Question about Dishwashers
Granite countertop We are trying to figure out a way to connect two matching countertops in our kitchen. We need some sort of connecting piece between the two counters. Some kind of moulding? trim? Thank you?
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 125 Answers
Granite needs to be color matched epoxied together at the seams. If they are sitting level and flush (and Solid) a home owner solution is to use matching silicone filling the seem then cleaning off with a good solvent. tape the top on both sides before starting. The second solution works to keep out food, but may not look great if they are not flush or have not been cut cleanly and the gap is not too wide. You will need suction cup turn buckles to pull them tight. Do not do any of the above if you are not comfortable with your skill level or feel it may damage your top. Granite can be stained using the wrong products.
Posted on Oct 13, 2013
IB4G2008
  • 3587 Answers
SOURCE: We have replaced our kitchen
the under counter inserts, made from plastic moldings(standard for dishwashers) are one approach. Having a custom frame built,and installed, is strongest long term solution. And all the better if it's a sliding type, for ease of service, which you WILL need sooner or later.
I'd call a local carpenter, and show them your issue, and get this done properly.
the granite will not do well, when it's penetrated at more than 25 to 40% of it's depth.
Posted on Mar 17, 2008
SOURCE: mounting brackets for granite countertop
This is the best way i have found. You must check this company out. Granite Grabbers www.GraniteGrabbers.com They are extremely simple mounting brackets secured with a very strong double sided adhesive. You do not have to drill you cabinets or deal with any expoy.
I have used them with excellent success, took 5 minutes to install
Posted on Feb 03, 2009
  • 2509 Answers
SOURCE: The brackets to hold the
You could have a handy person make some new brackets which attach to the new dishwasher's brackets with bolts but are made so that they line up with the existing worktop holes. You can probably use strips of soft metal with holes to fashion these.The dishwasher may have to sit slightly lower.
Posted on Dec 30, 2010
  • 18 Answers
SOURCE: need to stabilize machine and have granite
Ask a local granite fabrication shop to get you some dishwasher mounting clips. They look like a perforated disc of metal with a small nut brazed to one side. They come with a short screw that attaches through your dishwasher mounting tabs. Place your dishwasher where you want it relative to the cabinets and pick a hole in the mounting tabs that won't leave the clip protruding and attach the clip to the chosen hole. Use masking tape on the top of your dishwasher door, wipe the bottom of the granite and the top of the clip with acetone, then use a gel-type two part epoxy from your local hardware store to attach the clip to the granite. Use enough to make the epoxy push through the perforations in the clip as this is how the epoxy grips the clip. Push the clip to the bottom of the granite and close the dishwasher door, using a wood shim or two between the top of the door and the mounting tab/clip to push the clip tight to the granite. Pull the shims out once the epoxy has cured (check the instructions on the epoxy).
Feel free to contact me with any questions. Brandon Wiese - Brandon@StoneRepairman.com - http://.www.StoneRepairman.com
Posted on Mar 26, 2011
  • 4350 Answers
SOURCE: We have a Bosch SHE45M06UC/50
You glue on a wood strip, to the underside of the counter, then screw into that. Use construction adhesive. The wood strip needs to stick down no further than the counter edge treatment, so you normally cannot see this wood strip.
Posted on May 11, 2011
Which one has more heat resistant: Granite or Silestone? Explain?
Planning to refurbish your kitchen, Now-a-days, a wide range of choices for kitchen countertops are available in the market, which make you to choose the perfect one. In case if you are looking to select granite or Silestone for your kitchen worktops. Then, as per my knowledge both are popular choices, but he Granite is a very durable natural stone with a high aesthetic value. It is heat and scratch resistant but also porous and therefore possible to stain; it needs periodic maintenance. Where as the quartz used in countertops and flooring is a man-made combination of resins and crushed quartz. The resulting surface is non-porous, meaning it is more stain resistant than granite and requires less maintenance overall. For further detail explore at: Black White Granite Kitchen Worktops in Surrey Essex MKW Surfaces
Feb 29, 2016 | Green Bean Cleaning Products Commercial...
My black granite countertop has a stain which must have soaked thru seal, now shows a whitish spot, How can I fix this? Thanks
Remove Water Marks/Stains from Granite Countertops ...
? 2:55
https://www.youtube.com/watch?v=VO571n_4Jns
Jun 10, 2011 - Uploaded by KristyU2178
... the water mark/stain from my black granite countertop in mybathroom. ... @TheJefferyjones The stains ...
Removing Stains from Granite Countertops - YouTube
? 5:51
https://www.youtube.com/watch?v=hPPFe8902Zg
Oct 1, 2010 - Uploaded by MonkeySee
I left a bag of sweet potatoes on my black granite and there were some ... @Oxidized181 yes I have lots of ...
Stains on Black Galaxy Granite - Countertops
Jan 17, 2016 | Home
I cant figure out how to use the clips for a Franke topmount granite sink. No instructions came with the sink. It is a formica countertop.
We can't figure it out either! It seemed to come with undermount pieces (its not an undermount sink) and some blurry IKEA-style instructions. Been working on this 3 hours!
Anybody...???
Aug 04, 2010 | Franke Home
Installing cooktop into granite countertop
Put a bead of clear sylicone caulking around the cutout , then set the cooktop in place .
Aug 07, 2009 | Jenn-Air 30 in. CVE3401 Electric Cooktop
Pegasus Push Button Vessel Sink Drain with overflow
Put plumbers putty around the flange that will be in contact with the sink. When you put it into the hole, try to line up the overflow as good as possible. The nut that goes onto the bottom (tailpiece) has a rubber gasket that will go between the nut & the sink. Adding some plumbers putty here won't hurt. After all is secure, just remove the putty that squeezed out from tightening.
Feb 21, 2009 | RTO W/ Overflow Chrome 1 5/8" Vessel Sink...
Mounting brackets for granite countertop
Dec 19, 2008 | Dishwashers
Removing and reinstalling
There should be removabe clamps attatched to the bottom of the cooktop which tighten with a screw to the bottom of your countertop. Loosen the screws to the countertop, then remove the screws that attach the brackets to the cooktop. The cooktop should then be able to be pulled out.
Apr 07, 2008 | Jenn-Air 30 in. CVE3401 Electric Cooktop
Dishwashers Logo
59 people viewed this question
Top Dishwashers Experts
