Question about Rheem Water Heaters
Can't find drain plug - Rheem Water Heaters
    Master:
  • 452 Answers
It will b lower down near the bottom
Posted on Oct 12, 2013
How do I drain the Kwikot 600 dual geyser to replace the element
If the design is typical, there should be a drain valve at the bottom. There could be simply a plug that has to be removed for draining.
Jun 27, 2016 | Water Heaters
Drain plug frozen, how to unfreese it. GI6FARXXQ00
I'm not sure which drain plug you mean, but a hair dryer is the safest way to thaw it out. Unless you can unplug it for a day or 2 and let it thaw on it's own [usually not feasible]
Nov 16, 2014 | Whirlpool Gold GI6FARXXQ 25.5 cu. ft....
Nylon drain plug broke off and inside drain hole. how to remove//
OHHH BOY! Been there, done that many times. I've seen guys try chiseling away at it, ( not recommended) or use a hacksaw blade to cut it down to the threads of tank carefully, then pry and dig near cut to get it to fold up and needle nose pliers to grab it and pull it out in 2 pieces. You will feel the difference between cutting the nylon plug and when you start hitting the aluminum threads of tank, stop there. Best thing I've found, is I have a slightly tapered half round file just narrow enough at end to go into tank and plug about an inch or 2 before it comes up against the broken plug. Then I tap it in good until I feel it starting to bind against metal threads through nylon plug. Then I simply take a pair of pliers or an adjustable wrench, over the file and turn it out. The straight edge of the file jambs in against the nylon plug and walks it out. Good Luck
Mar 31, 2011 | RTO Atwood Water Heater - 6 Gal LP
My 6gallons atwwod water heater stop working. the drain plug had 2 wires coming from it. what are they for
"BEWARE OF ELECTRICAL SHOCK HAZARD"!! Wires coming from a drain plug would indicate to me that someone has used a "hot rod" type element in the water heater. They are an aftermarket heating element, that would be plugged in somewhere, (usually inside to a receptacle) that would supply 120 VAC (hydro) to it. BE REAL CAREFUL THAT THOSE WIRES AREN'T LIVE.!! Go in trailer and access rear of water heater if that's where the wires appear to be going and make sure it's not plugged in somewhere. When you removed it, was it similar to a round rod , or just a plug?
Jan 10, 2011 | RTO Atwood Water Heater - 6 Gal LP
I cannot get my water heater to drain, opened valves did everthing I'm suppose to Help?
the bottom is plugged with calcium deposits and is blocking the drain valve at the bottom,try using a small wire to dislodge the blockage from there or try hooking up a water supply and forcing the blockage backward,if your just removing the whole unit,then you can lay it on its side and let it drain from the top fill ports
Jan 06, 2011 | Rheem 50 GAL ELEC TALL Water Heater 6YR SC...
I have a GE smartwater reverse osmosis system model number GXRM10GBL02. Water leaks daily from the small hole on the faucet on my counter top. Any idea why water comes out that small hole? Otherwise the...
That is the drain for the reverse osmosis system. You have what is referred to as an AIR GAP faucet. The waste water is pushed up there before it goes to drain just as the drain for a dishwasher does. If water is coming out of the faucet the drain is most likely plugged or the line is kinked causing water to back up and overflow. Check the drain line for kinks and clean out the drain where it attaches to the stand pipe.
RJ
Oct 22, 2010 | General Electric GE SmartWater Household...
Is it feasible to un-screw the drain on the Rheem 50 water heater without it breaking off inside? I want to drain my tank but the drain valve is clogged and I cannot clean it as it is a right angle hose...
POWER OFF ..ya i think its plastic so if it does break you can picj it out with a screw driver and A HACKSAW BLADE. then go buy a brass plug or a new valve.. a ball valve would be nice.. did you know that you shold drain the tank EVERY YEAR ! AND SHUT THE POWER OFF
if i was of help please tell me.. tahks ..jay
Sep 12, 2010 | Rheem Water Heater Drain Valve
How to remove the water filter in Noritz
it's just a cup screen,, when you take off the cap screw you pull it out claen i and put it back,, it is on the cold side only right before the unit connection
Jun 22, 2009 | Noritz 6.9 Gallon Residential Direct Vent...
Water Heaters Logo
13 people viewed this question
Top Rheem Water Heaters Experts
Donni Steen
gizmonix
Level 1 Expert
Are you a Rheem Water Heater Expert? Answer questions, earn points and help others
