Question about Garden
When primed will run for a short time till fuel runs out
  • 7,482 Answers
Hi Charles
Sounds like you have dirt/debris in your carburetor jets, fuel passages or a diaphragm that is becoming non-flexible.
Check/Clean/Replace your Air Filter, a dirty air filter can make your engine run to rich with fuel.
Also be sure to check and clean your spark arrestor in the exaust,if you have one installed on your engine.
Note: ALWAYS USE COMPRESSED AIR TO CLEAN YOUR JETS AND PASSAGES, VERY IMPORTANT.
Note:Before you disassemble the carburetor:
Write down on a piece of paper or take a picture of how the linkage attaches to your carburetor for later reference when you go to reinstall your carburetor.
Mark each piece with a awl, or some kind of instrument that will make an alignment scratch before you disassemble the carburetor into separate pieces.
That way you will know which way it goes back together when you reassemble it.
Sometimes you can get by with priming the carburetor or by using a very small shot of starting fluid and letting it run a few times like that, and it will flush the gunk out of the jets,but most of the time you will need to rebuild the carburetor.
Be sure to check your fuel tank for water and dirt/debris, if there is water/debris then you need to clean your tank.
Check you fuel line condition after a while they will degrade and need replacment.
Check/Clean/Replace your fuel filter if you have one, normally they are located in the fuel tank of chainsaws and weedeaters.
When you remove your fuel lines from the carburetor be sure to make a drawing to how the lines are connected to the carburetor or take a pictue for later reference.
Normally the big line will be the line the fuel filter is connected to inside of the tank.The smaller of the two lines is the return to the fuel tank from the carburetor after it is pumped thru the carburetor by the primer bulb.
Make sure you are using fresh fuel...and oil if your using a two cycle chainsaw or weedeater with the oil to the right mixture...too much oil as it can cause hard starting and excessive smoking.
If the chainsaw/trimmer is over a couple of years old, then I recommend that you buy and install a new carburetor repair kit,because the diaphragm will get hard and that will cause it to be hard to crank.
The diaphgram may look good and flexible, but it can be deceiving and not act as a fuel pump as it should because it has become too hard and will cause hard starting,start and run and shut off, etc.
When you clean your carburetor, I recommend that you use a laquer thinner type cleaner to clean and dissolve the laquer build-up in the float and needle jet passages.
Be sure to remove all plastic and rubber parts before using the laquer thinner because it can dissolve the plastic parts and render them unuseable.
Be sure to use COMPRESSED AIR to blow out all the fuel and air passages.The higher air pressure is needed to blow some of the trash/debris from the fuel or air passages.
Be careful when blowing out the passages, because there are sometimes small rubber type seats in the bottom of some of the passages.
Keep in mind that the float (if you have one) for the carburetor must be level when you go to reassemble the carburetor or follow the instructions you get with the carburetor kit, or you could also ask the parts man that you get your kit from.
When you clean your carburetor and remove the jet screws, you will first need to lightly seat the jet screws.
But before you lightly seat the jet screws count the number of turns it takes to seat the jet screws from their original position.
Be sure to mark the turns down on a piece of paper.
That way when you put the jets back in, you know to lightly seat them first and then turn them back out to their original position before you started.
Note:
The little spring inside of the carburetor goes under the float arm.
That is where your fuel inlet needle/float valve is located...on the arm at the end.
Normally there is a small indention in the carburetor base and a small protrusion on the underneath of the float arm where the spring will be in the right postion for installation.
The spring will set in the indention and you will install the float arm with the needle/float valve and float rod into position over top of the spring,you will push down until it is in position and then you can tighten the screw that holds the float arm assembly in position.
Once you have your carburetor cleaned/rebuilt that should solve your problem.
Bud
Posted on Oct 12, 2013
Once you turn the key on it runs for one second & then quits.Is there a fuel pump sensor that could cause this or is the pump going out. free flowing & under pressure
Only a guess as you don't state model or make. If you are testing fuel pressure at the throttle body you have a TBI system.
The ECM controls the fuel pump by allowing a short run time to prime and then requires oil pressure to keep the pump running.
If you are testing with out the motor running you are only getting the prime signal.
Apr 27, 2015 | Cars & Trucks
1998 malibu can hear fuel pump wen switch is on but wont start as long as we put fuel in top of motor it will run till itruns out could it be relay on fuel pump changed filter
the fuel pump will run for 2 secondes with key on to prime system. then when you crank engine it should run all the time. you check fuse and if current go to fuel pump at tank connector. if there is current then the fuel pump must be defect.
Aug 30, 2013 | 2002 Chevrolet Malibu
Chipper/ Shredder runs for while on the amount you primed the eng
Check to be sure there isn't a small hole or crack in the priming bulb. If there is it allows air to enter fuel line, loosing the prime. Most have a collar that unscrews to remove it.
Jul 18, 2010 | Troy Bilt 24b - 060f766 5hp Chipper...
It just quict. if i prime motor it will run short...
if it has fuel pump unhook line from pump and gravity feed carburetor if it runs the pump is bad
May 21, 2010 | Briggs & Stratton Briggs Stratton Intek V...
1998 gmc 2500 wont keep running
The anti thieft system is keeping it from running.
Dec 13, 2009 | 2004 GMC Sierra 2500
1987 Chevy R10 project truck won't start
check the float on the carb is stuck shut not letting fuel in
Aug 17, 2009 | 1987 Chevrolet R10
Ran out of gas now won't start
Depress shrader valve on fuel rail and see if pump primed,If primed take air snorkle from throttle body of and use carb cleaner to gett running,Some one can keep giming short burst or cleaner to thottle boby inlet till air gets out of system.Have seen this before.Air trapped in injectors.
Jun 20, 2009 | 2003 GMC Sierra 1500
Garden Logo
16 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
