Question about Brother DCP 115C All-In-One InkJet Printer
Brother DCP-150C problem = nothing is coming out of the paper eve
I have all 4 inks full on my Brother DCP-150C printer yet whenever I print a document, nothing is coming out of the paper. No nothing. Not even a smudge or sign of dot of color. What could be the problem? Help me on this.. Thanks.
    Scholar:
  • 93 Answers
Best thing you can do is first make sure all packing has been removed off the new ctgs, sometimes manufactureres have small tape covering the head which causes this issue, also if ctgs look good then go to print driver right click and go to properties and look for utilites or diagnostics and run full head cleaning to make sure there isn't dried ink clogging lines.
Hope it helps
TankMurdock
Posted on Apr 23, 2009
DCP 150C Brother printer not printing
Press Menu then select Ink Management then Test Print - Print Quality and MONO START. Come back with the result to help you
Dec 15, 2014 | Brother Office Equipment & Supplies
My brother dcp 150c doesn't print the red color
my brother dcp 150 when going to print it says unable to print any help?
Aug 22, 2012 | Brother DCP 115C All-In-One InkJet Printer
My brother DCP-165C has full ink which shows in the status monitor. in the test print only the colored ones in visible in the paper. but in the normal setting when i print nothing is there in the paper. ...
In most cases the printer driver software can have errors while being in use or is shut down. So to reset remove your printer from the PC and uninstall the printer software. Now reinstall the printer software and then connect the Printer to be detected as a new hardware as it will be installed. Now check the printer properties to see the ink levels.
Activate head cleaning before a test is taken . Sometimes it is possible that the head is not reacting to the need of the PC command or can be an issue with ink drying or
poor ink cartridge contacts.
Apr 27, 2011 | Brother DCP 165C Compact Color Inkjet...
Brother DCP-150C - just installed a new black cartridge (changed colour cartridges last week!) - printer will print but page comes out blank??
This may be because ink is clogged in the printhead. ? Place the clogged cartridge in about 1/4 - 1/2 inch of warm water for a few minutes. When ink starts to slowly leak out take the cartridge out of the water and dry it using a soft cloth to "Q-tip." Then place it back in your printer and run the print head cleaning utility that comes with your printer software. You may have to run this 2-4 times before printing quality is reestablished. If your print head is destroyed, as can happen, you will have to buy a cartridge and refill that cartridge before it is fully empty.
Feb 19, 2010 | Office Equipment & Supplies
Brother dcp-150c, black ink wont work
Ink may be new, but their nozzles may be blocked; depending on manner of storage. To be sure apply a folded tissue paper to the ink nuzzle and press firmly. If the tissue comes off well blotted with ink it means you still have a good amount of ink in it and the nozzle is not blocked. If not blotted or scantily blotted, it means ink is really low or nozzle is blocked. To be very sure of this, place nuzzle in a plate/saucer with a bit water so that the nozzle is soaked. Leave for about 10 minutes. Then apply the tissue again. If still not well blotted it means ink is really low or empty. If new you should return it for a replacement. In the case of blocked nozzles, the procedure may be repeated over to get results.
Feb 14, 2010 | Office Equipment & Supplies
I have replaced my cartridges because they were low.It now shows they are full but even though i have cleaned as instructed nothing will come from my yellow cartridge and very little from my magenta...
It sounds like the heads are clogged...may be cheaper to get a new unit than to have that unit professionally cleaned; however, if you choose to go that route, remember to go to the ink section first to check the prices of ink cartridges before you buy a printer since once you buy the printer if the ink is high, you are stuck with it. A good sight to use to check on printers is Dealtime. They give you a drop down window to select by price, or most popular...http://www.dealtime.com/xFS?KW=printers&CLT=SCH
Oct 27, 2009 | Brother DCP 115C All-In-One InkJet Printer
My Brother DCP-150C cant print, displays, UNABLE TO CLEAN"
Unable to clean either means there's a paper scrap in the clean station, or the ink overflow box is full and needs to be changed by a dealer. Sorry, no quick fix...
Jul 22, 2009 | Brother MFC-5840CN All-In-One InkJet...
Bad printing
plz ask your vendor for help because it is in warranty period
Jul 05, 2008 | Office Equipment & Supplies
Brother DCP 115C All-In-One InkJet Printer Logo
719 people viewed this question
CheckitRight
CheckitRight
Ron Dufek
Ron Dufek
James Cagle
James Cagle
