Question about Video Game Consoles & Games
Bush lcd tv
When I switch the tv on, I only get a blank screen (no sound) It will not let me change input source either by remote or manually. Occasionally if power left on for a while and then TV switched off & on, it will work but getting more infrequent. Repairable or scrap ?
    New Friend:
  • 126 Answers
Scrap
Posted on Oct 17, 2013
SOURCE: PS3 won't connect to TV with component video.
You need to connect the PS3 to the television with both connectors (HDMI and Component). Then in the display settings change it from HDMI to component and during the 30 seconds that the screen goes black you need to disconnect your HDMI cable from your playstation. Then switch to the input that the component cable is connected to on your television (ie. AV1, AV2, etc). From here you will see the countdown for the test and you can continue with these settings.
Posted on Feb 01, 2009
  • 23 Answers
SOURCE: when I switch my ps3 on all I get is a blank screen
PS3 is one of the most amazing gaming device but like other competitor gaming devices (Xbox and Wii) It also has some problems like No Display Problme. You may check out the informative blog post at PS3 Repairs blog
Hope it helps to fix the problem................
Posted on Apr 09, 2009
  • 10 Answers
SOURCE: initial set up of PS3. initial set up screen not displayed
When tv and ps3 backswitch turned on hold down the front power button when off until the ps3 has done a double beep after the intitial beep and wait for a max of 1 min and initial set up screen should appear
Posted on Apr 20, 2009
  • 7 Answers
SOURCE: Blank Screen
well, the t.v could possibly be broken, call a repair man and describe your problem and maybe they can help, but do not attempt to fix the t.v yourself as a component inside can cause fatalities.
Posted on May 29, 2009
dropndeal
  • 134 Answers
SOURCE: how do i get my nintendo nes to work through a
Use the RCA AVI outlets on the side of the NES and not the RFI (cable) outlet on the rear of the unit. Tune your TV to the appropriate Video Input channel.
If still no signal, try another set of AVI cables.
Try the console on another television.
If no output from the NES, then it will require refurbishment. Click here for more information.
Please let me know how I may assist further.
Posted on May 07, 2010
Why is there a beautiful picture but no sound and cannot change input?
Re the sound, make sure that the mute switch is not on.
Re the input, did you try changing input at BOTH the tv and remote controls. Could be the remote source button is not working.
Sep 07, 2015 | Haier HL37B 37-Inch 720p LCD HDTV
Bush 24 inch tv/dvd combi screen went blank as if it's on standby. won't respond to remote control. one week old. is it seroius?
try switching on tv point remote at the tv pressing the menu/exit button and holding for 10/20 seconds hope this works for you
Oct 07, 2012 | Bush Industries IDLCD26TV16HD LCD TV
Sharp tv keeps changing the source channel on its own
you may fave a faulty switch in the key controller, may best advice is replace it
Part numbers:
KC792
XC792WJ
Fred
Jun 18, 2012 | Sharp Aquos LC-32G4U 32 in. HD-Ready LCD...
My lcd tv has no sound or picture it has a grey screen
You should try to use the Component cables. The red/green/blue cables as this will give you a better picture. Make sure your DVD player and TV will support those cable. However, the cable your using now will work. Your TV might be on the wrong input. Look for a button on the TV that says INPUT or SOURCE to change the input. It might be only on the remote control and not on the TV itself.
May 02, 2009 | Spectroniq Protron PLTV-32 32 in. Plasma...
How to change input without a remote or manual.
get connected to
www.pronto.com is for a manual
and replacement remote bush remote
Mar 18, 2009 | Bush 2871NTX 28" TV
Soyo 32" tv -- says "no sync"?
change your source input to the correct video source you are using
Feb 23, 2009 | Soyo DYLT032D 32 in. LCD Television
Blue screen, no video, but has sound
Did you hit the "input" or "video source" button by mistake on the remote or TV? That would change the input from the one the cable/video source uses. You're getting sound, so it's working......sounds as if the input was maybe changed. I'd hit the input/video source button a few times to go through all the available inputs and see if you get video back.
Dec 08, 2008 | Sharp LC-32SH20U 32 in. LCD HDTV
Screen changes between color as a demo function.no signal
Gateway was sued Class action over LCD's and Plasmas they sold over a 2 year period. They resell 3rd party TV's that were very faulty, an immature design.
Here's what I learned about mine, which makes it limp through as a Computer monitor (both DVI and VCA) and halfway functional TV.
You have to connect a DVI source, on the Main Menu for the DVI input there is an option called "Factory Mode". scroll down to it with the CH buttons and select it with the vol button. The scroll to "initialize eprom", select and confirm it. After the "Waitting" words disappear, make sure you have a TV source connected, Then turn the TV off and on, using the hard switch in the back. The TV input should be defaulted to channel 10 or 11 now But you select a TV channel that has no TV signal on it (like channel 1 for example) , the whole TV input side will refuse to let you select it again, and you'll have a blank screen and have to start over.
That takes care of the blank screen thing Now the other problem is parental control is defaulting to "ON" or something, and you can't program channels. With the TV input Main Menu engaged, select "Setup Menu." If you have this problem, then you'll only see 2 options, all the TV input and channel programming options will be missing. You have to select Parental Control, and when it prompts you for a password hit the volume > button 4 times (or just wait for a minute.) This should bring back your TV System and auto prgram/manual search options.
Unfortunately, my TV doesn;t remember these setting very well if I select cable, it does better if I select "AIr". But at least it funtions - kind of. If you switch to your computer input, you probably will have to switch the monitor off and on from the back panel again. Mine always starts up with the menu onscreen. All this might bve less trouble if you have a the remote, I don;t know where mine went after the last move.
Good luck, and hope this helps.
Billy K.
Sep 24, 2008 | Gateway LCD26TV 26 in. Television
Mintex 37 inch wide screen. remote is working however cannot change channel, input source or volum. only turns tv off. The buttone on tv doesnot work connot change input source or volume
Check if the remote is in TV position, that is, because most of the remote controllers have the feature that you can program them for use with another devices. Make shure that one button that says "TV" in pressed and released once before you try to change any function on the TV.
Jun 27, 2008 | Mintek DTV-373-D 37 in. LCD HDTV
Video Game Consoles & Games Logo
Top Video Game Consoles & Games Experts
James Wishart
Are you a Video Game Console and Game Expert? Answer questions, earn points and help others
