Question about Bosch Dryers
Bosch 800 next dryer (WTMC8321US/CN) - makes grinding / rubbing sound when turned on - drum turns very slowly.
    New Friend:
    Problem Solver:
  • 12 Answers
This ccan be the result of the skid pads being worn that the drum goes around on. If you can take the front panel off the dryer, the drum will be sitting on plastic skids mounted on the frame. The other thing to look for would be to see if you have any rubbing marks on the inside of the front panel to indicate it needs a little adjusting.
Posted on Oct 22, 2013
IFIXALL
  • 868 Answers
SOURCE: ge dryer makes grinding noise when drum is turning
If youve made sure that its not a roller thats dry or a belt idler pulley that dry,than yes its the motor,and oiling that will only make it worse.
Posted on May 21, 2008
michiganfan9
  • 179 Answers
SOURCE: Clothes are getting caught on edges of drum
you need to replace the felt on the dryer
Posted on Dec 20, 2008
Healeyman
  • 1198 Answers
SOURCE: Maytag dryer model MDET336AYW making
Check for a center bearing worn out.
Posted on Apr 22, 2009
erpaalai
  • 999 Answers
SOURCE: dryer squeaks while drying sounds like drum rubbing on something
A squeak can also be a slipping belt or something caught between the drum bearings usually the front but could be the back one.
Posted on Jun 14, 2009
  • 4 Answers
SOURCE: dryer is making a grinding noise when the drum turns
hi your belt is ready to give up take does it smell of burning if not it soon will take the name make and model to comet they will sort you another and they are very easy to replace you just open the back of your dryer make sure it is unpluged first take the old one off and just slide the new one straight on problem sorted
Posted on Apr 26, 2010
My bosch Nexxt WTMC 3300 dryer makes a squeaking sound when the load is light -- drying a larger/wetter load less likely to make the noise.
I had a similar problem with a different model Bosch dryer. First I made sure the dryer was unplugged. I found, after taking the front and rear panels off, that one of the front wheels that supports the drum was broken. I replaced the wheel and it works fine with no squeaks.
Jan 01, 2013 | Bosch Nexxt WTMC 3300 Electric Dryer
Drum makes grinding sound when turned manually. Is it bearnings, belt, or other?
the grinding noise is probably the bearings as the belt usually squeels and then breaks.I m not 100% sure with your model # but some have wheels that the drum runs on and they will wear out after time ;and they also have a bearing in them. Replace the whole set of wheels if that is the problem otherwise the others will wear faster.good luck
Oct 07, 2010 | Bosch Nexxt 500 Dryer
Bosch AXXIS dryer # WTA 3510 uc slipping / grinding sound when drum reverses direction. Difficult to turn drum by hand. Belt or motor?
drum baring or rollers if you can get belt off try to turn drum if it still hard to turn you will know its not the motor may be something in blower give it a try
Sep 30, 2010 | Bosch Axxis WTA 3510 Electric Dryer
The drum is making a resonating sound when turning.
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
May 23, 2010 | Bosch Axxis WTA 4107 Electric Dryer
The dryer was squeaking when it was on but know it
possible worn bearing.the more wear on the bearing the lower the drum will be.the drum sounds like its rubbing the bottom of the dryer.check for black dust behind the dryer
Feb 20, 2010 | Amana Dryers
The dryer (Bosch Nexxt 500) makes a loud grinding noise when rotating. Any idea what this may be?
The noise could be your drum rollers need lubricant or replacement.
When the drum rollers get flat spots on them they will make a bumping/thumping type of noise.
The grinding noise sounds to me like the drum rollers are in need of lubrication.
Sep 26, 2009 | Bosch Nexxt 500 Dryer
Lg dryer - front load - making a grinding noise
I also have the same problem as klrlesimmons, exactly as described. Sounds like sand is rubbing as the drum turns, and also sounds out of balance.
Repairmen replaced upper and lower glides and also the plastic bearing but not the entire bearing assembly.
Frigidaire Gallery, Model Number 417.49012890
Mar 22, 2009 | LG DLE3777 Electric Dryer
When turning, loud grinding noise.
Can be a tensioner pulley with bad bearings or the rear drum bearing is shot. When the rear drum bearing goes bad, the drum drops slightly and starts rubbing and making all sorts of terrible noises. I would not run it like this as the pivot on the rear of the drum that rides in the bearing could be cutting into the support. Not a good thing.
Good Luck and hope this helps.
Mar 15, 2009 | Whirlpool LER4634J Electric Dryer
I have a CTD40 Aquarius Dryer and an underwire from a bra has worked its way into the back of the drum through the dryer holes at the back of the drum. Is there an easy way into it to retrieve the item as...
take a pair of tweezers and a flashlight and turn the drum slowly around trying to see it and grab it with the tweezers to pull it out through one of the holes.
Jul 06, 2008 | Dryers
Bosch dryer
try lifting the drum from inside to check for any excess lift. it may be a bearing or bearing bracket.
Feb 16, 2008 | Bosch WTMC1301US Electric Dryer
Dryers Logo
64 people viewed this question
Top Bosch Dryers Experts
Lawrence Oravetz
MightyMikeJr
Are you a Bosch Dryer Expert? Answer questions, earn points and help others
