Question about Garmin eTrex Summit GPS Receiver
Garmin eTrex Summit Screen
I have blank lines in my screen. I think it needs to be replaced. Can I do this myself or do I have to send it to Garmin?
Here's what worked for me (YMMV): Take the unit apart according to the link above (save the two tapes - they can be reused). The edge of the glass display is covered with what looks like black electrical tape - what I think happens is the tape comes loose and pulls the connections apart. To fix the problem, just push down on the tape to restick it - should work for a while. Whatever you do, don't pull the tape off - it will ruin the unit. When you reassemble it, put the ribbon cable in first, then the screws - and be careful you don't cross-thread the screws - if you do, you're screwed (pun intended). Garmin should recall all the eTrex units and replace this obviously flawed display. Hope this helps
Posted on Oct 03, 2007
See discussion at Its possible that there's a bad connection at the ribbon cable, but most likely its a bad connection at the edge of the LCD glass panel. I've had two eTrex fail because of this problem. Don't pay the riduculous price Garmin asks for repair - just buy a new Magellan unit. If you must get a Garmin, go with the high-sensitivity receiver.
Posted on Oct 02, 2007
Can the garmin etrex summit download topo gps maps
The Garmin Etrex Summit does not have the ability to add maps to it.
Sep 13, 2011 | Garmin eTrex Summit GPS Receiver
My Garmin Etrex Summit records tracklogs and shows them on the screen but when I upload them to my PC all tracks show as 0 miles, 0 altitude etc
2 possible reasons.
Either memory is full.
Try remove all data from history, and have a small run.
It should be OK then on PC upload.
If not OK, only hard reset can cleanup device, and return to factory settings.
Consult your manual for hard reset instructions.
Oct 04, 2010 | Garmin eTrex Summit GPS Receiver
My garmin etrex legend screen goes blank with a vertical line on the screen after about 5 minutes od operation
Unfortunately the only fix for this is to send it back to Garmin for repair. This one can go one of two ways. Either the screen is faulty in which case it's a quick fix and you go away happy, or it's a software fault.. In which case I'd ask for a new one because in my experience most software faults with Garmin devices become recurring problems even though they clear and reprogramme them invariably we see them coming back with more software issues..
Oct 06, 2009 | Garmin eTrex GPS Receiver
My Garmin Etrex Legend starts up and finds the satellites, but then screen goes blank except for vertical line on the screen.Stays that way until batteries wear out. Fixable?
I have the same Garmin product. It had a problem displaying anything. I went to the Garmin web site and got tech support. They fixed the problem by telling me what to do. Try them befor you throw it away. But it sounds un-repairable
Aug 11, 2009 | Garmin Etrex Legend Handheld Gps
My Garmin eTrex Summit HC will not turn on. I
absolutely! Hve yoiu checked that this model does not have a switch on the rear as well as on the front? the one of the front is standby. The other one is main power. Not 100% sure about your model so just check first. Other than that take it back to seller for replacement or instructions
Jun 28, 2009 | Garmin eTrex Summit HC GPS Receiver
Blank screen with a black line down the middle.
Due to a new satellite launched this year, the WAAS is affected. Disable the WAAS, go to Garmin and download the latest software version FOR THIS UNIT. Install, enable WAAS and you should be good to go.
Nov 23, 2008 | Garmin eTrex Legend GPS Receiver
Blank Screen on Garmin E-Trex Vista
The problem is that your software version needs updating. A recently added satellite creates a glitch in the older software. Go to the Garmin website, load WebUpdater if you haven't already done so, and the updated version (3.8) will automatically install to your Garmin unit. I had the same symptoms, they have now disappeared and my Etrex Vista is back to normal.
Oct 14, 2008 | Garmin GPSMAP 76CS GPS Receiver
Garmin Etrex display problem
Have you updated your Garmin unit software recently?
Mar 21, 2008 | Garmin eTrex GPS Receiver
Screen Blanks
I had the same problem with an etrex Vista. I spoke with Garmin, they said that a recently launched WAAS satellite is interferring with some models (he mentioned it is the models with a black and white screen). Garmin tech support said that they're working on a software patch but for the meantime switch WAAS off.
Call Garmin tech support with any questions or to find out about the software patch, 1-800-800-1020
Nov 04, 2007 | Garmin eTrex Vista Cx GPS Receiver
Garmin eTrex Summit GPS Receiver Logo
353 people viewed this question
Top Garmin GPS Experts
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
