Question about Maytag Refrigerators
Maytag model MF12569VEQ1
Water drains into freezer compartment instead of drip pan. What do I need to do to correct the problem.
    Scholar:
  • 50 Answers
Dick,
Odds are your drain line is clogged. Often it is ice that is the clog. Here is what ya do: Empty the Freezer and unplug the refrigerator. Get a hair dryer and after removing the ice on the floor of the freezer and drying the bottom of freezer prop the hair dryer up inside a glass or ceramic (insulating) casserole dish pointed at the back bottom of freezer. Put hair dryer on hi and close the door. After about an hour (as you check in on it every ten min\'s) look for water dripping from the drain line into pan. If need be, use a shop vac to blow in from the top and draw (suck) on the drain tube at bottom. I bet this fixes it. Plug frig back in and observe over next week or so.
Posted on Oct 12, 2013
  • 1073 Answers
SOURCE: Maytag side by side refridgerator
the drain tube is clogged or maybe frozen, remove the restriction and you will have no more problem
Posted on Apr 10, 2008
SOURCE: Bottom of freezer has water dripping into it
We had a similar problem. It ended up being a frozen pea that fell down into the defrost drain and was blocking the water from draining out each time the freezer defrosted.
Posted on Aug 23, 2008
  • 51 Answers
SOURCE: water drains from freezer compartment into refridgerator
If the freezer is on top then empty out the freezer and remove the bottom and back liner of the freezer compartment usually phillips screws. In the back you will see the freezer coils along with a defrost element. Below these two items u will see a drip tray that collects water from the coils on defrost cycle, in the center of the pan will be a drain hole that connects to a hose that leads to a pan under the refrigerator.Normally the water is collected there and evaporated. The hole in the tray in the freezer is clogged. Thaw it and clean it until you can pour water in it and it goes to the pan down below. please rate me
Posted on Jan 09, 2009
Maytag317
  • 1136 Answers
SOURCE: Water is dripping from the freezer into the refrigerator
Hi, The defrost drain behind the rear freezer panel is plugged. Remove the rear panel and clear the ice away from the drain. Then you will need to flush the drain hole with hot water to make sure it is open.
Some models require an after market drain heat kit.
Please get me your model # and I can look this up to let you know if you need that heat kit.
Thanks
Vic
Posted on Jul 11, 2009
SOURCE: water dripping from freezer onto top shelf of fridge with ice buildup back of freezer
the defroster isn't close enough to the drain to be effective. remove the back wall of the inside of the freezer, remove the excess ice. clear out the ice from the drain using hot water and a turkey baster. there is a kit from whirlpool that uses a piece of metal and a screw around the defrost rod, but I found out that a piece of 14 gauge solid core wire with the insulation stripped off works great too. stick the stripped wire into the drain, 2 to 3 inches, and wrap the rest around the defrost rod.
Posted on Jan 04, 2010
I have a top freezer/bottom refrigerator-6months old-no icemaker hooked up. There is water dripping continuously into the refrigerator compartment-some of it freezes and the rest accumulates in the...
That water is from the melting frost of the automatic defrost cycle. Their is drain in the freezer behind the back wall under the evaperator coil that is blocked, so instead of defrost water draining it's pooling in the freezer or in some case espically on models with the freezer on the top,the water is leaking from the freezer vents into the fresh food compartment.
The way to clear the drain is remove back plate and remove all ice build up and GENTLY make a small hole in drain through then totally flush w/warm water.
The exact location of drain is under the coil behind back freezer plate in the center
Good luck
I hope this helps
Gene
Aug 17, 2011 | Maytag 21.7 Cu. Ft. Top-Mount Refrigerator...
Condensate dripping from the freezer through the openings in the top of the refrigerator ( behind the light). Do i need to defrost? Also get some water that sits in the bottom of the freezer.
It sounds to me like your refrig. is defrosting as it's suppose to automatically but the drain in the freezer is blocked so instead of the defrost water water running through the drain to the pan in the bottom of refrig, where it evaperates and you don't need to empty the pan,instead of that since freezer drain is blocked so the water is running into the fresh food compartment.
Jul 30, 2011 | Roper RT21SKXLQ Top Freezer Refrigerator
What a mess. The instruction manual (really lacking in detail) does not have part numbers or model description. Excess moisture dripping in refirgeration portion of unit (top freezer; bottom...
Yes it could, you will have to check your defrost water drain, if its plugged defrost water won't go to condensate pan under unit, instead will make its way down to refrigerator section
Jun 29, 2011 | Maytag Refrigerators
Does model# msd2652keu have a drain pan or not. can't find one. serial# 50909406ll
Hi, There is a hole in the lower back of the freezer compartment that carries the water to the drip pan when the fridge goes through the defrost cycle. Water on the floor means that hole is plugged and the water seeps through the doors. See the owner's manual - it will describe this issue. The fix is to have the blockage removed by squirting a solution of hot water and baking sode with a turkey baster or a similar injector.
