Question about Garden
I have a 2550 poulan and it use to start on one pull but now takes a while and will only run until it gets hot and sometimes kills after releasing trigger
  • josh1111 May 11, 2010
    have you tried to adjust the carb yet ? it may be internal damage how old is the saw?
    Problem Solver:
  • 11 Answers
Yea I used to start that way to, but after time we all need proper maintenance try your filters & a new plug might help.
Posted on Apr 24, 2009
My poulan pro 500ex runs until I try to go forward or backward then it shuts off
did you check the seat switch ???... unhook the kill wire at the engine ( for testing purposes ONLY ) and then try to move... if it works check you safety system... if not, check your safety system
Aug 30, 2014 | Garden
I have a poulan 6.25 self propelled mower that wont start soun like its not getting fire
First make your kill handle is pulling your cable all the way back.Sometimes the cable will rust or even break inside its sheathing. to test take a peice of wire and tie it off by pulling the arm all the way back then start it. If that works replkace kill cable
Jun 17, 2012 | Poulan Pro 22" Self Propelled High Wheel...
Poulan chainsaw model #2550 Serial # 99246D100255-3 Carburator adjustment floods out will not start
Check the fuel filter, air filter, and muffler for plugging. Check the carburetor lower chamber diaphragm for flexibility and no damage. Also check the needle valve tip that the diaphragm controls for any damage or wear. If still flooding, turn both needle jet screws CW to stops (lightly), the back each out CCW 1-1/2 turns. This is a basic setting which should allow the engine to start and run.
Start the engine and allow to warm up. Pull the throttle full on and adjust H needle CW till the engine starts to speed up, but still 4-stroking. Correct adjustment is when the engine 4-strokes unloaded, but immediately 2-strokes when cutting. Release the throttle and adjust L needle CW for better idle but allows the engine to 'follow the throttle'. Adjust idle speed screw so that the chain stops turning, but the engine continues to run. Hope this helps!
Aug 14, 2010 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
Poulan 550 Series push mower won't pull start
Hmmmm,,and the plot thickens. Without seeing the unit, i would have to think that when you pull the engine control cable bar, its not releasing the brake that sits against the flywheel. These cables do stretch. Pull the engine cover and you will see the brake against the flywheel. Pull the engine control handle and watch and see if brake is releasing. If its not, replace the cable.
That would be my bet. I hope this is of some help.
May 28, 2010 | Poulan Pro PR550N22SH 22Inch Briggs ...
18"poulan chainsaw
Start at 1.5 CCW form lightly seated then tune for performance like this:
Carburetor Adjustment by Madsens.com
http://www.madsens1.com/saw%20carb%20tune.htm
CW is leaner; to lean will destroy the saw. If over tightened closed (CW) the adjustment screw faces are easily marred; marred adjustments are difficult to impossible to set properly.
Clean the air filter; adjusting with a dirty filter can cause a run lean condition once cleaned and the saw run.
There are 2 wav (sound - idle & full – may not be highlighted) files that I find most helpful, I think you will too.
I think your starting procedure may be the cause of flooding. Flooded is the #1 cause of hard starts in 2-cycle engines. Read carefully the recommended start in your manual. most miss the second note. It should be similar to this (read 3, read it again):
Warm start in the manual says 1/2 choke BS. Close choke, (sets fast idle) open choke, pull rope.
Start Procedure
Cold:
  1. Ignition on/off to on
  2. Set compression release – optional step even if saw is equipped with a compression release
  3. Pull (close) choke, set fast idle (done when choke closed on some saws); pull starter and listen for an attempt to start. once heard (usually two pulls; no more than 4).
  4. Set compression release – optional step even if saw is equipped with a compression release.
  5. Push (open) choke pull starter until it starts (usually first pull).
Warm:
  3. Pull (close) choke, set fast idle (done when choke closed on some saws) – Do not pull with choke closed.
  4. Push (open) choke, pull starter until it starts (usually first pull).
If you still have trouble reply as you did before. I will get back to you. HTH
Lou
Feb 18, 2010 | Poulan Garden
Hartd to start when saw is warm
Are you choking it? You shouldn't be if hot. If no clean the air filter and try again. Are you setting the fast idle? You should be. Better? If your start procedure is similar to below and your fuel hoses have no cracks or holes the carburetor needs adjusting. A tune up might be a good idea. About $40 at your friendly neighborhood Stihl dealer (regardless of make). If taken in for tune up, get the oil/fuel ratio and use it until your next tune up (regardless of what manual says). HTH
Lou
Start Procedure
Cold:
  3. Pull (close) choke, set fast idle (done when choke closed on some saws); pull starter and listen for an attempt to start. once heard (usually two pulls)
  5. Push (open) choke pull starter until it starts. (usually first pull)
Warm:
  3. Pull (close) choke, set fast idle (done when choke closed on some saws) - Don’t pull with choke closed.
  4. Push (open) choke, pull starter until it starts. (usually first pull)
Hope this helps
Lou
Oct 15, 2009 | Poulan Pro Chain Saw 46cc 20"
Lawn tractor won't stay running if clutch is released.
There is an operator presence switch under the seat...it is more than likely faulty and must be replaced in order for the mower to run right.
Apr 28, 2009 | Poulan 42-Inch Steel Deck 17.5 HP Briggs &...
Poulan 2550 chainsaw does not lube the chain
sometimes the oi lpumps fail or get clogged youll have to take it apart and replace/clean the pump. let me know if you want more instructions on this
Apr 23, 2009 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
I have a poulan 2550 40cc that won't run in idle
Possibly the spark plug, idle screw is set too low, air getting into the fuel line. Does it run at higher speeds but kills when trigger is released?
Dec 23, 2008 | Garden
Garden Logo
63 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
