Question about Garden
Have a Poulan weedeater. Can't start it, started once early in the year but it quit. It's a couple years old but hasn't been used all that often. Pull the rope & nothing happens. Model PPB 250E. Hubby want's to ditch it but I don't want to spend money on a new one. Help.
    Sergeant:
  • 322 Answers
Check the diaphragm in the carburetor. I am willing to bet it is dried out and stiff so it won't supply fuel. an easy way to check is to put a small amount of gas right into the carb and try starting it. it should run on the fuel you put in then die once it is gone. if it does then it is most likely carburetor trouble, if it doesn't run then it is probably a spark issue
Posted on Oct 17, 2013
  • 14 Answers
SOURCE: Chainsaw pull cord won't pull to start
Simply check to see if motor is locked is to remove spark plug and try to pull start. If motor turns, then he may have gotten gas in cylinder and created hydraulic lock. If moto does not turn, it is just a few screws more to take side cover off and see if rope caught in pully. In fact, you may want to take side cover off first, and make sure rope pulls out of housing, and self winds, like it should. At hat point, he can simple turn flywheel by hand to see if motor is locked up.
If the motor is locked up, you can put small amount of motor oil, (half a tea spoon) into spark plug hole, let it sit half an hour or so, and then try to work the flywheel back and forth to break it free. This condition may have been caused by running straight gas, not mixed. And, even if motor frees up, it may still need to go in for repair.
We have a couple of Poulin Pros at this saw mill where I work, and have had the piston lock up more than once, from guys dumping in straight gas. Sometimes we'ra able to free up piston, and make saw run again. And sometimes we end up tearing it down and repairing piston ring. Good Luck
Posted on Nov 19, 2008
  • 11 Answers
SOURCE: Chainsaw won't start. Can't pull starting cord out
Thats a little strange.
Only thing that comes to mind is someone else had access to it and swapped out a plug that is too long for your short plug, Check plug type in owners manual.
maybe on sunday their 4 wheeler wouldn't start and this was quick fix.
Take off the chain cover or starter and see if it turns back and forth almost one full turn with a sudden stop at both ends of rotation. (Hitting plug)
if this is ok get back to me.
Bill
Posted on Feb 26, 2009
  • 3 Answers
Try replacing the muffler. The baffle or something inside the muffler may be loose and when compression is put on the cylinder from pulling starter rope to crank over engine it will cause baffle to move over and seal off muffler leaving nowhere for compression to go. When the sparkplug is removed this allows an outlet for compression when starter rope is pulled. Hope this helps
Posted on May 09, 2009
steve_lima
  • 181 Answers
SOURCE: HUSQVARNA model 435 Difficult starting
the problem is in the ignition coil.it needs to be replaced.it is under warranty.its warranty is life time.call husqvarna and they will either send you a new one or send you to a husqvarna dealer to fix the problem.that is at no cost to you..............let me know if this helped.................
Posted on Jun 06, 2009
jimboz4
  • 305 Answers
SOURCE: Starter rope will not retract.
inside the rope pull housing is a flat spring,it may have come loose from its anchor, its an easy fix...unscrew the 3 screws on housing, lift off housing, and the rope pull is inside the casing, you will then see if its broken, or just come off anchor, 10 minute job if its just loose......
Posted on Jul 21, 2009
My Poulan Weedeater will not start. About 10 years old. The bulb does not seem to be sucking gas upinto the carb.
The primer bulbs do eventually fail. Judging by the age it looks like yours has, it will need to be replaced.
Jul 08, 2011 | Poulan Garden
Poulan 33cc Weedeater 3 mo old will not idle, dies during acceleration
Sounds like you will need to clean your carburetor.
Be sure to use compressed air to blow out all the fuel and air passages.
Sometimes you can get by with priming the carburetor a few times, and letting it run a few times like that and it will flush the gunk out of the jets,but most of the time you will need to rebuild the carburetor.
If the mower/weedeater is over a couple years old, then I also recommend that you buy and install a new carburetor repair kit,because the diaphragm will get hard and that will cause it to be hard to crank.
When you clean your carburetor and remove the jet screws, You will first seat the jet screws and count the number of turns it takes to seat the jets from their original position.
That way when you go to put the jets back in, you know how many turns they were in/out.
Please rate me
Aug 23, 2010 | Poulan/Weed Eater No. Te475 952711797 17"...
I have old poulan weedeater featherlite grass trimmer. wasn't used for many years. I replaced lines and bulb which were dried out and cracked. opened up & cleaned up carb -gaskets seemed to be in...
Did you check for spark? Try starting fluid to see if you could at least get a hic cup? Almost sure that your issue is carb related and you may have to replace it if it is not an ignition problem.
Sep 19, 2017 | Poulan Garden
One year old Poulan weedeater starts right up but will only run with choke about half way on. Warm it up that way but it does not run any better. New gas, new spark plug, clean air filter. The weedeater...
CHECK THE SCREEN ON OUTPUT OF THE MUFFLER. ITS CALLED A SPARK ARRESTOR, THESE GET OIL FOULED AND MAKE EM A BEAR TO RUN . CLEAN IT UP AND SHE WILL RUN LIKE A CHAMP, THE CARB MIGHT NEED REBUILDING ,FUEL FILTER AND A SPARK PLUG IS THE FIRST THING TO REPLACE .. IF'N I WAS ANY HELP VOTE FOR ME ...THANKS.. JAY
May 25, 2010 | Poulan/Weed Eater No. Bvm200le 711482 24cc...
Weedeater starts and immediately shuts off. I checked the fuel filter and replaced the plug the unit is 1 year old.
Change gas, and spray out carb passages. If you tampered with the mix screws then its a whole nother story!
May 05, 2010 | Poulan/Weed Eater No. Te475 952711797 17"...
Doesn't seem to be getting gas. Gas in spark plug
your carburetor needs to be rebuilt. It has thin diaphragms that get hard after a couple of years, sooner in hot climates. Also check your fuel lines for cracking.
Feb 01, 2010 | Poulan Genuine Weedeater Part # 36006-128
Weedeater very hard starting or not starting at all
One of two solutions. But the only thing wrong is the carburetor. It needs cleaned or it needs a new carb. kit. If you need tips on how to clean, just let me know.
Jim
May 30, 2009 | Poulan Garden
Poulan weedeater will only run with choke half way on
this could one or a combination of a few things
1 check inside the tank for dirt 2check that the filter screen inside the tank is not plugged3 make sure the gas feed tube is not restricted pinched in the case or kinked also you can try a simple carb adjustment.also check to make sure the plug is gapped to the right specs good luck and i hope one of these suggestions do the trick
May 02, 2009 | Poulan/Weed Eater No. Bvm200le 711482 24cc...
Garden Logo
Top Garden Experts
Dennis Key
Dennis Key
john h
