My SA-EX 400 was working fine. Then, all of a sudden (after powering the system down for a few weeks) I get no sound through the speakers. It did give me the over load, or over heated message, but after blowing the dust out, it says that it's working properly. But I get no sound through the speakers, only the headphones.
    Sergeant:
  • 310 Answers
Check the back to see if it has a switch for disconnecting the preamp outputs from feeding the amps. These can also be jumpers (2) from Pre Out to Main In. You may have accidentally removed the jumpers or moved the switch. This allows you to use it as only an amp or only as a preamp to drive a more powerful amp.
Posted on Oct 15, 2013
4 Suggested Answers
SOURCE: No output on main speakers
I have experienced a similar problem with my Sony STR-GX57ES and took it to a certified tech only to find it needed the power supply replaced. I opted to hunt down a compatible power supply but have been unsucessful thus far. That being said I picked up an STR-D665 for next to nothing and found the power supplies to be quite different (you would hope so any, with the ES meaning Elivated Standard and all) but with the D665 working flawlessly I'd rather have something working than nothing. Good luck!
Posted on Aug 17, 2007
SOURCE: Durabrand Surround Sound SA-SP9 some speakers not working
on the remote, press the "channels" button
Posted on May 16, 2008
seabelow
  • 95 Answers
SOURCE: Overload on Technics SA-AX710 Receiver
Turn it off...remove all the speakers and turn it on....If it goes into the protect mode. you have a bad power amp. That's the big black flat things attached to the cooling fins.. one or both is shutting the system down. If it doesn't trip out, plug a head set into the phono jack and see if you can hear the music there. Can you turn it up without tripping.... if it's still ok...hang one speaker on the system, if it trips thats the bad leg...check the speaker/wire
Posted on Oct 23, 2009
1960 (approx.) b & w floor model TV sound suddenly doesn't work.
check av card
check speaker
check any dry soldering in power supply & audio section
Mar 25, 2014 | Zenith Televison & Video
I have a djm 400 and it has started producing a buzzing sound through the speakers. I can take the same speaker cables from the djm 400 and hook them up to my backup mixer and the buzzing goes away. What...
Since it works with your other mixer, the DJM400 is probably fine. You have a ground loop.
Make sure ALL, and I do mean ALL... (re-read that if there is any confusion) interconnected equipment WILL BE powered from the same receptacle or source. If speakers or amps are powered from one place and the DJM is from the other end of the room you likely have a ground loop and you can ex[ect buzzing. Run extension cords alongside the audio leads if necessaryy to carry power from where the amps or speakers are plugged in back to the DJM400 and ANY pther connected equipment.
Jan 07, 2011 | Pioneer DJm 400 Professional DJ Mixer
My Technics AV Control Receiver SA AX530 is in overload
An amplifier should never be turn on without speakers, it will overload internally.
make sure speakers work and try again.
Dec 04, 2009 | Technics SA-AX530 Receiver
Power, but no sound
take an ohm meter and remove wires from speaker...put meter in the ohms position...you will put a lead on each of the terminals of the speaker...you should have a reading of 2, 4, 8 ohms....you may also try to use the continuity test, same, but there will be a beep ....this basically ensures that the coil running through the speaker is still good, as one piece, otherwise it will get no good reading and this is usually from blowing the speaker or sudden high bass sounds....
Aug 09, 2009 | Sony SA-WM500 Subwoofer
46" Samsung LCD, no sound output whatsoever
First try hooking up a different source such as a DVD player or Cable box and see if you have audio. If you do then check the audio output from the computer. If you do not have audio then make sure the tv audio is up half way and turn off the set. When you do this you should hear the down chime provided you have the chime turned "on". If you do not hear the down or up chime then the sudio circuits on the Main bd are bad and the Main bd will have to be replaced. A quick way to check to see if the audio circuits are working is to listen for the up or down chime when turning on of off the set coming from the tv speakers speakers.
Jul 14, 2009 | Samsung HPT5054 50 in. HD-Ready Plasma...
SA-2 and SA-3 doesnt work together
its alwaays better just to call bose their great when it comes to this
May 20, 2009 | Bose Lifestyle 18 System
95 Ford stereo speakers stopped working
i'm guessing that is premium sound... check the relay for the amplifier.. or bass booster ... can't remember what it was called on my windstar of that year but when i blew the fuse i had no sound
Mar 23, 2009 | 1995 Ford Club Chateau
Problem w/ Panasonic SA-HT700 speakers
Try looking in the audio settings,it might be configured for stereo/mono or any number of surround sound settings e.g; 5:1, 7:1 In which case it might shut off the power to the circuit board inwhich the speakers are connected.If that fails .......Take it back!! Either the connection inside the speakers is faulty or the connections in the unit are faulty.
Oct 25, 2008 | Panasonic Home Theater System System
Computer stopped recognizing the speakers
Check the sound card system Can your hear through headphones for example?
Nov 15, 2006 | Logitech X-230 Computer Speakers
 Grubhead
Grubhead
