Question about Cell Phones
P0651 code for GMC - Cell Phones
I have a code PO651 on a 2005 Chevy Alvalanche
Symptoms of a P0651 code may include: Failure of the transmission to shift between sport and economy modes Transmission shifting malfunctions Delayed (or no) transmission engagement Failure of the transmission to switch between all-wheel and two-wheel drive modes Failure of the transfer case to shift from low to high gear Lack of front differential engagement Lack of front hub engagement Erratic or inoperative speedometer/odometer
Read more at: https://www.obd-codes.com/p0651
Copyright OBD-Codes.com
Sep 12, 2017 | Cars & Trucks
I own a 2008 GMC Envoy Denali, 2WD. Yesterday the engine would barely idle and numerous lights on the dash came on including the check engine light. I had a friend check the diagnostic codes and it came up...
Five days prior to this, the battery had to be replaced. The engine was started without the pause for two minutes ?????? Where do you people come up with some of this stuff ? Pausing for two min. before starting has nothing to do with it . DTC P0651: 5-Volt Reference 2 Circuit
Some of the engine sensors on your vehicle work off of a steady 5 volt supply by the PCM - engine computer . One of these sensors is short internally bring down the PCM .
Circuit
Short to Ground
Open/High Resistance
Short to Voltage
Signal Performance
Accelerator Pedal Position (APP) Sensor 1 5-Volt Reference 2 Circuit
P0651
P2122
P0651
Accelerator Pedal Position (APP) Sensor 2 5-Volt Reference 1 Circuit
P0641
P2127
P0641
Air Conditioning (A/C) Refrigerant Pressure Sensor 5-Volt Reference 1 Circuit
P0641
P0532
P0641
Camshaft Position (CMP) Sensor 5-Volt Reference 1 Circuit
P0641
P0340
P0641
Engine Oil Pressure (EOP) Sensor 5-Volt Reference 1 Circuit
P0641
P0522
P0641
Fuel Tank Pressure (FTP) Sensor 5-Volt Reference 1 Circuit
P0641
P0452
P0641
Manifold Absolute Pressure (MAP) Sensor 5-Volt Reference 1 Circuit
P0641
P0107
P0641
The Crankshaft Position (CKP) Sensor 5-Volt Reference 2 Circuit
P0651
P0335
P0651
Throttle Position (TP) Sensor 1 and 2 5-Volt Reference 2 Circuit
P0651
P0122, P0222
P0651
That's why it wasn't running good ,an lights lit on the dash. Your best bet , take it to GMC dealer .
No where in GM service info does it say after replacing the battery that you need to wait two min. before starting .
Position the positive battery cable (1) to the battery.
Tighten the positive battery cable bolt.
Tighten
Tighten the bolt to 15 N·m (11 lb ft).
Connect the negative battery cable. Refer to Battery Negative Cable Disconnection and Connection .
Caution: Unless directed otherwise, the ignition and start switch must be in the OFF or LOCK position, and all electrical loads must be OFF before servicing any electrical component. Disconnect the negative battery cable to prevent an electrical spark should a tool or equipment come in contact with an exposed electrical terminal. Failure to follow these precautions may result in personal injury and/or damage to the vehicle or its components.
Aug 02, 2017 | GMC Cars & Trucks
2007 cobaltpo651 circuit b how do i trll which is circuit b
DTC P0651: 5-Volt Reference 2 Circuit First off do you know what computer reference voltage is ? Your vehicle has 2 reference voltage circuits . This reference voltage is used to power engine sensors .
Diagnostic Fault Information
Circuit
Short to Ground
Short to Voltage
Signal Performance
P0651
P2122
P0651
P0641
P2127
P0641
P0641
P0532
P0641
Crankshaft Position Sensor 5-Volt Reference 2 Circuit
P0651
P0335
P0651
P0641
P0452
P0641
Intake Camshaft Position Sensor 5-Volt Reference 1 Circuit
P0641
P0340
P0641
P0641
P0107
P0641
Secondary Air Injection (AIR) Solenoid 5-Volt Reference 2 Circuit
P0651, P2432
P2431
P0651, P2431
Throttle Position (TP) Sensor 1 5-Volt Reference 2 Circuit
P0651
P0122
P0651
Throttle Position (TP) Sensor 2 5-Volt Reference 2 Circuit
P0651
P0222
P0651
How to check the 5v reference circuit for short to ground Cadillac
Jun 10, 2017 | Cars & Trucks
2008 impala no tach signal to pcm
You have a bad sensor or a short on the five ref. circuit .
The 5-volt reference 2 buss provides 5 volts to the following sensors:
The APP sensor 1
The crankshaft position (CKP) sensor
The throttle position (TP) sensor 1 and 2
The brake booster vacuum sensor
A bad sensor or short on the five volt ref. circuit will bring down the PCM and you will have a no start . I would pull the connectors off each of these sensors listed above to see if five volt ref. comes back to five volts . Well first check five volt ref at easiest sensor to get to . watch this video , he explains better !
