Question about Refrigerators
Why does my jvc house amp gets so hot ,I can't even touch the top ,it actualy burns me, is this normal?
    Scholar:
  • 50 Answers
Yugen,
All amps get hot. It is their nature. However, IF you have clearance around it of at least two inches so it can dissipate its own heat it should be very touchable. Otherwise its running hot and though it may be working now, your prone to premature failure. Got to a electronics store and get a small cooling fan for it!
Posted on Oct 12, 2013
I have a kenmore range # 79094152310. And when I turn on the right front burner, the top of the oven gets so hot you would get burnt if you touched it, is this normal for this stove?
no --not normal
stoves even glass top stoves are only hot in vicinity of the hot plates
if the whole top is hot , call an electrician in to check the systems
Oct 02, 2016 | Kenmore Kitchen Ranges
GE dryer very hot on top--hasn't been used
Often times the element has broken (burned out) and is now touching the element housing causing it to heat up and stay on even though the dryer is not even running.
Mar 10, 2014 | GE Dryers
Why does my jvc house amplifier gets so hot ,I can't even touch the top ,it actualy burns me, is this normal?
Nop, you have to check the correct air flow from down to top with nothing interfering the top at least 4 inch between amp and next thing up the amp, take away of near heat sources in every possible way, hope this helps, also check the speaker impedance to match with amplifier...this last part is a great source of heat, believe me...speakers should be 8Ohm, and anything less will put the amp under stressful situation generating lots of heat...
Oct 12, 2013 | Car Audio & Video
Top of dryer and the back panel get too hot.
Of course they get hot, that is normal.
Jun 30, 2017 | Frigidaire AEQ6700FS Dryer
Dryer top gets very hot as soon as i plug in
time to replace the timer b4 you burn down your domicile (aka house )
Aug 06, 2009 | Whirlpool Dryers
When my car is not on the three blue lights on top of the amp are still on, but the power light on the side of the amp is not. Is it normal for the three lights on top to stay on all the time?
No it is not normal.. Normaly when lights stay on the problem is a constantly hot remote wire, but in your case you say the main power light is off.. Soo one can only assume the the problem is in the LED board it's self. This can happen when an amplifier is over heated, or has a poor soldering job. Now if you can hear white noise comming from your speakers with those lights on, then you have a simialr, but more serious issue. If it is just the lights, and not a powered up amplifier I would just let it go.. LED's draw very little power, and can't hurt anything. If the AMP is actualy staying on, I would get it repaired..
Jul 25, 2009 | Audiofonics ADF-241 Car Audio Amplifier
Top of Dryer getting scalding hot
hi there try drying a load without your house ducting.if its restricted at all this cause the heat to not leave the dryer a designed by manufacture and their for get hotter.can be other things but thats most common.ps should have good air flow leaving dryer when vent off.but because fine at house just moved from i think new house is the problem.God bless ,tom
Jan 05, 2009 | Dryers
My rf367 range gets so hot during the self cleaning cycle that the top of the range is to hot to touch and the fan on my otr microwave comes on.
Normal operation. If in doubt place a high temp theromoter on range top to see if it exceeds 600-900 degrees
The basic idea is "burn baby, burn!" Self-cleaning ovens use an approximately 900 degrees Fahrenheit (482 degrees Celsius) temperature cycle to burn off spills leftover from baking, without the use of any chemicals. A self-cleaning oven is designed with a mechanical interlock (patented in 1982) to keep the oven door locked and closed during and soon after the high-temperature cleaning cycle, which can be approximately three hours. The door stays locked to prevent burn injuries. You can open the oven door after the oven cools to approximately 600 F (315 C).
Dec 14, 2008 | Whirlpool Kitchen Ranges
JVC Car Stereo Very Noisy
Bought new JVC stereo and installed it. No noise, no cracking. 1st stereo must have been bad.
Jun 08, 2008 | JVC AM FM CD DET FACE CAR STEREO
Refrigerators Logo
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
