. I was able to finish the job and fix the switch in less than 1 hour. Good Luck.
Posted on Jan 05, 2009
SOURCE: Kenmore 80 series washer doesn't stop filling up with water
Almost went and bought a switch until I widened by search for "kenmore washer 80 series overflow" and came up with this:
http://www.fixya.com/support/t1206464-kenmore_80_series_overflow
Turns out that a couple weeks ago, I had a really unbalanced load that probably shook off the tubing. Anyhow, saved me a trip to the supply store AND cost. Thanks to the original poster!
Posted on Jul 08, 2010
Will not spin out, just hums
Probably a capacitor problem, see Amazon.
Whirlpool & Kenmore Washer Won't Spin or Drain, Just Hums
? 6:42
https://www.youtube.com/watch?v=WMvHOtTaTZ4
Feb 26, 2014 - Uploaded by canyonman1963
Whirlpool & Kenmore Washer Won't Spin or Drain, Just Hums - Testing ..... It does not do this every time but about every 3 outof 5 times.
Kenmore Washer Diagnostic - Hums, Will Not Run After ...
? 3:34
https://www.youtube.com/watch?v=C5F-_U0_hYw
Jun 29, 2013 - Uploaded by ApplianceVideo.com
Repair your own Kenmore Washer with these following problems:Hums, Will Not Run After Filling Only at ... Find out why. Close ... Whirlpool & Kenmore Washer Won't Spin or Drain, Just Hums- Testing Capacitor, Waterpump ...
Dec 10, 2015 | Kenmore Washing Machines
My Kenmore Elite Oasis washer unbalanced signal seems to be very sensitive. Only after several tries of readjusting the load to get it really even that the washer will spin without stopping. I made sure...
If the washer throws an UL error code with out any clothes in the washer then the issue must be concerned with the mechanical alignment inside the machine or a bad CCU.
The most common problem which can cause this is some sort of mechanical hinderance which does not allow the basket to move freely.
The suspension system which holds the basket in its place might be faulty and causing the unbalancing. In this model i think there are plastic ring at the bottom of the basket . Even if they are worn out or moved out of position it may cause the UL error code you are facing
Nov 09, 2010 | Kenmore Elite Oasis 27052 Top Load Washer
Fl4 problem, kenmore elite won't spin or drain anymore.
EEPROM Error
The Central Condrol Unit (CCU) receives it's data from an EEPROMonboard the CCU.
If there is an error reading this data, it will cuse this error.
A power glitch may cause this error. Try unplugging the Unit for two minutes to see if that fixes the error.
Check CCU
So its likely you'll need a new CCU board. Check your owners manual, some models have up to a 5 yr. parts warranty on that CCU.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
May 16, 2010 | Kenmore Elite Oasis 27052 Top Load Washer
I have a Kenmore Elite Oasis HE washer model #27092600. It is making a loud noise before and during most of the spin cycle when it is trying to drain. What would cause this. I have had this machine since...
Mine was making a high pitch sound, thought a rock got under drum.... now it stopped yesterday full of water ... and won't spin or drain. What can I do here at home to fix it?
Apr 04, 2010 | Kenmore Oasis HE 27082 Top Load Washer
Kenmore Elite Oasis HE washer error code F2
The error code must be cleared first to make the machine back into operation. You have to press the PAUSE/CANCEL button twice to clear the error on the display.
The only filter the machine has is the one you removed to clean the pump. When the error is cleared, you can check the pump whether it is operating properly or not by running the diagnostic test.
Diagnostic Test Mode Procedure
  1. Close the door.
  2. Select the DRAIN/SPIN.
  3. Select NO SPIN by pressing the SPIN SELECT button.
  4. Press RINSE/HOLD or PREWASH OPTION button four times within five seconds.
  5. "C:00" will show on the display indicating that the door is locked and the diagnostic test starts.
  6. Press the button you pressed in step 4 above two times. "C:01" will show on the display and the machine starts to fill.
  7. Press PAUSE/CANCEL button two times when there's enough water inside the tub to stop the test.
  8. Observe the water level falls as the pump starts draining the water. Replace the pump if the water inside the tub does not drain. You have removed and cleaned the pump so you can easily replace it too.
Please inform me about the result of the diagnostic test and if you still need any assistance regarding this problem.
Jan 20, 2010 | Washing Machines
Kenmore Oasis Ld code
LD code is long drain one of 2 things the drain pump is frozen and need to be replaced or there is somthing in the pump. Pull the washer a way from the wall a bit and get a bunch of towels. Lean the washer back against the wall towards the middle in the back you will see the pump take it apart and find the clog.
it can be assessed through the bottom.
May 06, 2009 | Kenmore Oasis 27042 Top Load Washer
Machine doesnot agitate or drain once filled with water
it sounds like a bad lid switch if it will not drain or spin,the switch controls that-mike
Apr 24, 2009 | Washing Machines
Kenmore Elite Oasis Wash Machine Error Code F54
The F54 fault code indicates that the control board senses high motor current.
This can be caused by excessive friction in the spin basket.
With the washer off, open the lid and see if the basket spins freely.
If not, you may need to remove the basket and check for an item stuck between the spin basket and the outer washer tub.
The second and third images show procedures for removing the basket on the Oasis washer depending on whether you have an impeller or agitator in your model.
If the basket spins okay, then you can follow the technical troubleshooting described in the first image.
This may help you determine the cause of your washer problem.
Removing Tub, Basket, lint filter: http://media.fotki.com/1_p,srfssgbktsdgrrqxgtqsskgwtqkq,vi/rstsfdwbbxwwdskwfgkxrrdqddwqb/1/1303472/5961857/image5139789143943268173img-or.jpg
Removing basket & Hub: http://media.fotki.com/1_p,sqgwstkfwtfwsqwxgtqsskgwtqkq,vi/kbkbfbkgwxbfdtwrdxkrkggrdrw/1/1303472/5961857/image27197img-or.gif
Wiring Diagram: http://media.fotki.com/1_p,srfssgbdfbbkfwsxgtqsskgwtqkq,vi/rstkrrqkkxwrtdkbbrbxbqdswfffs/1/1303472/5961857/image3973684248966800668img-or.jpg
http://media.fotki.com/1_p,wktkgtrtsbsgwfrxgtqsskgwtqkq,vi/wrskkfsfrxwwqgrkddg/1/1303472/5961857/image35809img-or.jpg
Dec 01, 2008 | Kenmore Oasis 27042 Top Load Washer
Washing Machines Logo
100 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
