Question about Philips Magnavox MWR20V6 DVD Recorder/VCR
How to buy a dvd recorder on line - Philips Magnavox MWR20V6 DVD Recorder/VCR
How to i get access to the lens on my Panasonic DMR-ES10EB DVD recorder to clean it?
The safe way is to purchase a cleaning disk. It has two brushes on a disk that you put in the unit for a short time. You can buy them on line or at any electronics store.
Thanks for using just answer.
Apr 07, 2011 | Panasonic DMR-ES10 DVD Recorder
Disc say cant record,what disc do i buy
This model (PY90DG) DVD recorder supports the following disc recording formats: DVD+RW/DVD-RW/DVD+R/DVD-R for everyday video. These should record fine. The RW discs are for repeated recording/erasure while the R discs are once-only recording types - the R discs must be finalised in this deck to make them playable on other DVD players. DVD-RAM discs are NOT supported by this unit. This recorder will play MP3 files on a CD-R or CD-RW (not DVD-ROM) just fine as well, but will not record them.
Best discs to buy for this type of recorder are DVD-R (recommended brand - Verbatim or TDK if you can get them, but not Memorex). These are OK.
Feb 22, 2011 | Funai PY90DG DVD Recorder
Recorder keeps 'self checking' then taking dvd back to begining, although only on recordable dvd's, not rented. Are recorders worth repairing or are you better just buying another?
I have had a Panasonic DMR-E85 with this exact same problem you are describing. As I bought a Freeview Dual-tuner PVR I just bought a second-hand DMR-E55 as I liked the Panasonic interface. Two months down the line it is now exhibiting the exact same problems, except now as well as the continual self-check rebooting, it's also refusing to eject the disk. Booo. Time for me to buy a new DVD recorder again, and this time certainly not Panasonic... :(
Dec 02, 2009 | Panasonic DMR-E55 DVD Recorder
Can't dub from Samsung VR8606 to another device
If you have a scart socket on the back of the vcr poss marked av1.Connect a scart lead to this and if the dvd recorder has scart sockets connect to the one marked av2.Then put the vcr on play and the dvd on av2 and you should be able to record,hope this works.Jamie
Jul 07, 2009 | Samsung DVD-VR375 DVD Recorder/VCR
Go video vr3840 dvd/vcr player recorder combo
hello. well the only thing you can do is.!!! try to find another go video player. on line .!!! try putting a add on a site that your looking for a go video vr3840 dvd/vcr player.!!! chep.!!! you never know you might get lucky and find one . well "GOOD LUCK"
Jul 23, 2008 | GoVideo Go Video DVD/VCR Combo
Does not recognize a blank DVD
I bought DVD-R 1-16xspeed made by TDK which work fine.... it seems to be a bit of a mine field of discs available but I do remember these were recommended by Samsung via a leaflet in the box.
Apr 03, 2008 | Samsung DVDR120 DVD Recorder
Dubbing vhs to dvd
Easy. Connect RCA lead from video/audio OUT on the VCR to video/audio IN on the DVD recorder. Set DVD recorder source to VIDEO then press play on the VCR and record on the DVD recorder.
Sep 09, 2007 | Aspire Digital AD-8091 DVD Recorder
Dvd recorder, pc, dcd player
I take it this is a recorder only model not one with hard drive. I guess it will be line out from PC to line in on the recorder The recorder probably has RCA red/white cords So you will need a 3.5mm stereo jack to RCA converter this will work on the PC either way line out for trans to DVD line in for form DVD to PC
Jun 23, 2007 | Sanyo DRW-500 DVD Recorder
Cannot record thru line 1
If you could but now you cannot then this is a circuit break down- although check your set up , but I feel it is the machine beginning to die
Jun 15, 2006 | Sony RDR-GX315 DVD Recorder
Philips Magnavox MWR20V6 DVD Recorder/VCR Logo
21 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
