Question about Boating
Just clicks when I turn ignition - Boating
  • 36 Answers
Insure battery connections are good and if so try Tapping lightly on the solenoid while trying to crank the engine. If it cranks, replace the solenoid, if it doesnt you may need a starter. Insure battery voltage is getting to the solenoid large terminals while the key is in cranking position. the large terminals on the solenoid. You can tap lightly on the starter also if your getting power to the starter but its not cranking.. LIGHTLY Tap. The brushes inside the starter may be stuck. These are typical first things to try. Let me know how that goes. God Bless
Posted on Oct 14, 2013
Why want middle burner light automatically but will light with a lighter
That unit is suppose to have electronic quartz igniters. Apparently there's a problem but it doesn't automatically mean the igniter needs to be replaced. If you see a spark from the igniter then it's fine. If you see a spark but no flame then the ignition process is out of synchronization. In other words, the gas hasn't concentrated near the spark enough to ignite. This may be a matter of low gas pressure or the extra length the gas needs to flow to reach the center burner is impeding ignition. Simple fix is turn the knob just enough to start the gas for 2 seconds then continue the turn to click the igniter. or simply use a match. You may also see if there are any adjustments on the gas manifold that will enhance bringing more gas to the center burner quicker. Some unit have one click & that's it, others click the igniter continuously until you release turning the knob. Good luck. you'll figure it out.
Aug 13, 2015 | Verona VEFSGE365DSS 36" Double Oven Dual...
Gas was turned off and igniters keep clicking?
As I did not see what occurred, I suspect that the tea kettle boiled over and sent water into the burners. The igniters kept clicking and I eventually turned the gas back on. Will have to replace one igniter which apparently went out and have to light it manually at this point.
Dec 11, 2009 | KitchenAid Cooktops
I have a JGP636 or 960. One burner won't do
When you turn the burner knob on does the igniter click and turn off on it's own when the flame ignites? If it does then it has flame rectification. That means it can sense when the flame is on. Or does it click when the knob is in the light position and not stop until you move the burner knob? Then this is standard ignition. If it is standard ignition it sounds like it is the igniter switch built into the burner knob might be defective. Are you able to turn on any burner knob and when they are in the igniter position do all the electrodes spark or just the burner that you are turning on? If they all come on then they are wired in a series. If they are wired in a series do you get a spark at the electrode of the problem igniter? If so you can turn on one of the other burners to ignition position then while it is clicking turn on the problem burner to light it. If the cooktop uses flame rectification then there may be a problem with the switch built into the burner knob or the flame rectification sensor for that burner might be bad.
Sep 29, 2009 | GE Profile JGP636 Gas Cooktop
Ignition is clicking all the time, whether the gas is lit or not.
The clicking is the igniter. If it is clicking and not lighting, then you may have to purchase an igniter kit and replace it. the relays can go bad, or igniter fails.
Sep 04, 2009 | Bosch 30 in. NGP 732 / 736 Gas Cooktop
1997 Honda Passport. Merely a ''click'' when turning ignition
check your battery teminals are tight allso check the battery has power init by turning lights on could
Jun 05, 2009 | 1997 Honda Passport
Burner won't light
hi gud day,i think the sensor is we have problem is hard to repair in ur own,try to call the person have expireince for repair that unit, or ur igniter ligther have damage like small broken if u hear have click is ok but much better to check the igniter coz the broken igniter is not directly spark in the burner that why is not light.to check if remove the burner base cover then see if the igniter like a small niddle color white,turn the knob to click the igniter then see it wer the spark directly if u not see it means have a broken igniter.
tns gerbee
May 26, 2009 | Amana AKS3040 Gas Cooktop
1999 Honda Accord, 5 speed
It could either be a BAD starter or a BAD ignition they both would have the same symptoms of a "CLICK" alone. I would most likely lean toward the ignition because the key is difficult to turn but its not all ways true that key is tight because the ignition is bad, although possible. It could just mean a bad ignition cylinder(just the key part why its tight) I want you to do a test for me. With clutch engaged turn key to start position and listen for click on starter in the hood, when trying to start. If you hear starter click then the ignition switch is good. (Before you do this make sure that battery is FULLY CHARGED).STARTER IS AT FAULT. IF no clicking is heard coming from starter check starter fuse and if its good YOU have a BAD ignition switch. Contact if you need more hep and Thanks for using FIX YA
Jan 14, 2009 | 1999 Honda Accord
Igniter issue - some do not turn on other do not turn off
I would try cleaning the burners. You can purchase cleaning brushes made specifically for this purpose and they work like a charm.
Sep 25, 2007 | Thermador PC366BS Stainless Steel Gas...
Clicking sound whenever I turn on a burner
There is no problem. The click your hearing is the spark module igniting the gas. The clicking will only occur while the know is turned to ignite and will stop after your turn the knog to any other setting.
Jun 17, 2007 | Jenn-Air 36 in. CCG2523 Gas Cooktop
Boating Logo
67 people viewed this question
Top Boating Experts
Steve
Steve
ray gallant
Fabrice Wolters
Are you a Boating Expert? Answer questions, earn points and help others