The solution needs to be injected into that plugged hole. When the water from the injector starts going down (into the drip pan at the back) instead of coming back up, the blockage is removed and the problem should be solved.forgot to clarify that the solution needs to be injected into that plugged hole. When the water from the injector starts going down (into the drip pan at the back) instead of coming back up, the blockage is removed and the problem should be solved.
Take care.
May 26, 2011 | Maytage MSD2652KE 26 cu. ft. Side-By-Side...
Maytag MZZD2766GE side by side refrigerator: Water collects and freezes on the floor inside the freezer. Then apparently some of the ice defrosts as I get water on the kitchen floor under the...
Hi and welcome to FixYa, I am Kelly.
This is caused by a clogged evaporator drain that is item 5 of this link:
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=47966
It can be clogged either in the funnel area or at the end of the tube underneath the refrigerator.
Item 5 catches water from item 14 this link:
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=47966&diagram_id=28494316#d28494316
Your evaporator drain is clogged. (how to clear it)
  • Unplug the unit remove the freezer contents and do a manual defrost by directing an external fan at the freezer compartment for just over 2 hours. (Makes a water mess so be prepaired) This is a must do!
  • Remove the rear fiber-board compressor and condensor coil cover and locate the compartment drain tube in the drip pan. Make sure the end of the tube is NOT blocked. Clean as necessary.
  • After the 2 hour period... use vacuum forced air OUT pressure on the end of the drain hose in the drip pan. Have a 2nd person listen for airflow in the freezer compartment. This will float out any debris from the compartment drain funnel.
  • Clean the condensor coils and fan while the unit is unplugged but do NOT use anything sharp.
If you can not get air-flow up through the compartment drain funnel underneath the evaporator coils you will have to remove the access panel and remove the debris from the drain funnel.
Return the unit to normal service after cleaning. Watch for more ice build up after a week. No ice blocks after a week... no worries. Ice under the ice-maker... replace the inlet water valve due to it bypassing water when in the OFF mode.
Thanks for choosing FixYa,
Kelly
Mar 01, 2011 | Maytag MZD2766GES Side by Side...
Ice in the bottom of the freezer
Ok here is a generic response without a model number.
One of 2 things have happened. Either the inlet water valve to the icemaker has failed as noted by ice blocks in the ice bin or
If you need model specific information.... I need your exact make and model number in any response.
Kelly
Feb 19, 2011 | Maytag 25.6 Cu. Ft. Side-by-Side...
Maytag fridge water dripping from inside freezer side
This sounds like the evaporator drain may be clogged either in the freexer compartment or at the outlet to the drain pan under the unit. Every defrost cycle the defrost element makes water by melting the ice on the evaporator coils. If the drain is clogged there is no other place for the ice to go. Many times the drain may just have ice buildup in the evaporator drain funnel that can be corrected with a manual defrosting.
To do this manual defrosting all you do is first unplug the unit then remove everything from the freezer compartment. After that place a fan blowing into the freezer section for a little over 2 hours. Please NOTE this will make more of that pesky water mess so be ready to tend to the mess as it presents itself.
After the 2 hour fan session plug the unit back in and reload the freezer compartment with previous content. Monitor for the possibility of the water manifeting itself again.
In addidtion to the above there is a drain pan catch basin in the bottom of the unit near the compressor. They are usually white plastic on Maytag units and not to rugged. Make sure that the drain pan is not loaded with debris. There is about a 1/2 inch diameter opaque plastic line that drains into the catch basin. That is the Evaporator darin tube. Ensure the very end of the tube does not have caked up debris in the very end of the tube. Sometimes this tube cakes up and then the debris dries hard inside the tube near the end. Make sure the tube is free of foreign objects and clean.
After all of the above / cleaning and clearing / manual defrosting it is still making water then most likely the lower panel under the defrosting element / evaporator may have become disconnected allowing defrost cycle water from the melted ice into the freezer compartment vs exit via the drain. To fix the disconnected power metal panel problem the rear freezer panel would have to removed to re-attach / repair the metal panel that guides the water into the evaporator drain.
Thanks for using FixYa.
Kelly
Mar 26, 2010 | Maytag 25.6 cu. ft. Wide-By-Side...
Water is dripping from the freezer into the refrigerator compartment and pooling up in the various drawers/bins.. The drip pan underneath is completely dry.
Thanks
Vic
Jul 11, 2009 | Whirlpool 21.0 cu. ft. Top Freezer...
Drain pan leaking?
there is a drip pan located underneath you ref but most likely your prob is a plugged drain line coming from the freezer. when you ref goes into automatic def the water doesnt run out into the drip pan but instead onto your floor..
you can clean the drain line by removing the rear cover in the freezer compartment and using hot water to thaw the drain below the evap coil.
Dec 08, 2007 | KitchenAid Superba Architect KSCS25INSS...
Refrigerators Logo
89 people viewed this question
Top Maytag Refrigerators Experts
Bailey's...
Bailey's...
Shehu Pro
Shehu Pro
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
