Question about Emerson Evergrind E202 1/2 HP Garbage Disposer
Garbage disposer won't drain water - Emerson Evergrind E202 1/2 HP Garbage Disposer
Garbage disposal water comes up
I have no idea what this has to do with water heaters but if a sink and this has been happening since it was installed the problem is in the piping under the sink. It may also indicate your drain is starting to plug. This would be indicated by taking longer to drain the sink.
Jan 27, 2014 | Water Heaters
Garbage disposal quit working. Just stopped
Press reset button located on bottom of unit.
Use broomstick down inside disposal to make sure cutter disc rotates freely.
Copy following link for troubleshoot and illustrations:
http://waterheatertimer.org/How-to-repair-and-install-Garbage-disposal.html
Gene
h
Aug 19, 2013 | Emerson Evergrind E202 1/2 HP Garbage...
Clear water left n bottom of dishwasher
Check drain and pump. If the water goes to a garbage disposal then remove the hose at the disposal and see if it is clogged.
Good luck,
Marty
Mar 23, 2013 | Whirlpool Whirpool Energy Star Dishwasher...
Leaking garbage disposal
1) Where is the leak coming from?
Copy following link for troubleshoot walk thru and replacement tips
2) Add a comment Feb 2013
Feb 10, 2013 | Emerson Evergrind E202 1/2 HP Garbage...
Instant hot water dispenser does not heat water.
I had the exact same problem. I even replaced the first unit with a second unit...because I was sure I hooked everything up correctly. Then I called their support line and and felt very stupid. They asked one question "are you plugging in the Quick&Hot into the same electrical outlet as the garbage disposal"?. I said yes..and the garbage disposal works fine (thinking that this indicates a good electrical outlet). She then said "That outlet works off of a switch so no electricity is getting to the Quick&Hot until the disposal is turned on). Gosh darn it...that made total sense. I then tested this out by plugging an extension cord into a different outlet and it worked fine. Boy...do I feel stupid. Hope this helps.
Jan 17, 2009 | RTO Waste King AH-780-UL Quick&Hot Instant...
Emerson Evergrind E202 1/2 HP Garbage Disposer Logo
Top Emerson Water Heaters Experts
Donni Steen
Gil Shultz
ray gallant
Are you an Emerson Water Heater Expert? Answer questions, earn points and help others
