Question about Electronics - Others
Ucomfy foot massager
When plugged in and turned on all lights flash and unit does not function.
Feet for Acuvibe 5004 foot massager
Take one of the rubber feet to the hardware store and see if they can sell you replacements.
Oct 10, 2016 | Sewing Machines
MCS-490H
Is it possible that there are differences in power sources between where you originally used your massager and India? The massager may have lasted just long enough in the new environment to fail.
Dec 10, 2013 | Homedics Shiatsu Massager
Reclining is hard and the foot massager is not functioning, don't have the owners manual.
Sounds like the cable to foot massager is trapped in the levers. Turn it on its side and check. Unplug it first.
Sep 26, 2013 | Sunpentown Takasima A-619b 5-in-1 Air...
THE MODEL IS EP578.ROLLERS DONT MOVE BUT MOTOR IS FUNCTIONING.LIGHTS IN THE REMOTE ARE BLINKING ALL TOGETHER THEN THE MACHINE STOPS.
I found with my Panasonic EP578 that, if the lower photo sensor limit switch gets too dusty, the massage mechanism will travel downwards past the normal range of motion and the electronics will time out because the unit did not get a down limit sensor signal & reverse direction and proceed back to the upper limit switch in time. With the device unplugged, I simply removed the grommet screws and opened the fabric backing. Then I removed the units cover and Then blew out dusty photo sensors with compressed air. Then I swapped the red and green, 2-pin mag clutch coil connector plugs so that when I switched the unit on again I could make the unit travel back up to about, the scapular position. The reason that this is possible is that when you first start a normally working machine, the first thing that happens after the motor turns on, is that the motor clutch for the mechanism that provides the neck and vertebral massage balls, also energizes. I figured that I could get the voltage at that connector to energize the rolling clutch to get the unit back up again (as you can't move it by hand). Then I turned the unit off (while stile in cycle) and the swapped the mag-clutch coil connectors back to their original position. Re-starting the machine causes the moving massage mechanism to go through it's Power On Routine which realigns everything to it's 'Home' position and ready to run a fully functioning cycle. Remember to unplug the machine when working on it and keep all fingers, necktie, hair, jewelry from moving mechanism when it's moving to avoid damage to the machine and bodily harm to yourself!
P S here's a link to a service manual .pdf download for the Panasonic EP578:
https://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=1&cad=rja&uact=8&ved=0ahUKEwj_zpzD_NvQAhVpqFQKHb6EBbgQFggeMAA&url=http%3A%2F%2Fblog.lincomatic.com%2Fwp-content%2Fuploads%2F2013%2F01%2FEP578.pdf&usg=AFQjCNESCMv3PGtxbXCJfn-RHnEBwiQoIQ&sig2=2t3ZqNxLVT8Y4RJ6nKolmA
Mar 21, 2011 | Panasonic Shiatsu Massage Lounger with...
I have a dazey foot saver i need to know how to use it please can u help me
Fill with water to Fill Line. Add any salts or foot-soaking solution desired (a handful of Epsom salts, or 1 Tbsp bleach, per gallon, or a retail product, for example), or leave plain. Place on a towel, plug in, Turn to desired type of soak/massage/aeration/heat and enjoy. After about 10 or 15 minutes, dry feet on towel (you'll probably want to rinse or wash them when you're done with the Foot Saver). Unplug the Foot Saver and dispose of the water in the unit. Rinse it out (if any residue remains, wipe with a wet paper towel), and turn upside-down on a waterproof surface to air dry, or towel dry, and store.
Nov 09, 2010 | Health & Beauty
I wan to use in office work
Place it in a bag. Take it to work. Plug it in. Enjoy.
Jun 30, 2010 | Homedics FOOT MASSAGER ULTRA DEEP KNEADING...
My car shakes bad when it rains
When it's running bad does the "check engine light" flash? A flashing check engine light indicates a missfire, which sounds like what's happening. I would look for moisture entry at the ignition coils. You could try misting water on the ignition components with it dark and look or listen for arching. It could be arching in the spark plug tubes so not seeing the arch doesn't necessarily mean it's not happening.
May 11, 2010 | 2004 Chevrolet Cavalier
The power led light keeps flashing
Hi.
Give it a good 'knock' on the back (hard surface). You might hear a clink sound. I think it's when a cog gets out of line. My chair is fine now. You'll notice that the rollers start moving back to the off setting. So if it goes off and they are in the middle or top then it's stuck and needs a thwack!
Dec 01, 2008 | Homedics SBM 300H Therapist Select Shiatsu...
Electronics - Others Logo
74 people viewed this question
Top Electronics - Others Experts
Are you an Electronics - Other Expert? Answer questions, earn points and help others
