Question about Zebra Printer 140-751-00000
Labels are out
We are using zebra printer for printing labels from SAP.We have loaded new bundle of label and when switched on the printer it is kicking out the labels out. Can u anyone help me with this situation what could be the problem?? Thanks Surya
    President:
  • Zebra Master
  • 2,022 Answers
Load the labels properly
Posted on Sep 25, 2007
SOURCE:
Why is the text printing on Zebra LP 2844-Z label incorrectly spaced?
Zebra printers are not really made to print PDF files, if the only option is PDF I'd recommend switching to print on a laser. Also open the PDF and see if they are correct in the original doc
Oct 06, 2015 | Zebra Office Equipment & Supplies
Zebra ZM400 drops interface on port 515
make sure you have no network traffic for your printer and decrease the printing speed, and make sure you are using a free port not a used and default port for the service..
Jul 20, 2014 | Zebra ZM400 Thermal Label Printer -...
I am using a Zebra S4M Thermal printer with Zebra brand labels. I changed out the roll of labels with a new roll and it will not print. It completed the task like it always does but i only get a blank...
The new labels are probably not thermal labels. Test them by applying heat to the surface and see if they turn black. If they do not change, then they are thermal transfer labels and not direct thermal. Contact your label vendor and have them replaced.
Jun 09, 2011 | Zebra S4M Thermal Label Printer
How to load new labels
http://www.scanonline.com/Online-Store/ZM400-600
Download the ZM400/600 Quick Reference Guide on the right hand side of the page. They have a diagram on how to load labels.
There should also be one inside the printer - printed on the back wall...
Jul 10, 2009 | Zebra ZM400 Direct Thermal-Thermal...
Print delay between labels
This looks like its being managed in the software.
Check with the programmer.
Apr 28, 2009 | Zebra 105SL Thermal Label Printer
Printing Bar Code Labels from Intermec 3400
I am using Smartforms with Intermec printer 3400-e and it works in the correct way.
What is the software that you use to build the layout of the label? In my case Loftware.
What is the code to print the Barcodes.
In my case Code 39
Aug 07, 2008 | Intermec EasyCoder 3400 Thermal Label...
Zebra S600 printer
  1. Try just storing your labels in a cool dry place before using them. Peeling labels are usually a sign the glue is poor or weak.
  2. When tearing you labels off, feed them out before tearing them off, then hit the auto-align. See if that helps it.
  3. Try pushing a normal playing card under the metal cutter that tears the labels and pull it up and through the front to bend the blade slightly outward. This will hopefully allow the labels to pass underneath.
Jul 30, 2008 | Zebra Stripe S600 Thermal Label Printer
Printing every third labels ---> not evry
You need to take the labels out.
If you are using the labels that have perforations is where you can tear them off.
What you need to do is to
1) Switch off printer
2) ensure that the ribbon is loaded correctly
3) take some labels, feed them through the mechanism till you can see them coming out from the other end.
4) Make sure that the labels are lined up with the alignment mark or sometimes with label printers there is a light.
5)switch on printer and do a test print
May 08, 2008 | Zebra S4M Thermal Label Printer
Zebra Printer 140-751-00000 Logo
113 people viewed this question
Top Zebra Office Equipment & Supplies Experts
Gateway information...
Marvin
Marvin
Ekse
Are you a Zebra Office Equipment and Supply Expert? Answer questions, earn points and help others
