Question about Frigidaire Refrigerators
Frigidaire PLHS67EESB0 ice maker stopped not making ice and the ice ejector keeps turning and the machine keeps filing with water and overflows
    Scholar:
  • 50 Answers
If the ice ejector turns constantly, and water flows with each turn, you have a bad limit switch inside ice maker. This switch stops the motor inside, and thus the ejector, and allows for a freeze cycle. There are other possible problems but i suggest just getting a new ice maker. Not that hard to change out if you have any mechanical skills.
If you need further help, reach me via phone at https://www.6ya.com/expert/steve_24d988f3507f7480
Posted on Oct 12, 2013
dididsaythat
  • 291 Answers
SOURCE: ice maker water will not stop/overflows
either u got a bad ice maker or the spout going into the ice maker is leaking, ect.
Posted on Sep 03, 2007
  • 92 Answers
SOURCE: 10 yr old Frigidaire ice maker stopped making ice
check to make sure the fill tube is not plugged with ice if it is not then i would guess the valve is shot
Posted on Oct 31, 2007
roadbird383
  • 40 Answers
SOURCE: Frigidaire signaling water dispenser instead of ice maker
Sounds like the water solinoid valves are wired wrong.One activates The water dispenser.The other the ice maker.That, why every so often the water shoots out on the floor.The ice maker is telling the valve to open.
Posted on Dec 05, 2007
  • 1314 Answers
SOURCE: Frigidaire - FSC23F7DS - water dispenser not working but ice maker is
take out the crisper drawers and see if the water tank is frozen is the light on the dispencer lighting up when you depress the paddle and look up in the dispencer to see if the acuating paddis broken we will go from there
Posted on Feb 18, 2008
  • 12 Answers
SOURCE: Ice Maker leaking water in freezer and won't stop making ice
The filter should be before the fridge and should not affect it it sounds like the water valve from the fridge is defective .Other possibility is the icemaker head is defective and needs changing.
Posted on Mar 10, 2008
Frigidaire side by side Freezer only freezing top shelves, warm at the bottom
Its defrost issue.
Defrost cycle is not taking place on time or its not working at all.
Replacement parts can be purchased at any of the following web sites:
searspartsdirect.com
pcappliancerepair.com
appliancepartspros.com
repairclinic.com
partsselect.com
Before going to buy any parts directly.
Go through this troubleshooting help links.
This is list of refrigerator problems, which is normally faced in refrigerator.
You can go through the details, by clicking the link below:---
Refrigerator is not cooling properly?
http://technoanswers.blogspot.com/2011/06/refrigerator-is-not-cooling-properly.html
Both refrigerator and freezer not cooling properly in refrigerator?
http://technoanswers.blogspot.com/2011/06/both-refrigerator-and-freezer-not.html
The ice maker not working: ---
http://technoanswers.blogspot.com/2011/06/ice-maker-stopped-working.html
Compressor not running on refrigerator?
http://technoanswers.blogspot.com/2011/10/compressor-not-running-on-refrigerator.html
Water dispenser not working on refrigerator?
http://technoanswers.blogspot.com/2011/10/water-dispenser-not-working-on_19.html
Ice maker stopped making ice?
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-stopped-making-ice.html
Water Overflows in Ice maker and freezes inside?
http://alltypesofpartsreplacing.blogspot.com/2011/10/water-overflows-in-ice-maker-and.html
How to replace Ice maker assembly?
http://alltypesofpartsreplacing.blogspot.com/2011/10/how-to-replace-ice-maker-assembly.html
These will help.
Thanks,.
Dec 23, 2012 | Frigidaire Refrigerators
My Frigidaire refrigerator works find; Freezer stays cold but doesn't freeze food or ice
Its defrost assembly parts issue or the compressor is getting waek indication.
repairclinic.com
partsselect.com
These will help.
Thanks,.
Dec 23, 2012 | Refrigerators
I have a Frigidaire GSI 26, ffor the last couple of days it has been making a buzzing sound that lasts about thirty seconds to a minute, today the freezer quit working. the compressor is hot, as is th
These will help.
Thanks,.
Dec 22, 2012 | Refrigerators
FGHN2844LF4
These will help.
Thanks,.
Dec 22, 2012 | Frigidaire Refrigerators
Water keeps overflowing over the ice making coils
Do you mean that it is overflowing the sump tray into the bin? If so there are two things to check. First make sure the unit is level. Second their is a simple water float valve much like an old toilet float that keeps the sump full. Turn the machine off and make sure that the float will stop the water flow 100% when the sump water level is just over the bottom of the water pump impeller. If the float will not stop the water flow either the water pressure is too high or the float valve is bad and has to be replaced. In general water pressure should be between 20-40 psi.
Dec 18, 2010 | Ice-O-Matic ICEU220HA Undercounter Ice...
GE Icemaker stopped making ice. everything else
Try these steps
  1. Check the shutoff arm
  2. Check the supply valve
  3. Inspect the water supply line
  4. Test the shutoff switch
  5. Check the freezer temperature
  6. Inspect the ejector gear
  7. Test the ejector motor
  8. Test the ice mold heater
  9. Test the holding switch
  10. Test the water inlet switch
  11. Test the thermostat
  12. Test the water inlet valve
pls rate my suggestion.......
Jul 25, 2009 | GE Monogram ZDI15C Automatic Icemaker
Ice maker not making ice
my ice maker is not making ice what could be the problem, and there is not any water in the ice machine what do i need to look for
Jan 08, 2009 | Frigidaire FRS23KF7AB Side by Side...
The water supply line had gotten chewed by the dog. Now the we have the line repaired its up and running. But its got the same noise and not ice is dropping. The noise I am talking about is the same noise...
IF THE ICE MAKER IS TRYING TO DUMP ICE, IT MAY HAVE A PARTIAL CUBE JAMMING THE EJECTOR BLADES, KEEPING THEM FROM COMPLETING THEIR CYCLE. FEEL THE EJECTOR BLADES, ONE AT A TIME TO SEE IF THERE IS SOMETHING WEDGED BETWEEN THEM AND THE ICE MAKER MOLD. THERE SHOULD ALSO BE ICE CUBES IN ALL THE SLOTS, ALL THE WAY UP TO THE FRONT. IF NOT, THERE IS INSUFFICIENT SUPPLY OF WATER TO THE ICE MAKER.
Apr 10, 2008 | Refrigerators
Icemaker
Look at the ice maker and see what position the ejector bar (white bar with fingers that turns and ejects the ice).  Looking at the ice maker from the front (front is white plastic cover) the ejector bar should be in the 2-3 o'clock position .  If it is not then the module is broken.  In this case the module and ice maker thermostat need to be replaced.  If not sure how to do this repair then just buy a new ice maker.  Let me know what you find and we can go further if necessary.  This is the first thing to check.
Oct 20, 2007 | Kenmore 44109 / 44102 Side by Side...
Refrigerators Logo
85 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
