Question about Home
I need instructions to warm the water in Vitra jacuzzi
My client buy jacuzzi whit light and water jets but is not working the main control not turn on curse water in the plug all connections and not working..not guide any instructions
Jacuzzi Is STILL a viable SPA / Whirlpool Entity...
If you know the age of the equipment...
It may actually date back to when Jacuzzi
headquarters was right here in the San Francisco Bay Area.
Now SFSpas.com ... 510-527-5547
Paradise Valley Spas The Bay Area Top Hot Tub Retailer
Richmond, California (to be specific... (on Jacuzzi Street)).
((I was sad when they left).. but am still a happy customer).
Air "switches" remain their most popular trouble...
and if you know what yours LOOKS like... you
can VERY LIKELY still buy the parts from eBay...
I
recommend going to Jacuzzi... (opinion).
Carnac the Magnificent
Aug 09, 2017 | Jacuzzi Home
How to tighten a vitro nupva toilet seat.
Christina, how to tighten or install hidden fasteners on your toilet seat. check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Remove Vitra Shift toilet seat
Soft Close and Quick Release Toilet Seats Installation
How to fix loose toilet seat
http://vitraglobal.com/
Jun 27, 2016 | VitrA Home
I have A VITRA CORNER TOILET DEUL FLUSH BUTTEN BROKEN AND ITS VERY SLOW TO FILL
Your water valve must be clogged with sediment in the line. It has nearly shut the water off.
Feb 19, 2013 | VitrA Home
Hi, Just moved into an apartment with two vitra retro toilets. As soon as you start to use them you can hear water running as you add waste to the toilet bowl. Is this normal? The developer tells me it...
check the type of fill valve that you have in the tank and check with a plumbing shop or better yet check your local lumber company as
they usually carry toilet replacement parts and you can read the instructions on how to adjust the one you have
Sep 22, 2017 | VitrA Aria Toilet with Elongated Bowl/...
What do I need to clean my sink with to keep the shine?
You can use Kohler cast iron kitchen sink cleaner, available on line, Jacuzzi recommends warm water, mild non-abrasive liquid soap for everyday cleaning and Barkeepers Friend or Zud for tougher stains. No Abrasives whatsoever. like Comet etc.
Mar 08, 2011 | Jacuzzi Kitchen Cast Iron Black Finish...
We have a hot tub or jacuzzi inside or on the side of our pool. We had a new heater installed. The jacuzzi should heat up very quickly but now the pool tech claims the drain from the jacuzzi is blocked,...
Is the equipment to heat and filter the hot tub separate from the pool equipment or do both bodies of water share a common heater and filter pump? In most cases they share a pump and heater with valves that direct the flow of water depending on how the pool owner wants to use the pools.
The first thing you need to determine then is if the equipment is working properly. Is there flow of water to and from the spa? If so, is the heater burner kicking on? If it is running, is it running properly with sufficient gas pressure, 3-4" tall bright blue flames and stays on continuously during the heating cycle for the spa?
What is 'very quickly' for the time to heat the water? In other words, if everything appears to be operating normally but the water is not warming fast enough or at all how much time is elapsing before deciding the heater is not working?
How old is this equipment and how much experience do you have with this pool tech or the company they are from?
Nov 07, 2010 | Jacuzzi Pool & Spa
Home Logo
43 people viewed this question
Top Home Experts
john h
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
