Question about Mitsubishi WD-60638 DLP TV
Screen fresnel I am just trying to find out what the two screens cost for a 60 in. Mitsubishi t.v. with model #wd60638
2 Suggested Answers
mistersony
  • 320 Answers
SOURCE: Mitsubishi screen replacing
You must remove the front bezel and frame holder to replace the screen. You will usually see the screws holding the from from the rear of the unit. Once you get the frame off, take note of the way the old screen is installed. There is usually a label on one side near the bottom; the new screens must be installed with the label in the same location. The lenticular goes on the outside (facing the viewer) and the fresnel goes on the inside facing the mirror. You will be able to recognize the fresnel, it has a series of concentric circles that are raised on the sirface of the plastic Be sure to rate this solution.Thanks!
Posted on Nov 08, 2008
Find generic dlp lenticular screen and fresnel screen
I would find out the make of the lens, probably cannon. The Fresnel and Lenticular screens are nothing to do with the size of the picture, the lens does that bit.
Oct 01, 2017 | Televison & Video
Mitsubishi hdtv 1080 ws-a65 screen broke need replacement
there are 2 functionality screens and 1 screen protector (on some)
front screen = lenticular
back screen = fresnel
very front screen = screen protector (you can replace w plexiglass)
the fresnel and lenticular are very specific.. contact your local repair center for a new one. you can cut them from old screens but have to do just right (fresnel is a lens type - pic will be distorted if off center)
maybe find a old junker tv to pull screens from because new ones are about $100 a piece
Jun 03, 2010 | Mitsubishi WS-65311 65" Rear Projection...
I have a cracked screen on my Mitsubishi ws 55313 model. where can I get a new screen? I actually need the screen and the protective screen as well. Thanks, Kris
These parts can be ordered from tritronicsinc.com (use the guest account) using the part numbers and costs below:
Fresnel screen Part number: 491P104030 Cost: $234.08
Lenticular screen Part Num: 491P103030 Cost: $188.21
Hope this helps,
Dan
Feb 08, 2010 | Mitsubishi WS-55807 TV
I have a Magnovox HD TV Progressive Scan (Floor Model) TV
You can find a replacement Philips/Magnavox fresnel screen, in stock, for this model (51MP392H/17) at this following link from a major parts distributor:
Philips / Magnavox 51MP392H Replacement Part Fresnel Screen
And here's a link for the Lenticular (middle) Screen, if needed:
Philips / Magnavox 51MP392H Replacement Part Lenticular Screen
Jan 16, 2009 | Philips Magnavox 9P6034C 60" Rear...
Nov 08, 2008 | Mitsubishi WS-73713 73" Rear Projection...
Help
Please check HERE for front screen of your Hitachi projection tv.
Oct 18, 2008 | Hitachi Televison & Video
My Toshiba 50" Projection TV Model #50A50 screen has a crack in it. How do I replace it? or fix it?
There are two screens involved here, the protective screen (outer) and fresnel screen (inner). You do not indicate which is cracked. I have listed the part numbers and costs from tritrinincsinc.com below:
fresnel screen - part number 23430784 Cost: $133.01
protective screen - part number PS5001 Cost: $162.73 (no longer available)
You can check with local service centers for the protective screen as some may have one around in stock but it is no longer availabel from Toshiba.
Dan
Oct 08, 2008 | Televison & Video
Need to replace a cracked screen
WD-57731 & WD-65731 Front Disassembly
57” & 65” Models Screen Frame
Removal
1) Pull off the Speaker Grill.
2) Remove all the screws (b) from the
upper rear cover (except one at an
upper corner to support the frame).
3) Remove 10 screws (a) from the
front of the screen frame.
4) Remove the remaining ***** (b)
(supporting the frame). Carefully
pull the Screen Frame from the TV
and disconnect the ES and LE
connectors.
57” & 65” Models Screens Removal from Frame
1) From the rear of the Screen Frame remove 20 screws (a) from the top and bottom rails
2) Remove 6 screws (b) from each side rail.
3) Carefully lift the Screen assembly from the Frame.
MODEL: WD-52631 / WD-57731 / WD-65731
Screen Replacement
CAUTION: Wear gloves when handling the Lenticular Screen and Fresnel Lens.
This prevents cuts and finger prints. Do not place Fresnel Lens in the sun.
This may cause fire and heat related injuries.
Lenticular Screen and Fresnel Lens Replacement
1) Apply LENS-TAPE along the rear top edge of the Lenticular Screen.
2) Place the Fresnel Lens on top of the Lenticular Screen, and apply pressure along the top edge.
3) Place the screens in the screen frame and reinstall the cushions, top, bottom and side rails.
NOTE: The Lenticular Screen label must face the front and the Fresnel Lens label face the rear.
4) Reverse the Screen Removal Procedure and insert the screens in the Bezel.
Lenticular Screen and Fresnel Lens Removal
1) Remove the top, bottom and side HOLDER-SCREEN rails and their cushions from the Screen Frame.
2) Lift the screens as a single unit from the frame.
2. Separate the Lenticular Screen and Fresnel Lens.
Note: When separating the Lenticular Screen from the Fresnel Lens, use caution
while prying the Screen and Lens apart. Use a slot type ***** driver, and
remove the pressure sensitive double sided tape.
Mar 11, 2008 | Mitsubishi WD-65731 65" HDTV
Needed Fresnel Screen
What size screen? That model comes in 43,50 52 and 60 inch models.I have a source for the 43 and 50 inch models.
Mar 03, 2008 | Philips Magnavox 9P6034C 60" Rear...
Need a screen cover for 60 inch philip
Hello lcastillo225,
I think that you just called my shop, well in any event what you need to do is to contact the manufacture and order the part from them. The part is called a fresnel screen. Give them the make and model of your set and they will send you the part once you order it, however I would suggest that you get a qualified TV Technician to install the fresnel once you receive it. The cost will be around $150- $350 (average based on industry installation prices) for labor.
I hope this helps,
Thank you,
Shuttle83
Jan 26, 2008 | Philips Magnavox 9P6034C 60" Rear...
Mitsubishi WD-60638 DLP TV Logo
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
