Question about Whirlpool Furniture
Whirlpool wine cooler fan running not cooling
fridgetech
  • 473 Answers
SOURCE: wine cooler doesn't cool properly
Few things to check here. If the compressor is not running then the problem may be a bad thermostat or the compressor start device (ptc starter). Most common would be the thermostat on wine coolers. Also need to check if the fan is running. If everything is running then you have a sealed system problem. If the fan is the only thing that is not running that will cause a no cool situation.
Posted on Oct 07, 2007
SOURCE: danby wine cooler repair
I am having a problem with my wine cooler also.I found the upper evap fan not running.So i opened up the control board and plugged the fan that was not working into one of the other 2 sockets,and the fan worked.so i have a circuit board problem.If you go online to sears parts and repair.put in your model# and search,it will bring up a diagram of most of the parts available.And no it doesnt have to be a GE product.
Posted on Jul 08, 2008
SOURCE: Cuisinart Wine Cooler
If you call (Cuisinart’s service center (800) 726-0190), they will send you a brand new unit for $10.00.
Happy Holidays,
AC Freeborn
Posted on Dec 02, 2008
  • 44 Answers
SOURCE: danby wine cooler compresser not running and is hot
The compressor needs to be tested to see if it's operational. This normally needs to be done by a service tec.
Posted on Aug 21, 2009
  • 14 Answers
SOURCE: Vinotemp VT-16TEDS has light on but doesn't cool
You may need to change the cooling system on the unit if the unit is free of dust and still does not cool.
Posted on Sep 21, 2009
Wine fridge is not getting cold anymore
Its really hard to determine without proper diagnosis, but are you sure it indeed has a compressor? does it run ? Does it have a circulating fan inside? A lot of the wine coolers I've dealt with were "Peltier" coolers. They use electronics to cool usually only to about 10deg below room temp. They require a load ( in this case wine bottles ) to operate properly. They don't have a cold control like a refrigerator.
Jun 30, 2014 | Koolatron KWD28SN 28 Bottle Compressor...
Not colling
Check the back to see if the compressor is running or just really hot. If it is not running it could be a thermostat issue, but if it is hot and not running, that means your compressor has problems and will need to be replaced.
Apr 07, 2014 | Whirlpool 22" Dual Zone 38 Bottle Wine...
Wine cooler not cooling.
Your themostat inside the cooler may be broken.
Mar 19, 2014 | EdgeStar TWR282S Wine Cooler
It just stopt cooling (wgersdorf@yahoo.com)
Turn the temperature dial to the lowest temperature setting. Wait 24 hours for the wine cooler to reach the desired temperature. Also, turn the wine cooler off and inspect the fan. If the fan if it's running or not.
Lastly, check the compressor.
These are the areas that could make your wine cooler stop cooling; the temperatue settings (Thermostat), then Fan and the compressor.
Check these three areas and let me have a feed back.
Bye for now.
Mar 04, 2011 | Haier BC112G Wine Cooler
My wine cooler stopped cooling and running
What model # do you have? Is there anything working at all like lights, fans, or displays?
Sep 07, 2010 | Emerson (025806803716) Wine Cooler
FR23SL Uses Peltier Cooling - No compressor nor freon....
Luzer - Thanks for the very helpful solution. My cooler has the problem described. When I take off the back and plug it back in, all three fans run, but the unit does not get cold. Is it possible that it needs new fans anyway (like maybe they are going but not moving enough air to generate the effect)? Or woudl it be something else?
Thanks!
Mar 25, 2010 | Emerson (025806803716) Wine Cooler
Fan not working
Does it have a compressor and does it run? If so there is probably a relay on that board that is bad or only runs with the compressor.
Dec 16, 2007 | Danby DWC283BLS Wine Cooler
Wine cooler doesn't cool properly
Oct 07, 2007 | Marvel 61WC Wine Cooler
Furniture Logo
32 people viewed this question
Top Whirlpool Furniture Experts
john h
Gil Shultz
Are you a Whirlpool Furniture Expert? Answer questions, earn points and help others
