Question about ViewSonic NX1932W LCD Monitor
My ViewSonic NX1932W LCD Monitor was being used as a computer monitor. It stopped working with the power button displaying the amber color. If I hold the power button it will flash blue and return to amber. Also I can't determine how to remove the back cover to see if a cap, resistor, fuse or something is burned up. Help Please!!!
  • 89 Answers
These monitors are tightly held in place by clips. After removing all the necessary screws, use somehing like a credit card to pry open the lid. Just need to be careful not to crack the case, or your hand.
Posted on Nov 20, 2013
3 Suggested Answers
Riziel
  • 116 Answers
SOURCE: LCD Monitor has no video
Sounds your monitor has either blown a backlight or the inverter board is bad. Either way they can both be replaced, but tracking down the parts will be a bit difficult. But your LCD Monitor is in trouble! Sorry!
Posted on Nov 26, 2007
cashmerekay
SOURCE: Viewsonic VE175b Monitor Powers Up Doesn't Display Windows OS
Hi; I had the same problem. I know that sometimes devices require you to perform some type of '10-30 second' "hold" of one or some of its buttons in order to 'reset' the device, so to speak. So, having said that, try this:
1) Turn your monitor off (no green light) but leave it plugged in.
2) Leave it off for about 10 seconds.
3) Hold the [2] button on your monitor (the one to the immediate LEFT of your monitor's POWER button).
4) While holding the [2] button, now press and HOLD your POWER button.
5) Wait for your image to appear and STAY onscreen for about 5 seconds, then release both buttons.
6) Your monitor should retain its onscreen image.
Hope this helps! Good Day to all!
Kelvin W.
Posted on Dec 18, 2008
Have a nx1932w; worked fine until this morning; turn on the monitor (using it as tv) the logo is in black and white and it says no signal - can't even get menu button to work.
the most common problem with LCDs today is failing electrolytic capacitors, especially in the power supply section. Look for bulging, leaking, blown or missing capacitors and replace them.
May 17, 2012 | ViewSonic NX1932W LCD Monitor
My monitor dont come on, and green light flashng, viewsonic vp930b.
If your ViewSonic LCD monitor has stopped working with a blinking green power button, It typically means that there is one or more failed capacitors in the monitor. It would be best to send the monitor in to Viewsonic for service or to purchase a new monitor.
Mar 11, 2011 | ViewSonic VP930b 19" LCD Monitor
Have had the nx1932w for 4 years. turned on this morning and it only shows a blue screen with message stating no signal. have digital cable and all other tv's in the house work. please advise.. thank you
If the ViewSonic logo first comes on followed with no signal the monitor is okay, check the video cable connection between the monitor and the computer, if okay the video graphic's card may be the problem,or the motherboard, but this is speculation you will need somebody to check the system for exact cause.
Jan 01, 2011 | ViewSonic NX1932W LCD Monitor
No video.dual monitor set up. power button briefly goes from amber to green and then off.
after connecting external monitor see on the bar click on the displays symbol the select extended desktop or multiple display then you can see but if no display then restart the computer and go to setup by pressing del key and disable internal monitor and enable external monitor then you can see dual display .windows98 and old versions does not support dual display windowsXP and lates versions support dual display
Mar 12, 2010 | ViewSonic VA1930WM LCD Monitor
Viewsonic VP930b color problem - Red tint
Go to the setup menu on the LCD panel by pressing button 1 on the front. See if there is an option to reset the lcd to factory settings. Reset it and report if it helps not.
Jul 29, 2009 | ViewSonic VP930b 19" LCD Monitor
Hp L1502 LCD blank, LED still flashes
just check ur lcd display cable and try to clean and c it it will cme
May 29, 2009 | Samsung SyncMaster 910T 19" LCD Monitor
Viewsonic lcd tv 37"
try to check the RAM, video card, or processor maybe it is not properly inserted to the slot.
Jan 08, 2009 | ViewSonic A90f+ 19" CRT Monitor
Kelvin W.
Dec 04, 2008 | ViewSonic VE175b 17" LCD Monitor
No display (black) - power light is amber color
The video signal is not reaching your monitor, check the pins on the connector from the monitor to the computer, then check the video card:
Turn off your computer, unplg the power, and then take out the video card. Wait 5 minutes and then put the card back into the computer and turn it on. For onboard video; turn off the computer, unplug the power, then hold down the power button on the front for 5-10 seconds, then plug back in and turn on.
Make sure the video card is snug in the AGP/PCI slot. If this is built-in video, try borrowing a video card from another computer and install it in this one. If the borrowed card works, then replace you card. If video is built in, then you can disble the onboard video and use the new card without having to replace your motherboard.
Jul 14, 2008 | ViewSonic VX910 19" LCD Monitor
Blinking power button
It could also be because there is a problem with the display controller in the computer. Try to hook up another monitor to this computer and see if it comes up. If it does not work with another monitor, the computer will need servicing. If the display does come up, the Samsung monitor will need service. Good Luck
Jun 20, 2007 | Samsung SyncMaster 170 T 17 in. Flat Panel...
ViewSonic NX1932W LCD Monitor Logo
88 people viewed this question
Top ViewSonic Computers & Internet Experts
Are you a ViewSonic Computer and Internet Expert? Answer questions, earn points and help others
