I recently got a Macintosh c32 preamp and MC 2125 power amp. The left channel seems to drop out if i bump it or walk to heavily near it. I can get the channel to return by tapping on the volume knob or the expander knob of the preamp or even tapping on the case of the preamp I was wondering if anybody had heard of this problem and if it is an easy fix?
  • Audio Player... Master
  • 5,167 Answers
Very easy!
It's just a bad soldering joint somewhere. It just a question of looking around and then resoldering.
Posted on Oct 19, 2013
VOTIT
  • 2071 Answers
SOURCE: Sound through one channel
Only the right channel had a sound,the left channel is mute, whatever adjustment you did and whatever balancing you done nothigs happen,even you interchange the speakers. The problem is in the power amp. The STK IC there is busted already, it's better to change it with a new one so the performance become normal again.
Posted on Jun 17, 2008
mrwtech
  • 59 Answers
SOURCE: How do I connect a Polkaudio powered subwoofer (psw 125)
Connect a set of stereo RCA cables from the 'Output 2' on the Hafler to the line imputs on the Sub.Turn on the '1+2' output switch on the Hafler and rock out!
Posted on Dec 17, 2008
  • 85 Answers
SOURCE: Pop in left channel
Check your cabling,sounds like earth break
Posted on Jan 19, 2009
  • 4234 Answers
SOURCE: unbalanced LEDs> amplification problem, or mere graphic drop out?
This could be a defect in the metering circuit. In order to verify this, you should measure the output externally. Get that external measurement and post the results here. We'll continue from there.
Dan
Posted on Apr 12, 2009
freetek
  • 5568 Answers
SOURCE: Pioneer A110 Amplifier - quiet right channel.
> squirt some contact cleaner into it
An appropriate suggestion with one caution; look for a statement on the cleaner label that it will not harm plastics. I have seen some plastics not dissolve, but crack and disintegrate, along mold lines in particular. If you find no such statement use very sparingly and try to prevent over-spray.
Posted on Feb 24, 2010
What would be the probable cause of my konzert amplifier av-502 after replacing 2 power transistors npn & pnp in the left channel, the sound is distorted. i'ved checked the voltage across the spea
Check the bias resistors. They can burn out when power amp transistors fail. They will be very near to those two replacements. You can compare any parts using the right channel as a good. Readings and voltage measurements should be the same for both channels. Also the look of the parts. If a resistor is off-colour in the left, but not in the right you know something is up.
Jul 02, 2013 | Audio Players & Recorders
B&K AVP2000 left channel not working
Yes amps buzz when something gets near them - say a pen or probe and if you know what it is safe to touch a finger! Fortunatly for you the left channel is the same as the right. So if you believe it's the pre-amp work backwards from the where the power amp connects to the pre-amp, going through the pre-amp stage by stage - prodding the parts. Remember a buzz in the right a buzz in the left! No buzz in the left but one in the right fault found!
Ignore the power supply it's nothing to do with that as it's common to both channels.
Dec 30, 2012 | Audio Players & Recorders
Hello, I have inherited a McIntosh MC-7270 amp, and plan on wiring it to my two Bose 201s to test before selling. I need to know how to properly wire the speakers to the amp. The rear of the amp looks...
Well what you are dealing with is a HI-FI tube amplifier. The reason it has COM, 1, 2, 4 and 8 are because it does not have a transistor driven output. It has a transformer coupled output. The 1,2,4,and 8 are the different taps of the transformer in order to impedance match your load (speaker) with the tube power section. This amp is 270 per channel and your speakers are only suggested to 120Watts. You would use the Negative to the common terminal and the plus to your 8 ohm terminal on the Amp. This is a great amp, you should keep this and not sell it.
Jun 12, 2011 | Audio Players & Recorders
One channel of my McIntosh MC 2120 Stereo Power Amplifier Silent
is output amplifier is burned, check any burned fuse on the back. is high cmos power amplifier, need to be repaired. send to your top audio repair center.
Feb 16, 2010 | Mcintosh MC602 2-Channel Amplifier
NAD C340 The power amp is very muffled on the the left channel and right doesn't work work at all. Any ideas
it seems like your amp has a malfunction, it may be because some of the power transistors fried or the power IC
Aug 19, 2009 | Audio Players & Recorders
No Left Output
check stereo settings after that if it still persists your left channel is goin out
May 21, 2009 | Audio Players & Recorders
Left channel volume is very faint as compared to the right channe
It sounds like the preamp section is working but the power amp is not. Look at the power supply section and see if it is getting power to the power amp and if ok check the power transistors or IC.
Feb 13, 2009 | Yamaha Audio Players & Recorders
Dec 16, 2008 | Marantz PM7200 2-Channel Amplifier
Drop out of left channel, Adcom GFA5802
It sounds as if there is a broken solder joint somewhere that slowly opens up with heat. The other possibility is that an input or driver transistor is dying. Since the whole channel is dying, I would guess the broken joint and/or dying transistor are near the very input of the channel.
A tech can very easily find the spot by playing the amp until it starts to die, then spraying small bursts of freeze spray, one component or area at a time, until the amp suddenly comes back to life.
Aug 13, 2008 | Adcom GFA-5802 2-Channel Amplifier
Jun 14, 2008 | NAD C372 Amplifier
116 people viewed this question
 Grubhead
Grubhead
