Question about ViewSonic NX1932W LCD Monitor
My ViewSonic NX1932W LCD Monitor stop working and the power button color went to amber. If i hold the power button it will flash blue then amber again. it does this when hooked the the cable box (Comcast) or when used as a computer monitor. It was being used as a computer monitor when it stopped working. I can't even figure out how to remove the covers to see if a resistor, cap, or fuse is burned up. Help please.
3 Suggested Answers
  • 9 Answers
SOURCE: I have viewsonic 1703wb monitor. Often Monitor power went off
Check the power cable. If it uses a power brick style assembly (like a laptop) it may need to be replaced. Some power bricks can break a wire at the base of the brick just enough that it causes a short in the system and shuts down the power flow.
Posted on Mar 19, 2009
  • 30 Answers
SOURCE: have a nx1932w; worked fine until this morning; turn on the monitor (using it as tv) the logo is in black and white and it says no signal - can't even get menu button to work.
the most common problem with LCDs today is failing electrolytic capacitors, especially in the power supply section. Look for bulging, leaking, blown or missing capacitors and replace them.
Posted on May 18, 2012
Testimonial: "Thanks! I'll let you know if Viewsonic will stick with the warranty~"
My ViewSonic NX1932W LCD Monitor was being used as a computer monitor. It stopped working with the power button displaying the amber color. If I hold the power button it will flash blue and return to...
these monitors are tightly held in place by clips. After removing all the necessary screws, use somehing like a credit card to pry open the lid. Just need to be careful not to crack the case, or your hand.
Oct 12, 2013 | ViewSonic NX1932W LCD Monitor
Have a nx1932w; worked fine until this morning; turn on the monitor (using it as tv) the logo is in black and white and it says no signal - can't even get menu button to work.
May 17, 2012 | ViewSonic NX1932W LCD Monitor
Have had the nx1932w for 4 years. turned on this morning and it only shows a blue screen with message stating no signal. have digital cable and all other tv's in the house work. please advise.. thank you
If the ViewSonic logo first comes on followed with no signal the monitor is okay, check the video cable connection between the monitor and the computer, if okay the video graphic's card may be the problem,or the motherboard, but this is speculation you will need somebody to check the system for exact cause.
Jan 01, 2011 | ViewSonic NX1932W LCD Monitor
Black screen
Most common failure in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed VIEWSONIC and other monitors to get some ideas what goes wrong: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further.
Mar 31, 2010 | ViewSonic VX910 19" LCD Monitor
Hp L1502 LCD blank, LED still flashes
just check ur lcd display cable and try to clean and c it it will cme
May 29, 2009 | Samsung SyncMaster 910T 19" LCD Monitor
Viewsonic lcd tv 37"
try to check the RAM, video card, or processor maybe it is not properly inserted to the slot.
Jan 08, 2009 | ViewSonic A90f+ 19" CRT Monitor
Monitor in sleep mode
I think it maybe time to buy a new monitor
Aug 09, 2017 | X2Gen MG15VT 15" LCD Monitor
No display (black) - power light is amber color
The video signal is not reaching your monitor, check the pins on the connector from the monitor to the computer, then check the video card:
Turn off your computer, unplg the power, and then take out the video card. Wait 5 minutes and then put the card back into the computer and turn it on. For onboard video; turn off the computer, unplug the power, then hold down the power button on the front for 5-10 seconds, then plug back in and turn on.
Make sure the video card is snug in the AGP/PCI slot. If this is built-in video, try borrowing a video card from another computer and install it in this one. If the borrowed card works, then replace you card. If video is built in, then you can disble the onboard video and use the new card without having to replace your motherboard.
Jul 14, 2008 | ViewSonic VX910 19" LCD Monitor
ViewSonic VE710b 17 inch yellowed photograph look
Check and make sure that there is no speaker, power supply or UPS around your monitor.
Mar 16, 2008 | ViewSonic VE710b 17" Flat Panel LCD...
Viewsonic VG919S 19" LCD
Hi
You must focus to mainboard of LCD monitor find the voltage regulator IC. Voltage test the regulator IC use digital or analog multimeter range 10v dc connect the negative to cold ground, these regulator providing a constant supply of 2.5 - 5v to all IC in the mainboard. check the scalar IC. Because scalar IC will convert analog input signal of Red, Green & Blue. Lastly check the controller board, check the ribbon cable connector from mainboard to
controller board for lose, check the fuse inside controller. I think the exact problem of your monitor could be either the (mainboard) or (LCD panel where the controller board is located).
Oct 06, 2007 | ViewSonic VG910S (Black, Silver) 19" LCD...
ViewSonic NX1932W LCD Monitor Logo
73 people viewed this question
Top ViewSonic Computers & Internet Experts
Are you a ViewSonic Computer and Internet Expert? Answer questions, earn points and help others
