Question about Fisher and Paykel Kitchen Ranges
How do I dismantle nolte mobel wardrobe. I can't work out how to remove the sliding door
Did you manage to dismantle your Nolte wardrobe - we hav ethe same problem.
Posted on Jun 17, 2015
How do I assemble a Stag Minstrel wardrobe from its component parts?
These are the instructions for a Stag Minstrel S150 double door wardrobe which I hope helps figuring out what goes where etc..
I've just noticed the photo isn't very clear on line, so here is a transcript of what it says.
Instructions for dismantling Stag Minstrel double wardrobe S150.
1. Remove shelf by sliding forward.
2. Remove hanging rods and shoe rail by sliding their end ferrules ( the circular bits the rods pass through) inwards and sliding the rods clear.
3. Remove the screws that pass through the lower wings of the top gussets into the end panel.
4. Close both doors, bolting the left hand door at the bottom only.
5. Remove the screws that pass through the carcase back into the top panel
6. Remove the screws which pass down through the top of the wardrobe into the end panels, and lift the top, complete with gussets and shelf supports, clear of the wardrobe.
7. Lay the wardrobe on its back, and remove the screws which pass upward through the front and back rails into the bottom panel.
Pull the plinth clear. The wardrobe will now divide into two halves.
NOTE : When reassembling the wardrobe make sure that
(a) the two halves of the wardrobe are located correctly together before fitting the plinth over the bottom location blocks ;
(b) all screws enter the holes bored for them.
Jun 13, 2015 | Home
I need assembly instructions for my Powell Cheval jewelry wardrobe
I have know the wardrobe design services company.They will guide the Correct instructions about jewellery wardrobes.Site address of wardrobe design firm Robetek Industries http://robetek.com.au/ .
Feb 13, 2015 | Powell Company Walnut" Cheval Jewelry...
Where can I dowload the assembling instructions for the Alessia bedroom range model 926
If they look like the image. The 2 screws are the mounting holes, you screw those to the top of the door. Edge of metal support alined with the edge of the door, both in the same position one at the front corner of the door and the other at the back corner. The roller is mounted with a screw through the diagonal slot on the side. There are 3 positions. You place it in whichever position you need so it clears the floor. The highest position will give you the least floor clearance, the lowest will give you the most floor clearance. Normally both rollers are in the same position, unless your floor is not level.
May 09, 2014 | Slide-Co Sliding Wardrobe Door Roller For...
How do i dismantle a wardrobe so i can get it up my stairs
If it is not a flat pack wardrobe then there is no easy way and it depends on what timber the robe is made out of. Your only hope is to carefully try and pries apart the joints with screw drivers, hammer and a small pinch bar whilst trying not to damage the integrity of the wood itself. Start by taking off the doors to have a good look first. It may be easier than it appears. cheers
Jan 17, 2014 | Fisher and Paykel Kitchen Ranges
I need to adjust the sliding doors in my wardrobe so they stay on the tracks..how do I do it
from the edges of the door you will find a hole that allows you to get to a normally a Phillips headed screw that is parallel to the track. This screw adjusts the height of the door on the roller body. It also adjust the vertical position of the door to make it line up with the opening edges . Turn both sides evenly to lift the door and then one side or the other to correct the opening alignment.
Aug 31, 2013 | Home
How Dismantle jbl on tour
First you need to remove the sliding door. You can do this by opening it and lifitng one side with a screwdriver like on one of the pictures.
After that you can remove the battery cap and batteries.
Than you will need to remove the JBL logo. This is quite tricky. because it is glued.
After that you can remove all the torx screws and open the device.
http://imgur.com/a/Czyat
I damaged mine because I didn't have proper tools. Fixed the speaker though.
Aug 12, 2012 | JBL On Tour Computer Speakers
How to dismantle panasonic sc-hc3 sliding door?
Remove the speaker covers by sliding a screwdriver carefully under the edges and push it up. They are just pressed into holes. Once removed, you have to remove the 4 screws of the top cover (the one with the buttons). After removing the screws slide a screwdriver carefully under the top cover and push it up. Attention, the cover is connected to the body with little cables so do not break them. Once pushed up , you see little screws that hold the top sliding rail. Remove them and you can take the sliding door off. Good luck
Jan 16, 2012 | Panasonic Audio Players & Recorders
I'm trying to help my friend move her bedroom round as she has new wardrobes coming, and we cant get her roger black treadmill out of the room with out dismantling it, but she has lost the manual so I need...
I have a Roger Black Treadmill & it came in 1 piece ready to go. There is no way to dismantle the one I have. Not sure if there are multiple models but I have only ever seen 1
Aug 31, 2010 | Baby Gear
Ps3 dismantle instructions
1. To remove drive you only need to remove small plastic door with fine flat screw driver under small **** towards the front of console then undo blue screw and slide drive towards front of console and pull straight out. Be careful not to press on any of the drive's surfaces especially where the label is as head or platter will be damaged!
2. To dismantle the rest of the console, remove sticker on left side of console, remove rubber plug/ foot, undo tamper proof screw with correcy T15 star driver, and slide false plastic cover towards you. Then you have several philips head screws all marked with arrows to undo after which the top can be removed straight up. When removing or disturbing the optical drive be careful not to damage the heat transfer pad under the drive as the electronics of the drive will then overheat. The rest should be easy!
Nov 29, 2008 | Sony Playstation 3 (PS3) Console
Kitchen Ranges Logo
848 people viewed this question
Top Fisher and Paykel Kitchen Ranges Experts
Beamvacman
Level 1 Expert
linnap
Bob Kirkwood
Are you a Fisher and Paykel Kitchen Range Expert? Answer questions, earn points and help others
