Our LG 26LC55 TV has just stopped working.
Our LG26LC55 TV has just stopped working completely. The red 'standby' light is there (indicating some power is available) but as soon as you use the remote or TV controls to turn the TV on, the red light disappears and absolutely nothing happens, no sound or vision. Does anyone have any ideas as to the problem. We bought it 13 months ago an unsurprisingly both the retailer and manufacturer are not helping hiding behind the 12mth manufacturers warranty.
Thanks
  • Anonymous May 11, 2010
    Hi, I now have the exact problem withe same TV. Do I need anything else except for the capacitor? Any help please?
I have just fixed my own LG 26lc55 flatscreen.. with the problem of the red light is on and when i turned on the tv, nothing happened not even back to the redlight..
Solution-- take off the back panel, in the middle there is a brown " plate " with a lot of electronics, one of the black capacitor is burned out. if you look closely at the top you will see one of them is broken " the + on top is open " in my case " maybe all ", it was a 3300 uf, 105 degree, 10 volt capacitor, i took it of bought a newe one at a electronic store " 3 $ " and put it in. took 10 minutes and my tv is now working.. BY THE WAY, i could not find the exact capacitor, so i bought a 3300uf, 105 degree, but 16 volt. and it works like a charm.. REALLY HOPES THIS WILL HELP YOU..!!
Posted on Oct 28, 2009
  • hectorhurley
    hectorhurley Dec 29, 2012
    I can't thank you enough larshassing, I did exactly what you said I had to replace 2 capacitors on my LG tv cost me about 4 euros to repair, I was ready to throw my tv away and buy a new 1 so you saved me at least 250 euros Once again many thanks
LG PLASMA TV
U have no audio and no video which tells you that it has to be something that both systems have in common - the power supply.
Locate the PS board and check for blown fuse, burnt resistors, bad or bulging caps.
Jul 24, 2015 | LG Televison & Video
No Picture, but sound for a minute, then shuts off
I think your Display card not proper work so please contact LG Technician.
Thanks.
Feb 17, 2014 | LG RU-44SZ61D 44" TV
Lg light blinks red
How many times this standby/power light blinks at one time switch ON? Count it carefully. These blinks are fault indication, and known as blinking codes. From the number of blinks occur at one time switch ON; you can get an idea about the faulty circuit stage inside the TV. This will make repair easy. For more information, check the link http://electronicshelponline.blogspot.com/. If the blinks continues, and non-stop, the fault should be with its main system control IC, and with the memory IC.
Dec 21, 2013 | LG Televison & Video
Red blinking light
Hi, Ephraim. The flashing red light indicates that the device is showing "low battery". It could be that the LG phone charger fits the charging port on your bluetooth headset but it is not compatible with your device. In order for you to know that it is charging, the device should show a steady red light(means charging).
Please take a look at the table reference below.
•With the Charger Plugged In
______________________________________________________________________
•Headset Indicator Headset Status
Red-----------------------------------------------Charging (battery level less than 50% charge)
Yellow-------------------------------------------Charging (battery level more than 50% charge)
Green--------------------------------------------Charging complete
With No Charger Plugged In
Off ---------------------------------------------Power off
Three blue flashes------------------------Powering on/off
Steady blue --------------------------------Pairing/connect mode
Rapid blue/purple flashes -------------Connection successful
Quick blue flash --------------------------Incoming/outgoing call
Slow blue pulse --------------------------Connected (on a call)
Slow blue flash ---------------------------Standby (not on a call)
Slow red flash ----------------------------Idle (not connected to phone)
Slow purple pulse -----------------------Connected call muted
Steady red ---------------------------------Attempting to connect
Quick red flash ----------------------------Low battery
Note: After 20 minutes on a call or of inactivity, the light stops flashing to conserve power, but the headset remains on
Hope that'll help you in some way.
**Please rate my post and/or leave a comment** ...Thanks...
Sep 25, 2013 | Motorola Mobility H560 Bluetooth Headset
What is the code for LG 37LE4500 TO WORK WITH SKY REMOTE CONTROL
I also have an LG TV. I used this 4 digit code: 0742.
TO PROGRAM THE remote USING THE 4 DIGIT CODE:
1. Turn your TV on.
2. Press tv on your Sky remote control.
3. Hold down select and the red button together for about two seconds, until the red light on the Sky remote control blinks twice.
4. Press tv on your Sky remote control again.
5. Key in the four digit code for your brand of TV. The light on the Sky remote control blinks twice. If the light blinks once only, recheck the code for your brand of TV and start again at Step 1.
6. Press the standby button on your Sky remote control. If your TV switches off, press select. The light on the Sky remote control blinks twice (code stored). If your TV does not switch off, press tv, then press the standby button. Repeat this (press tv, then standby) until your TV turns off, then press select (stores code).
Mar 12, 2011 | LG Televison & Video
I want to find the Sky remote code for this Tv.
Just got an LG 42LH2000 and code 0206 works
May 16, 2009 | LG Televison & Video
Tv went off while watching a program power standby red light blinks 6 times then pauses then repeats tried unplugging unit waiting a few minutes then replugged same results nothing. can anyone help me ?...
Here's an excerpt from the Sony Manual online. And the link - http://esupport.sony.com/US/perl/webtree.pl?template=EN&mdl=KDF55XS955&content_id=68&category_id=11&problem_id=52
The POWER/STANDBY (red) indicator flashes three times
If your power/standby indicator is flashing in a pattern of three flashes, this may indicates that the lamp cover is not attached securely. Follow the directions in the Operating Manual under changing your lamp that related to closing and securing the Lamp Cover. Ensure that the Lamp Cover Door is securely fastened by tightening each screw.
The POWER/STANDBY (red) indicator flashes continously
If your power/standby indicator is flashing continuously, and the lamp cover has been secured, your TV may be in need of service.
The POWER/STANDBY indicator is lit up green (not flashing)
A sustained green light indicates your TV is on.
The POWER/STANDBY indicator is lit up red (not flashing)
A sustained red light from your power/standby indicator simply indicates that your TV is in standby mode. This shows you that your TV is ready to be turned on with the remote.
Is it the power light and not the lamp light? If the lamp light is flashing then replace the lamp.
Apr 07, 2009 | Sony Grand WEGA KDF-55XS955 55" Rear...
LG DLP RU-44SZ51D Lamp Indicator blinks red
44 inch lg dlp hdtv no picture or sound press power button standby light turns yellow and then back to red
Mar 04, 2009 | LG RU-44SZ51D 44" Rear Projection...
LG 42in LCD Television - turning unit off
The amount of standyby power consumtion is minimal. The only way to turn it off completly is to disconnect the power from the TV. This will however increase your start up time when you want to use the TV.
Nov 28, 2007 | LG 42LC2D 42 in. LCD HDTV
Televison & Video Logo
992 people viewed this question
Top Televison & Video Experts
Electro Med Services...
