Question about Refrigerators
My magic chef model ctn1911gew is not working properly makes a clicking sound and is not cold at all and fan on bottom is not running. please help
    Scholar:
  • 50 Answers
Are we talking about the fan near the compressor? It is important to know if the compressor itself is running. If there is a loose connection to the compressor via the start/over load relay (normally attaches directly onto the compressor), or if the start/over load itself is bad the compressor will not run. It will click trying to turn on untill the over load gets hot Check to see if your compressor is really hot. Could be bad start/over load relay or bad compressor. Try unplugging your frig for say 30 min then, with your hand on top of a cool compressor, plug the frig back in and see if compressor smoothly vibrates for at least 5 min without becoming very hot or shutting off even though fan continues to run. The fact your fan is not running could itself be the problem. It is needed to keep the freon, and the compressor cooled.
If you need further help, reach me via phone at https://www.6ya.com/expert/steve_24d988f3507f7480
Posted on Oct 12, 2013
4 Suggested Answers
t0pc4t
  • 132 Answers
SOURCE: Magic Chef wine cooler clicking
If I was abetting man - I would suspect that the fan is polarised, and has been wired incorrectly..
Check that there is nothing obvious in the way of the fan blades..
Posted on Aug 15, 2008
  • 2920 Answers
SOURCE: Magic Chef refrigerator stop cooling
check the fan relay and the compressor to make sure it is still working...if not there is a capasiter you can replace to get it to work again
Posted on Aug 27, 2008
  • 16 Answers
SOURCE: bottom of refrigerator not getting cold enough
have you cleaned out the coils underneath the fridge? it's very simple. pull the fridge out, look underneath(try pulling off the bottom grill from the front for more access), and start cleaning. to much dust and lint will hinder the coils from cooling. A vacuum with the brush attachment or little broom works good.
Posted on Jul 27, 2009
I have a magic chef refrigerator.Model number CTL1911DEW. compressor is fine, freezer is fine. Light is off on refrigerator thermostat and its not getting cold D
There is a fan which brings cold air from the freezer side to the refrig and sounds like it is not running.
If you need further help, reach me via phone at https://www.6ya.com/expert/gary_9c859f4aa7e5ab10
Feb 25, 2018 | Magic Chef Refrigerators
Magic Chef Fridge & freezer not cold-both fans running-Compressor hot- cleaned drain tube-outside of fridg cold
Is compressor running continuously or is it clicking on and off every couple minutes? Is there any frost buildup on inside back wall of freezer?
Sep 26, 2017 | Magic Chef Refrigerators
My Magic Chef MCWC44DZ Wine Cooler does not get cold. i do not have any error messages any more due to me ordering the PTC relay and fixing the connections. I see the bottom fan working and i feel the...
You may have a Freon leak at the compressor. Running this unit at low pressure will only make it leak that much more. Have a technician check it and refill is there is a fill port available.
Feb 26, 2014 | Magic Chef MCWC44DZ Wine Cooler
My magic chef model CTN1911GEW not working properly not getting cold
Do you see ice buildup on the back of the freezer wall? Is the compressor running and getting hot?
Oct 11, 2013 | Magic Chef Refrigerators
Bottom of fridge not cold
After adjusting the settings switch or dial (usually inside fridge) you wait a couple of hours then see if bottom is colder. Most fridges (older models anyway) have an adjustment procedure. This worked for our Magic Chef purchased about 1994
Mar 03, 2013 | Kenmore Refrigerators
My Magic chef refrigerator/freezer has a problem with the refrigerator part getting warm. I tried shutting it off and letting it set for 24 hrs and that worked a couple of times, but now it just doesn't...
sounds like your refir has an interior circulation fan which is not running. If not the vent to allow cold air to recirculate is closed. Could be the freezer is icing up and defrosting it is helping somewhat.
Feb 03, 2011 | Magic Chef Refrigerators
Magic Chef MCBR445W1 seems like it dosen,t stop
Most times this is a bad cold control, but there are other things to check for. Make sure the condenser fan is working and the coils are not covered with dust. A separated heat exchanger ( small capillary tubing soldered to the large suction line ) can separate from one another and make the fridge run too long. - tape tubing back together. A poor working evaporator fan motor could also make the fridge run too long and freeze - replace the fan motor. An inefficient compressor or refrigeration system could make the fridge run too long and freeze - have a service tech check this out. A misaligned control settings, make sure the air damper and cold control have not been bumped and are out of normal settings. Stuck open air diffusers or air dampers are becoming more and more common for allowing too much air to be blown into the fresh food section and freezing things. On all frost free fridge's the freezer temp air is blown into the fresh food section, if you have "easy" to freeze items ( eggs, veggies in water, etc ) in front of or under where the freezer temp air comes out, they could freeze - store them in a different spot. Doors not closing properly making the fridge run too long is something else to check for.
Check on the cold control if faulty, replace the cold control, not having found any other problem, do check on plastic air deflector at the top rear of the frig had been knocked off. replaced it if faulty. As you know, the deflector directs the freezer air toward the front of the frig and the rear of the cold control, which is now functioning properly.
Good luck.......
Aug 01, 2010 | Magic Chef MCBR440 Compact Refrigerator
I have a Magic Chef refrigerator. Model# CTN1511GEW Serial# 10381240ZB, It wont stay running. The freezer is staying cold but the bottom part is not. Been about 3 days not working properly. I can turn it...
your rtc overload contactor on the units compressor body is making that snap noise,you need a new overload,remove the spring wire that holds it to the compressor,unplug the rtc overload and capacitor and get a new one and reverse procedure to in stall
Jan 16, 2010 | Refrigerators
Aug 27, 2008 | Magic Chef Refrigerators
Magic Chef MCWC30MCG not getting cold?
You need to replace the Ptc unit attached to the compressor. Go to REPAIR CLINIC.COM and order the following part. 1206838 Ptc relay. They also will show you were it is located and how to replace it. Compressor tanks very rarely go bad. It is an $11.00 dollar part
May 28, 2008 | Magic Chef MCWC30MCG Compact Wine Cooler
Refrigerators Logo
89 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
