Measuring Tools & Sensors Logo
j
jeff Vandy Posted on Oct 12, 2013
Kobalt KL-12120 display shows 1.8.8.8 and doesn't work
I have a. 80. Volt Kobalt leaf blower that has a bad trigger that needs to be replaced,where can I buy one? Azteca
You can purchase a replacement trigger for your leaf blower from the Kobalt parts website . Alternatively, you can call their customer service department at 1-888-3KOBALT (1-888-356-2258) to order the part over the phone.
Where can I get a plastic lower guard replacement for a 10 inch sliding compound miter saw kobalt brand?
Hello, John -
I am not finding a replacement lower guard for your model of Kobalt miter saw for sale online.
In the owner's manual for the Kobalt miter saw model SM2507LW (Kobalt is owned by Lowe's), I found the following information on the last page (page 50):
(Quote)
For replacement parts, call our customer service department at 1-888-3KOBALT (1-888-356-2258)
(End quote)
Source:
http://pdf.lowes.com/useandcareguides/000999312085_use.pdf
Note: All the parts and their part numbers are listed in the owner's manual: pages 41-48.
Therefore, I suggest you call the Kobalt Customer Service number and ask about the availability of the needed part. From the Kobalt Contact Us information, Customer Service is available Monday - Friday, 8:00 am - 5:00 pm (Eastern Time.)
Best wishes,
Dec 01, 2018 • Saws
Where can I access a digital version user manual for the kobalt 24v max lithium ion battery charger
Call Kobalt to request it:
1-888-3KOBALT (1-888-356-2258), 8 a.m. - 8 p.m., EST,
Monday - Friday
Jun 17, 2018 • Drills
I need the spool cover for my Kobalt trimmer
The Kobalt brand is sold at Lowes. Although there are several other companies' trimmer covers sold there, I have no idea if any could substitute. Here is the phone number for Kobalt Tools, the manufacturer. Perhaps they can assist.
  • 1-888-3KOBALT
  • (1-888-356-2258)
  • Monday - Friday
  • 8:00AM - 5:00PM EST
KOBALT
Jun 08, 2017 • Garden
I have a Kobalt 10 gal, 1.5 hp air compressor. It has a digital display. It does not show anything in the display and keeps running until relief valve pops. I tried to find a new pressure switch but no...
Abandon the display and install a generic pressure switch at a convenient port. Example. Remove the safety valve and install a tee fitting. Re-install the safety on one port of the tee and a pressure switch on the second port. Generic pressure switch on Ebay is about $15 dollars. The pressure switch usually has other ports to install gauge and quick fittings. Will not look pretty but will work nicely. Good luck
Dosnt work
If display is scrambled, reset timer: Push reset button while holding down enter button.
If display doesn't show, check AAA batteries.
If timer still doesn't work, then Contact Intermatic.
8000 series comes with 1 year limited warranty
https://parts.intermatic.com/
Intermatic does not show replacement memory board for ET8000 series
Upvote the help.
And take advantage of fixya expert assistance live.
For a price, expert works with you while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
I need a kobalt hvlp spray gun manual where can i get one?
Go back to where you bought it and have them photocopy the book from another unit. Good luck!
3answers
Kobalt air compressor won't run
hi mate take the head off and inspect the valves and gaskets i had this problem and it was the gaskets gone just make sure the valves are opening and closing ok good luck
Top Measuring Tools & Sensors Experts
Steve Pack
Steve Pack
ADMIN Andrew
ADMIN Andrew
Are you a Measuring Tool and Sensor Expert? Answer questions, earn points and help others
