Question about Locks & Locksmithing
Kaba 552 digital lock combination lost how do you override or factory reset
4 Suggested Answers
SOURCE: I lost the instructions to reset the combination for two luggage
I lost the combination lock
Posted on Jul 12, 2009
  • 4 Answers
SOURCE: resetting my master lock
nokia6708
Posted on Jun 15, 2010
flbergeron68
  • 541 Answers
SOURCE: how to reset an open master lock
your answer is on this site
http://www.masterlock.com/faq/lostcombo.shtml
Posted on Jul 05, 2010
Do not no the code to my unican 5 # lock
You will find a link to download the manual for your model on this page:
http://www.kaba-ilco.com/access_control/literature/literature_grid_mechanical_pushbutton_locks.aspx?id=13
Hover your mouse over "PDF" under the "TIPS" column and the two choices of "Changing the Code/Combination" or "How to Reset a Lost or Unknown Combination" will appear--move your mouse over the appropriate one and click to download the info.
These are PDF files, requiring Adobe Reader to open. There is a link on the same page to download Adobe reader, if the file will not display for you.
Aug 01, 2012 | Simplex Kaba Ilco Unican 1000 keyless...
Lost the df-59 key and need to change the combination
For $9 you can get the df-59 key and spanner wrench from this company:
http://www.ckilock.com/Mpage18.asp ,10th item down on page
C.K.I. Wholesale Lock Supply 1-800-445-5230
Their item number SMPBC201278
Hope this helps!
Feb 22, 2012 | Simplex Kaba Ilco Unican 1000 keyless...
Unican keypad door lock reset?
Good luck--and please provide feedback if this helps!
Oct 24, 2011 | Simplex Kaba Ilco Unican 1011 keyless...
I can't remember the code for our 7004/7014 ilco door lock and need to reset it. Can you please instruct me as to how to do this.
I have reviewed the installation instructions and in the case of a lost combination, Kaba Ilco recommends that you call their technical service department:
"This is a lost combination situation.
Please call our Technical Service Dept.
For further information at (800) 849-8324
or (336) 725-1331."
They are located in North Carolina, so the best time to call is probably during east coast business hours.
Aug 24, 2011 | Simplex Kaba Ilco Unican 1000 keyless...
Need to change lock code on a gun safe
In the case of a lost combination, Kaba Ilco recommends that you call their technical service department:
or (336) 725-1331."
Jun 01, 2011 | Simplex Kaba Ilco Unican 1000 keyless...
WE HAVE THIS LOCK INSTALLED AND IT HAS THE TYPICAL FACTORY SETTING CODE (2/4 THEN 3). WE DON'T KNOW HOW TO CHANGE IT! HELP
Customer service can be contacted from this link:
http://www.kaba-ilco.com/access_control/support_contacts/service_and_support.aspx
Tech Support from this link:
http://www.kaba-ilco.com/access_control/support_contacts/technical_support.aspx
Jan 06, 2011 | Simplex Kaba Ilco Unican LP1000...
I tried to change the code on a 1000 series lock and now I can't get any code to work
You have probably inadvertently created a lost combination situation. In the case of a lost combination, Kaba Ilco recommends that you call their technical service department:
or (336) 725-1331."
Dec 03, 2010 | Simplex Kaba Ilco Unican 1000 keyless...
Lock failure where can i get these repaired cheap.
Nov 19, 2010 | Simplex Kaba Ilco Unican 1000 keyless...
Reset combation without a combation kaba
I found this instruction elsewhere on this site ( thanks to pctuneup191):
PROCEDURES TO CHANGE THE COMBINATION OF SIMPLEX 1000 SERIES CIPHER LOCKS
1.) ENSURE THE DOOR IS OPEN.
2.) INSERT THE DF-59 CONTROL KEY INTO THE COMBINATION CHANGE PLUG ASSEMBLY (ON THE BACK OF THE
DOOR) AND UNSCREW THE CYLINDER BY TURNING THE KEY COUNTERCLOCKWISE.
3.) TAKE THE CHANGE PLUG ASSEMBLY COMPLETELY OUT OF THE DOOR.
4.) TURN THE OUTSIDE DOOR KNOB CLOCKWISE ALL THE WAY UNTIL IT STOPS, THEN RELEASE THE KNOB.
5.) PRESS IN THE EXISTING COMBINATION FIRMLY.
6.) INSERT THE SPANNER WRENCH IN THE COMBINATION CHANGE SLEEVE. IT SHOULD INSERT AT THE NINE
O'CLOCK POSITION.
7.) TURN THE SPANNER WRENCH GENTLY CLOCKWISE UNTIL IT STOPS AT THE 12 O'CLOCK POSITION. NOTE
THE NOTCHES IN THE COMBINATION CHANGE SLEEVE MOVES AS THE SLEEVE IS MOVED.
8.) TURN THE SPANNER WRENCH COUNTERCLOCKWISE BACK TO THE NINE O'CLOCK POSITION UNTIL IT STOPS.
REMOVE THE SPANNER WRENCH.
9.) TURN THE OUTSIDE DOOR KNOB CLOCKWISE (ALL THE WAY, UNTIL IT STOPS), THEN RELEASE.
10.) INSERT THE NEW COMBINATION BY PRESSING IN THE BUTTONS. USE AT LEAST three numbers and a
maximum of five.
11.) TURN THE DOOR KNOB CLOCKWISE ONCE, ALL THE WAY, UNTIL IT STOPS. HOLD IN THIS POSITION AND
CHECK IF THE LATCH IS RETRACTED.
12.) RELEASE THE DOOR KNOB.
13.) TURN THE DOOR KNOB CLOCKWISE ONE MORE TIME TO THE STOP POSITION. AT THIS POINT, THE LATCH
SHOULD NOT RETRACT UNLESS YOU USE THE NEW COMBINATION.
14.) REINSERT THE CYLINDER INTO THE BACK OF THE DOOR BY SCREWING IT IN CLOCKWISE WITH THE DF-59
CONTROL KEY (DO NOT OVERTIGHTEN!)
REMOVE THE KEY.
A Df-59 key can be purchased at this site:
http://absupply.net/kaba-access-control-lock-1000-series-key-df59.aspx
The spanner wrench (SMPBC201278 Simplex:SpannerWrench $9.00) referred to can be purchased from this site:
These are PDF files, requiring Adobe Reader to open. There is a link on the same page to download Adobe reader.
Sep 29, 2010 | Simplex Kaba Ilco Unican 1011 keyless...
Locks & Locksmithing Logo
61 people viewed this question
Top Locks & Locksmithing Experts
ray gallant
Tom Chichester
Are you a Lock and Locksmithing Expert? Answer questions, earn points and help others
