Question about Mcculloch 16" Electric Chain Saw Mcc3516f
Tighten chain How do I tighten the chain on Mcculloch 16" Electric Chain Saw Mcc3516f? It is loose.
davesoucy
  • 148 Answers
SOURCE: need an owner manual for mcculloch eager ****** 300s-16
You would pay the manual about the price of new saw. These are made in china and usually motor or the switch blows. Check that the voltage pass thru the switch and if so and it dont work, throw it away.
Posted on Aug 28, 2009
Testimonial: "not what I was asking about. I wanted a user manual for mcculloch eager ****** 300s-16 electric chain saw. You people can't read."
dontbother10
  • 2220 Answers
SOURCE: I have Mcculloch Mac 10 10 chain saw year unknown
Put a small amount of fuel mix in the carburator. If it sputters investagate fuel system.
Lou
Posted on Oct 08, 2009
  • 2841 Answers
SOURCE: chain comes off mcculloch electramac em250 chain saw
Adjust the chain until you can pull on it and it will come away from the bar but will not hang from the bar. If that does not solve your problem then the chain or drive gear is worn out. If the oiler is not working it is for sure worn out.
Posted on Apr 25, 2010
dontbother10
  • 2220 Answers
SOURCE: set the carb for a mcculloch 3516 chain saw
Carburetor Adjustment
There are no hard and fast settings.
A good initial starting point for the "H" and "L" needle valves are 1.5 turns CCW from lightly seated.
The "T" adjustment enters here (idle speed) and there is no initial setting without a tachometer, depending on age of your saw there may not be any initial "T" setting.
The "L" needle is primarily idle performance (not speed) and acceleration to full throttle.
The "H" is mostly performance at speed, but all are interconnected.
Start with a fresh mix of fuel. Put ALL of the old mix in any 4 cycle engine and start new. I suggest 50:1 regardless of what your manual says.
CW is leaner; to lean will destroy the saw. If over tightened closed (CW) the adjustment screw faces are easily marred; once marred adjustments are difficult to impossible to set properly.
Clean the air filter; adjusting with a dirty filter can cause a run lean condition once cleaned and the saw run.
Clean the spark arrestor and muffler; if the saw cannot exhale it cannot inhale.
Now we adjust for performance. The best performance adjustment procedure I have found follows.
Madsens Shop & Supply, Inc. Carburetor adjustment (All saws homeowner and professional are the same)
http://www.madsens1.com/saw%20carb%20tune.htm Read step 4 (allow it warm before making adjustments).
There are 2 wav (sound - idle & full - may not be highlighted) files that I find most helpful, I think you will too.
I am going to inject a little philosophy here. Undetected air leaks and defective fuel delivery systems account for most chainsaw failures. Constant adjustment of needle valves can easily camouflage more serious problems that result in burning up your saw. A sudden need for an adjustment is often indicative of a larger problem.
If push comes to shove a local saw shop (I prefer Stihl mechanics and do not own a Stihl) should be considered.
If you have more questions or need additional help please reply below and I will get back to you. HTH & Good Luck.
Lou
Thank You for using FixYa.
Posted on Jul 09, 2010
  • 54 Answers
SOURCE: McCulloch 14" chain saw Model CS 38 EM It quit
Most often there is a dust-oil clog in the bottom of the bar slot which closes an oil passage between the bar slot and the hole drilled half way through the side of the bar. This provides a passage between the thin shim plate with the two bar bolt holes beside the bar and through to the oil tank or pump output. You can remove the bar and chain and punch out the blockage in the bar with a paper clip if the chain is removed. Make sure the wire can be pushed from the bar slot right through the side hole in the bar. A gravity feed chainsaw should leak right out into the slot of the shim plate, a button pumper should squirt out there with the bar removed. With a button pumper you may have a tiny check valve in the line or the push button to take apart, replace the spring or unstick the ball inside the check valve. This is why they went to the gravity feed oil system which just leaks in there and gets picked up by the bottom of the links as the chain races past the passage between the bar side hole and the chain slot.
Posted on Mar 24, 2011
Testimonial: "I checked as you suggested and I removed the pump from the crank shaft and the plastic gear is stripped. Now I can not find a pump. Thanks Jim"
Oil to petrol ratio
25 to 1 get 2 stroke oil from a hire shop only need a one shot mix, will do up to a gallon.
May 02, 2012 | Mcculloch 16" Electric Chain Saw Mcc3516f
How to tension the chain on a mcculloch 2618cav chainsaw?
Slacken off the two 13mm nuts on the cover, leave them finger tight, clean away the saw dust from the front of the saw to expose the adjuster screw, this is in the front of the cover, it will reqiure a flat blade screw driver, screw in clockwise to tighten the chain, when adjusted correctly it should fit snuggley all the way around the bar, with a gloved hand pull the chain around the bar manualy, it should pull freely with very little resistence.
Oct 30, 2011 | McCulloch 16 In 4.5 Hp Electric Chainsaw...
My chainsaw wont start. electric souce is good, but nothing happens when you press the trigger.
Check the chainbrake is fully pulled back to the top handle, many electric saws have a micro switch to prevent the saw from running with the brake on.
Jul 16, 2011 | Mcculloch 16" Electric Chain Saw Mcc3516f
Chain loose
Chainsaw bars get loose all the time. This can create a dangerous situation.
Tightening the chain is done through the positioning of the bar. The further away from the drive gear it extends, the tighter the chain is.
The are usually two nuts holding the bar on. These need to be loosened slightly to allow the bar movement.
Depending on your model there may be a guard over them. Remove it.
Once the nuts are loose, locate the tensioning screw. It will be relatively small, located adjacent to and facing parallel to the bar.
This screw is attached to a metal lip that in turn is attached to the bar. The screw remains in one place while the lip moves up down.
Start spinning. Keep going until the chain is tight.
Tighten the Bar Nuts, replace the guard if necessary.
Now go slice some wood.
Best regards
Mike
May 17, 2010 | McCulloch 16 In 4.5 Hp Electric Chainsaw...
I need to tighten the chain. Is there a way to do
there should be a screw at the back end of the bar.Screw it in to push the bar out ,or forward, thus makeing the chain tighter
Apr 04, 2010 | McCulloch 16 In 4.5 Hp Electric Chainsaw...
Chainsaw chain will not tighten on the guide bar
The two nuts on the bolts for the chain bar, need to be loosened.
Then the tension screw is tightened by turning it Clockwise. (To the Right)
If the chain doesn't tighten,
1.Insure that the nuts are loose enough, so that the chain bar may slide.
2.Insure that the tension adjusting screw does not have stripped threads, nor the threaded part of the case it screws through.
Oct 17, 2009 | McCulloch 16 In 4.5 Hp Electric Chainsaw...
Poulan Farmhand chainsaw chain tightens too tight for motor to move chain
Make sure the chain is not over tightened. When adjusting the tightness, ensure there is at least 1/8" of looseness by pulling up on the chain in the middle of the bar and releasing it. If a chain becomes overheated because of leaning on the saw when the chain is dull, or lack of oil on the chain, it may expand in the track and not turn freely.
Marlyn, Mountain, Ont. Canada
Oct 02, 2008 | McCulloch 16 In 4.5 Hp Electric Chainsaw...
Mcculloch 16" Electric Chain Saw Mcc3516f Logo
Top McCulloch Garden Experts
Roland W VanLue
Roland W VanLue
roeb
Are you a McCulloch Garden Expert? Answer questions, earn points and help others
