Question about Frigidaire 20.3 Cu. Ft. Frost-Free Upright Freezer - White
Door ajar light lit with door closed - Frigidaire 20.3 Cu. Ft. Frost-Free Upright Freezer - White
  • Official Brand Answer
  • 4,342 Answers
Good Afternoon Don, thank you for allowing me to assist you!
Did the unit previously experience a power loss? If the temperature of food rises to an unsafe level, the red light will glow. First, deactivate the alarm to the unit by unplugging it or flipping the household circuit breaker. Wait approximately ten minutes and then turn on the unit. After deactivating the alarm and the unit has run approximately four hours, the red light/alarm should go off on its own. If the red light/alarm continues to stay on, the freezer may possibly have a communication problem with the control board, temperature control or a wiring harness. If this is the case, I would recommend connecting with an experienced technician to determine the underlying cause.
Posted on Oct 14, 2013
  • 389 Answers
SOURCE: Frigidaire 17 CF upright freezer. We are getting
It could be the button that the door hits on when you close the door. If you can take it out and clean the connections it may do the trick. If it really bugs you then you can twist the two wires to gether and it should fix the warning. This means the button switch may have went bad but if you know the door is closed who needs the annoying warning. Please leave a thumbs up. I can only try for you from way out here in the Raz Shack
Posted on Apr 21, 2010
woodchuck789
  • 4059 Answers
SOURCE: alarm on door keeps peeping red
The door switch which senses when the door is ajar needs to be replaced or cleaned. See if you can make the alarm go off by pushing the switch in as far as it will go or take the switch out and by pass it by taping the wires together. There's a sensor switch for each door so try each one separately.
Posted on Feb 12, 2011
  • 160 Answers
SOURCE: door was not sealed tightly
The door seal has a magnetic property to it. Until the freezer gets to a certain degree the magnetic porperties of the door seal dont react properly. Make sure the door seal is properly adjusted. If the door was left open it could have semi warped the door. This gets corrected when temp drops to correct temp. Reset freezer by unplugging and waiting for a few minutes. If problem persist contact appliance technician.
If you have any more questions you can comment me back.
Posted on Jul 28, 2011
  • 551 Answers
SOURCE: Red light showing high tempature
cooling temperature of freezing is damaged and also damaged heater machine which keep in deep freeze but controller point keep in normal side,you must be repair that problem as soon as possible otherwise full freezing system get damaged.
Posted on Mar 24, 2013
  • 551 Answers
SOURCE: door ajar light is on
your freeze caused some technical problem,you read your freeze catalouge and there must be get solution.
Posted on Mar 26, 2013
Why is door ajar alarm on when door is closed
Hello friend, thank you for your post!
I see that your door ajar alarm is going off when the door is closed to your Frigidaire freezer. It sounds like a possible issue with the control panel or switch. Let's perform a reset to your appliance to see if that will correct the issue. You can do that by disconnecting power from the appliance for roughly ten minutes. I hope this helps. -Matt
Sep 22, 2014 | Frigidaire 14.1 cu. ft. Upright Freezer...
How can i stop the door ajar alarm when door closed and 0 f
Hey friend, thank you for your post!
In order to stop the door ajar alarm from beeping when the door is closed you would need to reset the alarm. If you have done that and it continues to beep it could be an issue within the switch or panel of your Frigidaire freezer. I would recommend having a professional come out to properly diagnose your appliance. -Matt
Sep 19, 2014 | Frigidaire Freezers
Door ajar keeps flashing evan though the door is close
Good Afternoon Friend,
I understand the door ajar light keeps flashing even though the door is closed on your Frigidaire freezer, model# FFU17K1CW. Please try resetting your appliance, by either unplugging it or shutting the power off at your home's circuit breaker, for 3-5 minutes. Restore power. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your appliances status has changed successfully. If further troubleshooting is needed, please leave the model number of your appliance. Hope this is helpful.
-Best Regards-
WP
Jul 10, 2014 | Frigidaire 16.7 cu. ft. / 473 liter...
Door ajar light is on
Mar 26, 2013 | Frigidaire Freezers
Door was not sealed tightly for about a day resulting in some frost inside freezer. Door appears to be closed but door ajar light is still lite and alarm is still beeping. What do I need to check?
Jul 28, 2011 | Frigidaire Freezers
Alarm on door keeps peeping red light on and says door ajar
Feb 12, 2011 | Frigidaire Freezers
Food is not completely freezing in spots
This is a symptom of air leaking into the freezer. The most common place is around the door. Check the door really good to make sure something is not obstructing it from closing all the way, it may be closing enough to satisfy the ajar alarm but not enough for a bit of moisture to sneak in. Look for tears or breaks in the seal. If you put a bright flashlight inside the freezer and close the door, turn off the lights in the room you may find a leak that way.
May 03, 2010 | Electrolux 21.0 Cu. Ft. Upright Freezer -...
Frigidaire 17 CF upright freezer. We are getting Door Ajar light and beeping but the door is closing and sealing. Not sure what to do? Freezer seems to be operating as usual. Also, not sure this could...
Mar 14, 2010 | Frigidaire 20.3 Cu. Ft. Frost-Free Upright...
Door is closed but door ajar light on and beeps. look like sensor knocked off the door and I dont see where to put it back
Usually on most vehicles you will find the switch in the catch on the door, not knowing what vehicle you have I can't be any more specific then that.
Some vehicles us the interior light door pin also, but it really is dependent on vehicle make, model and year.
Aug 29, 2009 | Kenmore Freezers
Servis fridge freezer
Hi ,
ngafm at your service,
If its cold and frozen it may be that the door switch that activates this light in the case that the door is ajar, is faulty.
Or it may be that the temperature is dropping to slowly for you to see it by eye!
The whole purpose of the, "door ajar" light is to protect you food from spoilage and to warn you before it gets to warm!
Door ajar or not!!!
My advice is to fix the problem now no matter if it is only the switch causing a false alarm.
Or the worst case scenario !
You need hands on service!
Bless You ,
ngafm,
please give me a good rating before you sign off.
Thank you.
Sep 07, 2008 | Freezers
Frigidaire 20.3 Cu. Ft. Frost-Free Upright Freezer - White Logo
289 people viewed this question
Top Frigidaire Freezers Experts
AJMAL KHAN
Dan Webster
Dan Webster
John Tripp
John Tripp
Are you a Frigidaire Freezer Expert? Answer questions, earn points and help others
