Question about Kitchen Ranges
My temperature will not increase above 350 degrees, it actually goes backwards when hitting the up temp button and also will not even heat to 350 degrees. This happened after I used the self cleaning
I have a Whirlpool self cleaning oven, model RBS245PD86 which I recently cleaned by using the self cleaning button. After this, I am not able to increase my heat past 350 degrees and it does not heat at all when preheating to 350 degrees. Is my heating element broke? What do you recommend?
  • 113 Answers
Sounds like your thermostat is bad
Posted on Apr 23, 2009
Whirlpool Accubake Wall oven pre heat but temp goes 350 and downwards when pressing temp up
I am not sure about this, but sounds like a connector is on backwards or in the wrong place.
Nov 26, 2014 | Whirlpool Ovens
Can not raise temperature above 350
500 degrees farenheit is 260 degrees celcius (metric)
any chance the display is set for metric ?
Jun 28, 2012 | Whirlpool RBS305PDS Electric Single Oven
Whirlpool Built In Oven - Accubake - RB5275PD06 After self cleaning last week, the control panel is not functioning properly. For example, when we press the temp button, it won't go above 350. When...
Good Evening!
This is a common problem that Ledgestone Technologies and Fixyourboard.com can solve. The touchpad on your oven has failed and will need to be replaced. Read more about the failure and solution below. Message us if you have any questions!
info@fixyourboard.com
Whirlpool Oven Wont Increase Temperature Stuck at 350
May 27, 2017 | Whirlpool Ovens
I have a westinghouse window unit and I think it has heat strips for the heat. How do I tell if it is a true heat pump or if it has heat strips and how do I get to the Heat strips in the unit to check.
If it is a heat pump, the compressor will be running both in cool mode and in normal heat mode.
Confirm the current indoor temperature. Turn the thermostat up one degree at a time until it comes on. This will typically be 1 to 4 degrees increase. As soon as it comes on stop increasing the temp.
If the compressor is running, it is a heat pump.
Check the temperature coming our of the vents at that time. You should have 30 to 60 degrees increase from the air temp going into the unit and the conditioned air temp coming out.
Then turn the T-stat up another 10 degrees. If the temp coming out of the vents increases by 20 degrees or more. the strips are on.
The strips operate in three situations.
1) the system is set to emergency heat
2) The heat pump cannot keep up with the demand for heat. (because its too cold outside, the desired temp setting is greater than 4 to 8 degrees above the room temp, or the HP is malfunctioning.)
3) The HP is in defrost mode
You could also take the panels off the unit and look for a reversing valve, but unless you know what you are looking for you will not recognise it.
Oct 12, 2009 | Heating & Cooling
Honeywell T87f 3855 Doesn't Activate Heater
thats becaue you need more than this zone working like you said about the master/slave this zone is a slave.
Jan 25, 2009 | Heating & Cooling
Whirlpool Electric Wall Oven RBS275PDQ6
had same problem, had computer checked out by profesisonal. Was ok. But it seems it is the control pad that clean cycle screws up. Try this (thanks to my wife and her experimental prowess). 1. turn oven on to custom broil. 2. push down temp button to 375. 3. press bake button. 4. You should now have up or down temp. We think you have to get past pre heat cycle in order for this to work. But work it does.
May 07, 2008 | Whirlpool GBD307PDS Electric Double Oven
Oven does not maintain temperature. Part 2
sometimes when they get hot that is when they fail
Sep 18, 2007 | GE Profile Spectra JGBP90 Gas Kitchen...
Kitchen Ranges Logo
460 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
