Question about D-Link Dlink DI-514 Air Wireless 2.4 GHz Router (A0177337)
How to create wireless bridge - D-Link Dlink DI-514 Air Wireless 2.4 GHz Router (A0177337)
  • 438 Answers
DD WRT is a firmware upgrade sight you can find wonderful firmware upgrades that make your router come to life and Evan worth more than you payed for your original router, check the router database and see if your router is listed and capable for an upgrade to dd wrt, i did it with my dir615 and it gave me a whole host of additional optins for configurations , it was a long search for "dd wrt" but well worth it.
Posted on Oct 15, 2013
How to connect my TP wireless as a bridge
Here's a very concise walk-through:
http://blog.jeffcosta.com/2011/09/29/create-a-wireless-n-bridge-with-2-inexpensive-tp-link-routers/
If you follow it, step-by-step, you ought to be fine. I've done a bridge using a Linksys E1500.
The only difference is I chose to use different firmware- which I got from the DD-WRT site. That's another option, if your TP-Link is on their approved list of routers.
HTH
Nov 23, 2014 | Computers & Internet
Tip
Do you have a Tivo Premier and are you experiencing wireless communication...
Recenty, I discovered that devices were dropping off of my wireless network (Netgear N300 wireless N with DSL modem). After trial and error, the solution to the wireless communication problems was to create a wireless N bridge using the Tivo Wireless N adapters.
To use this feature, you will need two Tivo wireless N adapters. One wireless N adapter should be set to bridge and plugged into an available ethernet port into your router. The second adapter should be set to client and plugged into the ethernet port in the back of the Tivo Premier. Once the power has been applied to both wireless adapters and the Wireless adapter (connected to the router) has connected to an available address on your router, press and hold the button (on top of each adapter) to establish a secure wireless connection between both adapters.
Once each adapter has established communication, you will have a separate 5Ghz Wi Fi signal (as well as a channel )dedicated to you Tivo devices throughout the house. Each Tivo Premier added to the house should have the wireless N adapter and connected using the secure connection to the wireless bridge by pressing the button on each adapter (the one on the router as well as the one on the Tivo to install).
If sucessfully installed, you should be able to connect to all Tivos on the network for management as well as streaming. If communication between the Tivos isn't successful, you will have to restart each Tivo and establish a new connection to the Tivo service.
Another suggestion when using the wireless N adapters is to setup a static IP address on each Tivo that is higher than the IP address assigned to the wireless adapter. Each Tivo utilized two IP addresses for each device (one for the adapter and one for the Tivo). You may have to check the router administration screen to determine the IP addresses used for the wireless adapters before establishing a static IP address for the Tivos. If you assign static IP addresses to each Tivo, you will have to restart each Tivo and reconnect them to the Tivo service to establish proper network mapping.
With this wireless network configuration, you will ensure that your Tivos are connected to the service using high speed, dedicated wireless N communication for streaming purposes between the services offered while not impacting other computers, servers, video game machines, and tablets that are connected into your house.
Since the Roamio uses a built in wireless adapter, you may not have success in adding a Roamio to the wireless bridge created on your router unless you disable the built in wireless adapter and purchase the external wireless N model from Tivo.
Instructions on setting up wireless bridge can be found at this location:
http://support.tivo.com/app/answers/detail/a_id/1590/kw/wireless%20n%20adapter
on Oct 02, 2013 | Tivo Premiere 4
Tip
Wireless Bridging is used to connect two LAN segments via a wireless link. The...
Wireless Bridging is used to connect two LAN segments via a wireless link. The two segments will be in the same subnet and look like two Ethernet switches connected by a cable to all computers on the subnet. Since the computers are on the same subnet, broadcasts will reach all machines, allowing DHCP clients in one segment to get their addresses from a DHCP server in a different segment. You could use a Wireless Bridge to transparently connect computer(s) in one room to computer(s) in a different room when you could not, or did not want to run an Ethernet cable between the rooms. Contrast this with Client Mode Wireless, where the local wireless device running DD-WRT connects to the remote router as a client, creating two separate subnets. Since the computers within the different subnets cannot see each other directly, this requires the enabling of NAT between the wireless and the wired ports, and setting up port forwarding for the computers behind the local wireless device. Segments connected via Client Mode Wireless cannot share a DHCP server. pictoral In the case in which we are interested, a wireless device running DD-WRT such as a WRT54G is configured as a Wireless Bridge between a remote wireless router (of any make/brand) and the Ethernet ports on the WRT54G.
on Jul 16, 2010 | Computers & Internet
Sonos wont work with Dynamode R-ADSL-C4-W-G1
You have your Sonos bridge hardwired into your Dynamode correct? Your bridge needs to be physically plugged into your router at all times, it creates the SonosNet network that your Sonos players operate on.
Dec 25, 2012 | Computers & Internet
We have a block of IPs from ISP that come into a remote site offering Fiber 8MB Down 2MB Up, rolled down to one allocated port on Cisco Router (ISPs). We have (2) Q-Bridge Wireless Bridges for Point to...
Hello admin620,
This is just a guess based on the given network design information:
The 3 LANS can use a single router at the local site (via NAT) which can be configured as a neighbor to the ISP's cisco router.
If this solution is helpful please click a thumbs-up rating below.
Have a great day,
martyshaw152
Feb 06, 2010 | Connex Q-Bridge Wireless Ethernet Bridge...
How can I change the default management vlan (vlan 1) to another vlan # in Cisco Aironet 1242G wireless AP
create a new vlan (eg vlan 10)
then ensure that the ethernet port is the same bridge group number as the new vlan (bridge-group 10)
do the same for the wireless port
then shut down vlan 1
Oct 06, 2009 | Cisco Aironet 1242ag 802.11a/b/g Wireless...
Trying to create a bridge with two routers
You do not need a bridge if you are using a wireless adaptor on your pc in the other room. Just set up the Belkin Plus router to the WEP security settings you want and make sure the pc wireless usb adaptor has the same settings as the router. You should be good to go. Good Luck.
Jul 15, 2009 | Belkin Wireless G Plus MIMO (F5D9230-4)...
Connect itouch to internet
From what it sounds like, you are working in a Windows environment. What you are trying to do is bridge your wireless ad-hoc network with your wired network connection. Windows does not support this method of connection even though they have the option for "allow other network users to connect through this computer's internet connection". That would only work if you had two ethernet cards in your system, and that option bridges one ethernet port with the other. It doesn't support bridging to your wireless adapter.
Most laptop wireless cards do not support an "infrastructure" mode, which would turn your notebook into a mobile router. Instead they create an ad-hoc network completely separate from your wired network. There are some commercial pieces of software that can bridge the two, though I've never been able to make them work.
The easiest route would be to go to Target or a local electronic store and pick up a wireless router. You would take the ethernet connection from your laptop and attach it to the router. Then your laptop and iPod would both connect to the internet through the router.
Mar 29, 2009 | Apple iPod touch Second Gen (8 GB,...
ZyXEL Ethernet Bridge Won't Connect
the i =ndications are quite clear it's a concern with router's wireless reception...try to reconfig wireless settings on your router change channel to 1 if still the same router is not sending wireless signals properly..
Feb 13, 2008 | Computers & Internet
D-Link Dlink DI-514 Air Wireless 2.4 GHz Router (A0177337) Logo
101 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
