Question about Invacare Supply Group Invacare Scooter Lynx L-3 L-4 Transaxle Differential
We were given a lynx lx-3 it would run and then shut down, you would have to shut it off and then turn it back on to get it to work. Then it shut down and will not move at all it has a full charge, the light is still working and the scooter is getting power but it seems to not be getting power to the throttle what can I do to fix this.
One battery maybe dead check seperately
Posted on Oct 20, 2013
2 Suggested Answers
  • 1428 Answers
SOURCE: What is Invacare Supply Group?
Really i don't know the charge. Contact Fixya Team on support@fixya.com
Visit http://safemanuals.com/user-guide-instructions-owner-manual/LYNX/4TS630A-_E
Cheers
Posted on Mar 11, 2010
Where will I find the reset button on my scooter ?
With this kind of issue, when you believe something is not right. Have the charger and the batteries checked out before buying new batteries.
May 11, 2014 | Invacare Lynx Lx-3 Scooter Model...
Problem with keyboard, tiny water spillage, big damage
How to enable On-Screen Keyboard in Ubuntu 10.04 (Lucid Lynx)
Turning on the on-screen keyboard in Ubuntu Linux is a little more complicated than it should be. These tips should work for any version of Ubuntu within the last few years, but I'm using Ubuntu version 10.04 Lucid Lynx.
The simple way to enable the on-screen keyboard is to run the program from the Terminal:
$ onboard
However, if you cannot use the keyboard, you cannot type. On to method 2:
  • Go to System -> Preferences -> Assistive Technologies in the Ubuntu menu.
  • Select "Enable assistive technologies".
  • Click "Preferred Applications".
  • Under Mobility, select onBoard from the drop-down menu. Check "Run at start".
  • Log out and log back in, and the On Screen Keyboard is now enabled.
If you want to enable the on-screen keyboard at the login screen, please read my VMware Lucid Lynx guide, it's explained as part of that tutorial.
Jan 19, 2013 | Computers & Internet
I have a lynx 3 when I'm riding it will just stop
Lose connection OR brushes in the motor are worn - I would expect brushes to last a very long time. You might remove and inspect them. Removal is by a screwdriver - They are the large screw looking devices on the back of the motor.
The last item would be a temperature sensor in the motor or in the drive electronics. This would shut down the current to the motor in the event something gets too hot. It could also be faulty.
If you battery is old, the voltage may be too low, and automatic shutoff might occur. Simply measure the voltage WHILE THE CART IS MOVING. Measuring it while you are at standstill will give a false high voltage.
Dec 31, 2012 | Health & Beauty
I have a Hayward Power-Flo LX SP1515-Z2-EBK3 that is being used to pump water through 2-4x8 solar water heater panels. The pump intake is 1 1/2 inch, discharge out is also 1 1/2 inch. The pump is located...
I have a 3/4 hp hayward pumping thru solar panels, too. 1-1/2 discharge thru 50 ft of 2inch pipe, up 12 ft then thru (4) 4x12 panels. Mine is on 115 volts ac.
You have plenty of pump and when you run a pump with low flow, amperage is low. You are not tripping your breakers, it sounds like the pump is overheating. Is it hot to the touch when it shuts down?
Do you have an ammeter so you could check your amps?
What size wire is running the 60 ft to the pump?
I don't have any other ideas to share.
Gary
Sep 06, 2011 | Hayward Power Flo Lx
Motor stopped dead during slow turn on grass, neons light up,but it immediatly shuts down again lights ok motor stays dead.
Hi roybruce
Sounds exactly like a brake problem.
To check this run the scooter as far as it will go untill it shuts down or 10 minutes which ever occurs first.
Then being careful not to get burned touch very carefully with your finger the brake. Located at the end of your motor attached to the free wheel lever.
This could be very hot so be careful.
If the brake or motor is hot replace the brake. If the brake is cool to the touch you could have low voltage. Have your batteries load tested to make sure. Replace batteries if needed.
Good Luck
Tim
May 03, 2011 | Invacare Supply Group Invacare Scooter...
My crative zen moziacv lx shut down
charge is then if dat doesnt work go to zen website and get the mp3 player recover program
Feb 10, 2009 | Creative Labs Zen Touch MP3 Player
Lynx fridge freezer the freezer is working the fridge has stopped
check if there are frost at the back of the freezer wall, if there is then you have a defrost issue.
if not, check the vents if air is coming out on the fridge side. close the freezer door, press the door switch on the fridge side and feel the air. if there is no air, the evaporator fan could be shut.
if there is little air, check the vent, insert a small rigid wire, push the vent or flapper open and make the air stronger. you have a vent controll problem.
if there are ice in the vent, thaw it out and hope it won't freeze again.
Jan 01, 2009 | Refrigerators
Problems with car
At about 140,000 miles it would run a few miles and all of a sudden shut off. Turns out it was a bad computer. After replaced, never happened again. No other problems with this car.
May 14, 2008 | 1983 Mercury Lynx 2 Door
Open Questions:
See all Invacare Supply Group Invacare Scooter Lynx L-3 Questions
Invacare Supply Group Invacare Scooter Lynx L-3 L-4 Transaxle Differential Logo
197 people viewed this question
Top Invacare Supply Group Health & Beauty Experts
wcdoc1953
wcdoc1953
Robin Hill
Robin Hill
Are you an Invacare Supply Group Health and Beauty Expert? Answer questions, earn points and help others
