Question about Craftsman Garden
Bad head gasket
Sparkplug will not tighten
  • Craftsman Master
  • 7,482 Answers
Hi
Sounds like you have a stripped head, normally this happens when the plug is over tightened or when the spark plug ceases to the head.
You will have to go to your local auto parts store and explain your problem, they have the answer to your problem.
It is called a Helicoil and Tap.
You can find one at this webpage...
Bud
http://www.amazon.com/Helicoil-5334-14-Save-A-Thread-Thread-Repair/dp/B0002SRF4O/ref=sr_1_3?s=automotive&ie=UTF8&qid=1381631152&sr=1-3&keywords=spark+plug+hole+repair+kit
Posted on Oct 13, 2013
I have a 1999 GMC 350 I need the head torque specs just replace head gaskets can anyone help
  1. Clean the cylinder gasket surfaces on the engine block.
  2. Inspect the dowel pins (cylinder head locator) for proper installation.
  3. Clean the cylinder head gasket surfaces on the cylinder head.
  4. Place the NEW cylinder head gasket in position over the dowel pins (cylinder head locator).The cylinder head gasket is not directional and may be installed using either side facing the engine block.
  5. Install the cylinder head to the engine block. Guide the cylinder head carefully into place over the dowel pins and the cylinder head gasket.
  6. Install the cylinder head bolts.
  7. Tighten the bolts in the sequence shown in the image below on the first pass to 30 [n-m] (22 lb ft).
  8. Use a torque angle meter in order to tighten the cylinder head bolts in sequence on the final pass. Tighten:
    • Tighten the long bolts (1, 2, 5, 6, 9, 10, and 13) on the final pass in sequence to 75 degrees.
    • Tighten the medium bolts (14 and 17) on the final pass in sequence to 65 degrees.
    • Tighten the short bolts (3, 4, 7, 8, 11, 12, 15, and 16) on the final pass in sequence to 55 degrees.
  9. Measure the NEW spark plugs for the proper gap.Adjust the spark plug gap if necessary.
    Specification:
    Spark plug gap to 1.52 mm (0.060 in)
  10. Install the NEW spark plugs. Tighten:
    • Tighten the spark plugs for a USED cylinder head to 15 [n-m] (11 lb ft).
    • Tighten the spark plugs for the initial installation of a NEW cylinder head to 30 [n-m] (22 lb ft).
  11. If reusing the engine coolant temperature (ECT) gauge sensor, apply sealant GM P/N 12346004 to the threads of the ECT gauge sensor.
  12. Install the ECT gauge sensor.Tighten:
    Tighten the ECT gauge sensor to 20 [n-m] (15 lb ft).
Mar 20, 2018 | GMC Cars & Trucks
What's the problem when I hit the gas it has a miss in it especially when I try to pass a vehicle, it's almost like it could be a exhaust leak or a leak in the the vacuum line?
Exhaust leak won't cause a miss, vacuum leak can cause bad idle, but any of several other things could cause your miss, including:
Bad sparkplug
Bad plug wire
Bad injector
and, more serious issues like
Bad valve
Head gasket
Feb 04, 2016 | Cars & Trucks
What causes air to seep around the spark plugs on a 2002 Chrysler voyager
Loose sparkplug
cross threaded sparkplug
over compressed washer on sparkplug
worn threads in the head
Just put new ones in. Start them by hand and turn using a sparkplug socket and extension bar until tight. Add the ratchet bar or T-Bar and tighten a further one eighth turn.
Jan 10, 2016 | Chrysler Cars & Trucks
Engine misses when going up incline until I let off gas
Missing under load can be caused by a number of different things including:
a bad sparkplug
bad ignition wires
if your car is old enough,
bad distributor cap
Also, it's possible it's missing all the time, and you only notice it under load. If so, then add
bad valve
bad piston or rings
blown head gasket
Apr 18, 2015 | Cars & Trucks
My 2000 5hp Yamaha engine runs but leaking water
Is it above or below where the sparkplug is? If it's below, may possibly be just a head gasket needs replacing.
If it's above or beside then it's a cracked a cylinder head. Depending on how bad it is, an engineering shop might be able to weld it or else it's a replacement part.
Oct 11, 2014 | Yamaha Motorcycles
Strong petrol smell
When your engine misfires fuel is still being pumped into the engine, it's just not being ignited. You need to find the cause of the misfire first. It could be: a bad sparkplug, a bad sparkplug wire, a leaking head gasket, a bad ignition coil, or cracked engine block. I'd start with the spark plugs first, then the ignition coils as they commonly fail. Good luck!
May 06, 2013 | Volkswagen Cars & Trucks
What would cause my 2001 dr-650 to leak oil at the top of the cylinder near the exhaust only when running? is it difficult to repair?
Sounds like a bad head gasket. Try the following. Remove the head cover and tighten down the head bolts. Don't tighten the cam bolts. Remount the cover and hope that sealed up the leaking gasket. If not, the head will need a new gasket. Remove the head cover and sparkplug, put the piston at TDC compression then note the cam gear reference mark)s) position. The gear will need to go back in in the exact same position. Remove the cam gear and dismount the chain from the cam. Hook a wire to the cam chain so it can't fall into the tranny. Now pull the head off and remove the carbon from the head an piston then replace the gasket. It would be a good idea to reseat the valves since you have the head off. I don't really recommend this repair for the beginner. Please rate my answer. tombones49_91.gif
Apr 20, 2011 | 2001 Suzuki DR 650 SE
1998 chevy malibu internal water leakage, water mixed with oil-white smoke coming out of tailpipe on 3.1 engine. water drains from coolant tank through engine **** pit plug removed
Hi, the problem you are having is with the cylinder head gasket and it sounds like its quite bad so the chances are the head will need skimming and testing to see if it has a crack in it.
if your doing this yourself you will need to get a workshop manual as the head bolts have to be undone in a certain order and the same when you do them up and you also need to tighten them up to correct torque settings.
this is a very big job and will need a few days to get sorted and the head will need sending off to be machined.
let me know if you need further assistance.
give me a shout back if you need anything og
please rate this post as i have a whole page of unrated posts
Aug 26, 2010 | 1998 Chevrolet Malibu
Specs on torquing head bolts on 1988 pontiac lemans aka daewoo lemans aka passport optima. also do i need gasket sealer anywhere or gaskets only when doing a head job on this car?
firstly tighten in sequence to 20Nm all round, then tighten to 30Nm all round,then tighten 90 degrees all round, and finally tighten a further 90 degrees all round. if you taken head off you should replace gasket or just use gasket sealer if you cant replace, just replace the head bolts, dont reuse or they may break
Jul 24, 2009 | 1988 Pontiac LeMans
Garden Logo
32 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Jim Parker
Jim Parker
Dean Gruber
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