2006 Cadillac DTS Shorted 5v Reference Circuit
Dec 05, 2016 | Cars & Trucks
What are the probable causes of DTC P0651?
http://www.2carpros.com/questions/chevrolet-tahoe-2004-chevy-tahoe-engine-stalls-has-p0651-service-engine-cod
Dec 12, 2015 | 2008 Chevrolet Chevrolet TrailBlazer LT
My 2003 chevy pickup starts up then stops running almost instantly and will not run it has a 4'3 engine and has a dtc p0651 code in it could you tell me how to fix the problem?
You have a short on PCM - powertrain control module , 5volt reference circuit . This will surely make the vehicle not keep running !
The powertrain control module (PCM) provides 5 volts to the following sensors:
The air conditioning (A/C) pressure sensor
The fuel tank pressure (FTP) sensor, if equipped
These 5-volt reference circuits are independent of each other outside the PCM, but are bussed together inside the PCM. Therefore a circuit condition on one sensor 5-volt reference circuit may affect the other sensor 5-volt reference circuits. The PCM monitors the voltage on the 5-volt reference circuit. If the PCM detects that the voltage is out of tolerance, DTC P0651 sets.
Aug 30, 2015 | Cars & Trucks
Chevy colorado
Hi there:
DTC P0641 - 5-Volt Reference 1 Circuit
DTC P0651 - 5-Volt Reference 2 Circuit
Perform the Diagnostic System Check - Vehicle prior to using this diagnostic procedure.
Circuit/System Description
The engine control module (ECM) has 2 internal 5-volt reference busses called 5-volt reference 1 and 5-volt reference 2. Each reference bus provides 5-volt reference circuits for more than one sensor. Therefore, a fault condition on one 5-volt reference circuit will affect the other 5-volt reference circuits connected to that reference bus. The ECM monitors the voltage on the 5-volt reference busses.
The 5-volt reference 1 bus provides 5 volts to the following sensors:
* The manifold absolute pressure (MAP) sensor
* The fuel tank pressure (FTP) sensor
* The air conditioning (A/C) refrigerant pressure sensor
* The accelerator pedal position (APP) sensor 2
* The intake camshaft position (CMP) sensor
The 5-volt reference 2 bus provides 5 volts to the following sensors:
* The APP sensor 1
* The throttle position (TP) sensor 1 and 2
* The crankshaft position (CKP) sensor
Conditions for Running the DTC
* DTCs P0601, P0602, P0603, P0604, P0605, P0606, P0607, and P2610 are not set.
* The ignition is in Unlock, Accessory, Run, or Crank.
* The ignition voltage is more than 5.23 volts.
* DTCs P0641 and P0651 run continuously when the above conditions are met.
Conditions for Setting the DTC
The ECM detects a voltage out of tolerance condition on the 5-volt reference 1 or 2 bus for more than 0.5 second.
Action Taken When the DTC Sets
DTCs P0641 and P0651 are Type A DTCs.
Conditions for Clearing the MIL/DTC
Diagnostic Aids
It may be possible to locate the fault by disconnecting one component at a time from the 5-volt reference circuit while viewing the 5-Volt Reference circuit parameter on the scan tool. The scan tool parameter would change from Fault to OK when the source of the fault is disconnected.
If all 5-volt reference components have been disconnected and a Fault is still indicated, the fault may exist in the wiring harness.
Circuit/System Verification
With the ignition ON and the engine OFF, observe the 5-volt Reference 1 and 2 parameters. The scan tool should display 4.3-4.7 volts for a normally operating system.
Circuit/System Testing
Important: Additional DTCs will set when disconnecting the components.
1. Ignition OFF, disconnect the harness connector of all appropriate sensors for the applicable DTC.
Important: A short to voltage on the signal circuit of certain components may cause this DTC to set.
2. Ignition ON, measure for 4.8-5.2 volts between one of the 5-volt reference circuits and ground.
* If the voltage is less than the specified value, test for a short to ground on all the 5-volt reference circuits. If all circuits test normal, replace the control module.
* If the voltage is greater than the specified value, test for a short to voltage on all the 5-volt reference circuits, or the signal circuit, for each component associated with the appropriate 5-volt reference circuit. If all circuits test normal, replace the control module.
3. Connect each component associated with the 5-volt reference circuit, one at a time, while monitoring the voltage. The voltage should not change more than 1 volt.
* If the voltage display changes more than the specified value when a component is connected, replace the component.
Hope this helps; also keep in mind that your feedback is important and I`ll appreciate your time and consideration if you leave some testimonial comment about this answer.
Thank you for using FixYa, have a nice day.
Jul 12, 2012 | Chevrolet Colorado Cars & Trucks
I have a 2003 chevy silverado 1500 series and it is showing a trouble code of p0651 and i have no idea what it means can you tell me and help fix it?
Possible causes:
- Shorted sensor
- Shorted sensor circuit
- Failed ECM
Unfortunatly error codes are very sparse when it comes to giving specifics. The only recommendation is to take it to a certified chevrolet mechanic. I know that isn't the advice you wanted to hear, but its the best I personally can do.
Hopefully one of our mechanics will see this post and be able to give you some better advice.
May 30, 2011 | Computers & Internet
Having trouble geting it inspected reading code po651
P0651 indicate a problem with the fuel tank pressure system. Insure the cap is tight ... Might want to inspect the gas cap for bad / worm o-ring or seals.. replacement would be recomended
Nov 26, 2010 | Chevrolet S 10 Cars & Trucks
Cell Phones Logo
135 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
