Question about M-Audio Audio Players & Recorders
Loud rattling noise
They arent blown because i do not see any tear/hole
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 81 Answers
Hey shawn, try lowering the volumne level & see how the speakers react.
www.tiger direct.com has new computer speakers,all different prices & different quality levels. from the best to the cheapest computer speakers.
they carry all computer parts. 2 tb hard drives, $89.00
for usb2 & usb 3 ports.
Posted on Oct 13, 2013
Why is my whirlpool deut washer tearing clothes
Check the little holes around the drum, I have seen pins and needles get stuck in these and cause lots of damage. I would replace the seal.
Apr 10, 2013 | Washing Machines
How do you fix the bob when it has a tear in its neck. the head is starting to come off.
I had the same problem, started with inch long tear in his adams apple ,eventually more than half his head was fallin off. I took a nice sharp knife and pirced a hole an inch above and below the tear every 4 or so inches and stuck zip ties through em. Feed the end of the tie through the top hole going inward. Do all the top holes like that. Once your done with the top feed the now inside ends of the ties outside through the bottom holes. Do this all the way across, THEN feed the ends through the locks and zip em tight. i then put a scarf on his neck to hide the tie ends, or i suppose you could tape em down. I dont think striking the ties will do any damage to your hands it just looks tacky. Make sure your holes are atleast an inch away from the edge of the tear so the ties dont rip through the "skin" inbetween them.
Jun 19, 2012 | Century "Bob" Body Opponent Bag
2000 saturn sl2 stalled and wont start , it just ticks battery is fully charged belt wont move at all it seems that the engine has locked due to oil leak. what can i do
try turning the engine with a bar on the crankshaft ot with a screwdriver on the ring gear, and remove the spark plugs, if water comes out of the plug holes then you probably have a blown head or gasket, if you still can't turn the engine over tear down is the next step
Feb 04, 2011 | 2000 Saturn SL
Besides a blown head gasket what else can cause water in the oil?
Cracked Heads, Cracked Block, missing chain guide for the timing belt lets it wear a hole in the cover which lets water mix in the oil. You are looking at tearing that engine down to find the problem.
Jul 07, 2010 | 1999 GMC Safari
Leaking water under front edge of machine?
Open the door and gently pull on the grey rubber gasket and check all around it for holes / tears. There are three tiny holes in the 'wall' at the bottom that are supposed to be there, but you should not see any other tears. I just found a large tear on mine that causes leaks when I run very large loads. I am going to try to fix it with Gorilla Tape, otherwise I will probably have to buy the whole new gasket. It seems like it would be a real pain to replace!
Apr 30, 2010 | LG WM-2277HW Front Load Washer
Printer is new and prints almost no black.
Try increasing the black level in the settings. Otherwise being that it is new. I would just return it for a new one so that way you arent running into problems past the warranty period.
Thank you,
Lee
Jun 23, 2009 | Samsung CLP-350N Laser Printer
Holes in clothes
Inspect the rubber seal, and steel drum to make sure there is no foreign object sticking out, which could be tearing holes in your clothes. Also check to see if any of the holes in the steel drum are dented in. or out or misshaped, as this could cause the tumbling action of the drum to tear clothes.
Mar 13, 2009 | Kenmore HE2 Plus Front Load Washer
Holes in clothes
Be carefull not to overload and inspect around door and heat entrance area for catch points or sharp areas.
Its usually Washers that tear clothes inspect closly to determin cut or tear. if tear try smaller loads with only similar materials
Dec 31, 2008 | GE DCSR483EA Electric Dryer
What kinda glue do you use on a blown speaker?
A blown speaker needs the windings replaced and re-coned. If you have deteriorating foam\cardboard type edges you an use clear silicone caulk from any home improvement store to fix small tears or detererioration. Tears and such on a large scale will require re-building.
Oct 03, 2008 | Audio Players & Recorders
56 people viewed this question
Top M-Audio Audio Players & Recorders Experts
Michial Gueffroy
 Grubhead
Grubhead
jason
Are you a M-Audio Audio Player and Recorder Expert? Answer questions, earn points and help others
