How to enter bios with v k8m8msr2 b motherboard
Stuck at Motherboard splash screen
your stuck at the boot from DVD, you must boot form C to finish installation.
Jul 27, 2014 | EliteGroup P4M800-M7 Motherboard
Bios cant read a 500GB HD
p4vm800 fsb mb solution- format hard disk in another compter and install window (os) on your hard disk .
connect with your motherboard ,turn on computer press bios entering key ( f2 or del ) . after entering the bios set up set as defalt . install window (os).
Aug 18, 2011 | Asrock P4VM800 Motherboard
Need to get into bios settings on 8k3a motherboard
During the boot process you will see on the screen to press a certain key to enter setup
Press and hold that key during the boot up process to enter BIOS
after you make any changes in BIOS press Esc then press the F10 button save to cmos to restart
cmos is located in BIOS
hope this helps
Feb 26, 2011 | EPoX computers10: Mainboard EP-8K3A...
How to reset the bios to factory default on Asrock P4I45GV R5 Motherboard
Enter the BIOS using the key that the POST screen indicates. After entering the BIOS, you should be able to navigate to a tab that says "restore factory defaults" (or something similar). This will allow you to reset your BIOS settings to default.
Dec 21, 2010 | Asrock P4I45GV R5 Motherboard
My motherboard is Intel D101GGC. On start-up it is showing BIOS ROM CHECKSUM ERROR..DETECTING DRIVE A MEDIA..then a bip sound and then it shows PLEASE ENTER SYSTEM DISK AND PRESS ENTER...i'm not able to...
Go to your bios again set it to default and then restart it.
If nothing happens you need to use your operating system disc to fix that.
Set your first boot sequence to CD first.
Hpe that helps you out!
thanks for using Fixya!
Dec 16, 2010 | Intel D101GGC Motherboard
Asus logo comes up on boot but cant enter bios or anything else beccouse the keyboard doesn't work. I'we tryied other keyboards bbut they don't work to so i can't enter bios or install Windows my...
Most Asus motherboards by default have the USB ports enabled in the bios.
Buy the item, Y adapter below to bypass the PS/2 keyboard port on the motherboard; http://www.cablestogo.com/product.asp?cat_id=1538&sku=27225
You should be able to enter the bios using a USB port. Or buy a single PS/2 to USB; http://www.cablestogo.com/product.asp?cat_id=1538&sku=35700
Cheers'
Mike
Jan 20, 2010 | ASUS P4P800-E Deluxe Motherboard
How to install bios setup
You don't install a bios setup. It is on each motherboard already. A chip ( called the bios chip ) has the setup on it. You just need to enter it, when the computer first boots. There should be a time, when on the screen it says something like " hit F2 to enter bios". Some computers and older ones had different ways to enter the bios, and your manual should say.
If by chance you are asking on how to upgrade your bios, reply and I will give those instructions.
Good Luck
Jan 18, 2010 | Computers & Internet
Im trying to enter to my computer bios screen but
press delete or what command it says... to enter bios set-up
Oct 25, 2009 | Mercury PVCLE266 Motherboard
Unable to boot
i have intel D101 motherboard and 2.8GHz processor, 512MB Ram but boot settings are disabled in bios
and unable to enter into bios.
Aug 09, 2008 | Intel D101GGC Motherboard
Computers & Internet Logo
61 people viewed this question
David Payne
David Payne
