Question about Dell Latitude D510 Notebook
Vista Installation on Dell and
Hi
I did try to insall vista on my DELL inspiron 600m and on Laditude d510 but t fail to install. For which it is quite irrating to me and From the same DVD i install the vista ultimate on my dell Precission M90 Notebook it install very nicely and i was amazing to find out that vistal ultimate runs very fast then xp but still have and wireless internet connection problem once it connected with my other note book through wireless connection to internet and when i tunn off my net connection and again i want to conect it again it fails to do so and after so many time and utilizing many options i turn my machine off and the next day when i turn it on it connect automatially and without having any porblem. Kindly help me out.
Best Regards
Ghauri
smgpk@yahoo.com
    Novelist:
  • 166 Answers
Actually, VISTA ultimate comes with proper license keys for certain series of laptops only. And i'm sure the DVD which you have is for only "Dell Precission M90 Notebook"... so please do not try same DVD on another laptops... use recommended DVD or operating systems only
Posted on Apr 23, 2009
  • Shyny Saxena
    Shyny Saxena Apr 23, 2009
    thanks for rating...i hope my advice would work for u
Dell Inspiron 6400 doesn't boot past dell splash
The hard drive has failed, or windows 7 is not compatable with the laptop. Try installing vista, if this works! there is a problem with windows 7, no change! have the hardware checked for possible replacement.
Jul 01, 2012 | Dell Inspiron 6400 Notebook
I cant get my dell laditude D510 to turn on
Some machines need a battery with some power left in them, to work. If the battery is finished you will need to get it rpacked or buy another.
If the battery should be OK you cannot run it on the power supply, that may have burnt out. You can buy ones that work on all machines much cheaper that an original.
Jul 06, 2010 | Dell Latitude D510 Notebook
Windows vista isn't starting up due to corrupted file. How do I log in/
If windows Vista OS isnt loading then your Operating System ( OS ) is corrupted. Try running the installation disk and repairing your system. If this fails you will need to do a FULL operating system re-installation.
May 20, 2010 | Dell Inspiron 1525 Notebook
Dell 600m won't power from ac
It could be the charging port is loose or has gone bad outrightly. If it is shaky or has a dry joint, then try scrapping off the solder and resoldering ok. Power down the pc and then to AC supply to see whether it charges. If it does, then you probably have a corrupt operating system and should be re-installed. If the RAM becomes unstable, it could also come with such a problem. Hence, I suggest too that a confirmed working and compatible memory should be tried on your pc. If all failed then your motherboard is bad and should be replaced. Good luck
Jun 03, 2009 | Dell Inspiron 600M Notebook
Dell Latitude D510 Screen Failed
The 14.1" inch screen is compatible with Latitude models D500, D505, D510, D600, D610 and Inspiron models 500m, 510m, 600m.
You may also need a screen inverter - in fact that is often the reason a screen is considered to be failing. The lcd inverter can be one of the most common items to become defective in a laptop computer. You may need a lcd inverter replacement if your screen is dim, dark, colored oddly, blinking, flickering or has dark stripes. Just something to keep in mind.
Hope this helps,
Chris
Mar 20, 2009 | Dell Latitude D600 Notebook
CANNOT INSTALL AUDIO DRIVER AFTER CHANGING VISTA TO XP IN DELL 1525 LAPTOP, PLEASE GIVE ME A SOLUTION
Here is a set of links to follow to get the appropriate drivers for XP for the 1525. You also might want to check Dell's site they have a list of drivers available for XP and the components.
http://support.euro.dell.com/support/topics/topic.aspx/emea/shared/support/reinstall/en/reinstall_center?~ck=ln&c=uk&l=en&lnki=0&s=gen
Follow this simple Installation step to downgrade Windows Vista to Windows XP.
a. You have to prepare SATA Driver on your USB Disk. You may get the Dell Inspiron 1525 SATA HERE
b. You have to prepare Dell Inspiron 1525 Wireless Card Driver as well known as Broadcom BCM 4311.
c. For Dell Inspiron 1525 Webcam you have to get Creative Labs Webcam that you may get it in the Windows Update Sites.
d. Get Marvell Yukon 88E8040 PCI-E Fast Ethernet Controller drivers.
e.
Video Card Driver Intel GM965
Dell Application Software Quickset
Ricoh R5C833 Flash Drive controller Driver
Sound Audio Driver Dell Inspiron 1525 SIGMATEL STAC 92XX C-Major HD
Download Intel Chipset
Dell Inspiron 1525 Modem Conexant D330,HDA,MDC,v.92,
Touchpad
Notes: After installing windows XP, you have to prepare windows Downgrade XP patch for Dell Inspiron 1525 before installing Dell Wireless 355 Bluetooth Module and finish Dell Inspiron 1525 driver for Windows XP Installation. Enjoy Xp on your Dell Inspiron 1525 Notebooks.
Jan 29, 2009 | Dell Inspiron 1525 Notebook
Laptop blue screens when trying to reinstall vista
The problem might be with the bad sectors on a hard drive. You should run Scan Disk on a partition where you were trying to install Windows Vista.
Jan 16, 2009 | Dell InspironTM 1501 Notebook
Dell inspiron 600m sound drivers
Hi the easyest place to find all your drivers for your Laptop is to go to the Dell website.
here is a link to your model of Laptop Dell 600m
http://support.dell.com/support/downloads/driverslist.aspx?c=ca&l=en&s=gen&ServiceTag=&SystemID=INS_PNT_PM_600M&os=WW1&osl=en&catid=&impid=
Nov 08, 2008 | Dell (0Y4801) for Inpsiron 600M, Latitude...
Cant re-install windows vista to my dell vostro 1700
Did you try the repair option again, this time just choose repair. If not you need to clean install the computer. You can go the microsoft site to get full instructions for "Clean Install Vista"
Dec 09, 2007 | Microsoft Windows Vista Ultimate Edition
Dell Latitude D510 Notebook Logo
100 people viewed this question
Alun Cox
