Question about Cobra 6000 Pro HD 5 GPS Navigation
Cobra 6000 gps unit does not power up at times. when unit is plugged to supply unit flashes start up screen erratically. I have attempted the online updates but cannot complete because unit does not power up. after the unit is plugged for approximately 8 - 10 hours the start screen will appear. the unit will function with limited performance for about 4 hours then will stop and go to a black screen at first. then approximately 10 seconds later go back to the flashing start up screen.
4 Suggested Answers
SOURCE: Software Update
SAME PROBLEM
Posted on Oct 17, 2008
SOURCE: ticking sound
We have a similar problem which was from a bad coed to receiver connection.
Try holding the point to where you hear the 'tick' and wait for the connection.
Posted on Oct 28, 2008
SOURCE: wish to update software
I did some digging in the files on my units drive. I have found a solution that gave me 2009 maps. With a little bit of computer file knowledge, you can register (for free in the developer section) at NAVTEQ. Their website is "nn4d.com". It took me about two hours of separating different database files but it was smooth sailing from there. Good Luck
Posted on Dec 19, 2009
How do I unfroze the screen of my Cobra 6000 pro hd gps? Nothing works
Try to leave it on with no battery supply until it runs completely out of charge and switches off. Only then connect it to your PC and see if it communicates with the software on the PC. If it's still frozen you need to restore it to factory settings.
Dec 15, 2014 | Cobra 6000 Pro HD GPS Navigation Trucker...
Cobra gps update
You need to download from the following link their HomeBase software to do so:
Cobra HomeBase
Aug 30, 2014 | Cobra 6000 Pro HD 5 GPS Navigation
I need the direction on how to upgrade acobra 6000 pro HD GPS
You need to update your device. You do so by connecting it to a computer and downloading the Cobra HomeBase software from their website. Here's the link
Jun 24, 2014 | Cobra 6000 Pro HD 5 GPS Navigation
My cobra gps 6000hd has started being very slow to load
There may be a system update which needs to be installed.
You will have to connect to computer to do this.
Apr 09, 2014 | Cobra 6000 Pro HD 5 GPS Navigation
Display screen is cracked
how can I get a new replcement screen for my cobra 6000 pro hd 5 navigation. can u give some advice on how I can get a replacement screen
Aug 28, 2013 | Cobra 6000 Pro HD 5 GPS Navigation
SG2 model. I push power on and no screen.
Your battery is probably finished, get a new one at Battery Bob or elsewhere online, much cheaper than at SkyGolf
Feb 24, 2009 | SkyGolf SkyCaddie Handheld GPS Unit
Re: Won't turn on
your power cable has a short in it. replace it.
May 16, 2008 | Cobra 4000 GPS Receiver
Lowrance LCX-19C GPS Receiver Problem
It sounds like you may have to send it out for service, but before you you do there are a few things you can try.
Low voltage can cause erratic behavior. Since you already wired directly to the battery, check the plug for corrosion.
Try unplugging the transducer cable to see if the display still behaves erratically. You wont see depth readings but you should still see the screen going black. If no erratic behavior with transducer unplugged then problem is in the transducer cable or the plug. A common source of failure is at the plug because the added stress of plugging and unplugging cables can cause the socket to twist slightly which can cause a short.
Make sure you have the latest software update.
How to see if your LCX-19C is already using version 1.8.0 software:
  1. Press the MENU button twice on your LCX-19C.
  2. Select SYSTEM SETUP.
  3. Select SOFTWARE INFORMATION.
  4. The software version for your unit is located under the line that says "LCX-19C" (ex. "Version 1.8.0").
  5. If your version is the same version listed above, there is no need to download the software.
If it is lower than 1.8.0 you can download the update from this link: LCX-19C UPDATE
Copy it onto a blank MMC card and install it in your GPS. The GPS should prompt you on how to install the update.
If you need to send the unit in for service click this link: LOWRANCE SERVICE
Mar 15, 2008 | Lowrance LCX-19C GPS Receiver
Cobra 6000 Pro HD 5 GPS Navigation Logo
37 people viewed this question
Top Cobra GPS Experts
Steve
Will Halftowaite
Are you a Cobra GPS Expert? Answer questions, earn points and help others
