Question about Qca Spas Dream Series Dream Master Hot Tub with Flex Cover
Ec on hot tub codes - Qca Spas Dream Series Dream Master Hot Tub with Flex Cover
    New Friend:
    Problem Solver:
  • 6 Answers
Can you NOT understand simple English. Where do I purchase liquid nitrogen?
Posted on Oct 12, 2013
3 Suggested Answers
Coastsider
  • 331 Answers
SOURCE: What does the code Ec on my oasis hot tub mean?
Your spa is in Economy mode. You have a basic Balboa Controller likely a Value Series.
Posted on Apr 14, 2010
adamh294
  • 310 Answers
SOURCE: what does ec mean on
EC stands for Economy mode. This is a setting that tells the computer to check the temperature of the spa less frquently, as well as running fewer filter cycles. Spas should be set to EC while you are away on vacation or not planning to use it for a while
Posted on Apr 29, 2011
EC keeps showing on my temperature screen can not find anything in the instructions. Help
Means "Economy"
You probably have a Balboa Control System.
Find the "Code" number on the label of the unit and do a Google Search. Find how to switch between Economy and Standard.
I recommend that spas be on Standard.
But if the spa is hot and is not giving you any problems, and the only irritant you have is not knowing what EC means, you can leave it alone, since you now Know.
Good Luck
Sep 26, 2014 | Eclipse 4 Person Hot Tub Spa - Dream Maker...
What does Ec mean
EC on a Hot tub shows that it is in "Economy mode" meaning the spa will only heat during a filter cycle. Not a setting to be in if you live in "cold country" (you risk having the equipment freezing up)
Nov 21, 2013 | Dream Maker Spas Pool & Spa
What is Ec code on disply mean dreammaker spa
check recirculation pump and heater element if ok temp sensor
Mar 29, 2013 | Dream Maker Spas Dream Maker Ez Spa Hot...
On my hot tub control panel Balboa M1 is the code Ec?
Your spa is in Economy Mode:
Ecn or Ec MessageEcn or Ec Message
If the Ecn or Ec Message is Alternating with the Water Temperature on the Display, the Spa is Operating in the Economy Heating Mode.
If the Ecn or Ec Message is ON Solid (Not Flashing) on the Display, the Spa is Operating in the Economy Heating Mode, but there is No current water temperature because the Spa is between Filter Cycles.
Ecn or Ec is Alternating with Temp:
The Spa is Operating in the "Economy" (Ecn or Ec) Heating Mode.
The Water Temperature is Sampled Only during Programmed Filter Cycles. The Heater will Only operate and Heat up to Set Temperature during the Filter Cycles. The Water Temperature will probably drop Below Set Temperature between Filter Cycles. Other Heating Modes are Standard, Standard in Economy, and Sleep Modes.
Ecn or Ec is ON Solid (Not Flashing):
The Current Water Temperature is "Unknown" (- - - or - -) while in Economy or Sleep Mode.
Between Filter Cycles, while in the Economy or Sleep Heating Modes, the Pump has not turned ON and the Last Water Temperature is not Current. To read the Current Water Temperature, either Change to Standard Heating Mode or turn On the Heating Related Pump, and wait at least 2 Minutes.
Mar 13, 2013 | Balboa Instruments Pool & Spa
What does ec mean on my hot tub
Apr 29, 2011 | Qca Spas Dream Series Dream Master Hot Tub...
On our Keys hot tub it is showing F8 along with the EC mode on the panel. We have had it 4 yrs and never seen this , It is also not shutting down all at once after the 2 hrs filtration. Any ideas? ...
The EC mode indicates Economy Heating mode. Which means it check the temp and heats the tub less often. The F8 is usually indicating Filter=8 hours of filtration. Change modes to standard, and change filtration to desired level.
If you do not have the manual for this tub, contact keys for instructions on how to change the filtration options. With out the model number I cannot guide you as to how to do this.
Jan 13, 2011 | Pool & Spa
Tub is not heating to temperature and flashing a Ec message on the temperature screen.
the Ec message is reffering to the mode the tub is set for. Ec stands for Economy mode. In Economy mode the heater will only come on during the filter cycle you have programmed. It will take a while for the tub to actually heat up in this mode. Change the mode to St mode which stands for Standard mode. Your manual should explain how to do this. usually you hit the temp button then the light button to change from mode to mode. Once the St is in the read out window don't touch anything and it will except the programmmed entry automatically. In the Standard mode the tub will keep heating until the set temperature is reached. then it will come on every half hr or so to check that the temperature is maintained.
Oct 09, 2010 | Dream Maker Spas Dream Maker Ez Spa Hot...
WHAT IS THE MODE BUTTON FOR?
EC stands for Economy. Change the mode until you reach ST and then it will stop flashing and function as normal.
Economy mode only allows the heater to function when the hot tub is on its filtration cycle.
Regards,
Ian.
http://hottub.synthasite.com
Jan 04, 2009 | Jacuzzi Balboa R574 System for 1 2 Speed...
Qca Spas Dream Series Dream Master Hot Tub with Flex Cover Logo
116 people viewed this question
Top Qca Spas Pool & Spa Experts
john h
Ian Summerfield
Ian Summerfield
Are you a Qca Spas Pool and Spa Expert? Answer questions, earn points and help others
