0276,0274,0277,0273. Check these codes. If you wish to get more details, check the sites linked here. Setup code list, and setup procedure to many popular brand remote controls are given. http://electrohelponline.blogspot.com/ http://remotesearch.blogspot.com/ Selecting the view option, either to Mosaic / Time slide, can be selected by the drop-down list, at the top left of the display window, will make surf easy.
SOURCE: my one for all won't program...
dish network remotes are universal, you can program your receiver, vcr/dvd, telivision and stereo to most remotes. if you need info on this just post again, otherwise i would list your issue under the remote brand
SOURCE: dish network remote with a element tv
Since you dont have a popular brand set you should try using the scan method. Here is a link with a video to help program your dishnetwork remote to work with your set. http://www.disheez.com/videos/dish-network-video/programming-dish-network-remote/
SOURCE: how do you set the Dish network 1.5 IR remote with toshiba tv.
You didn't mention which model of TV you have but if you dont have the manual for the Dish remote, you can retrieve the codes from their website which would be more current anyhow.
You may not find a codes setting that agrees with your TV if it is a recent acquisition since the manufacturers are changing their codes all the time.
You may be able to find one that at least controls some of the Toshiba's functions but don't expect too much.
Experience tells me that if you can do at least power and volume control, be happy.
This is no, and never will be, a truly 'universal' remote.
SOURCE: Dish Network IR Remote's SAT Mode Not Working ____
Hello, this is Nick Franta with DISH.
If you are trying to get the remote programmed to the receiver you can remove the smartcard from the receiver and that will prompt the system info screen. This will allow you to program the remote to the receiver.
If you need the process for programming the remote, here it is:
Hope this helps!
