Question about Samsung WF328AAW Front Load Washer
Pcb wiring what is the PCB?? Is it expensive or should replace washer 5 yrs old?????
    Problem Solver:
  • 5 Answers
Its the Printed Circuit Board, basically the main brain of the washer. They range from 70-170 depending on model. If you have a service plan on the washer, it might be worth it, but if not, I personally would replace the washer.
Posted on Oct 12, 2013
Our Frigidaire front load washer is only 4 yrs old and we are having trouble with the final spin cycle. It turns ok but when it is done there is water in the bottom of the basin and all the clothes a
Sounds like the rinse hold button is selected.if that is okay check the penny trap at the bottom front of machine.this will collect buttons coins etc and prevent proper drainage.if not then the relays on the pcb board have probably failed as the machine usually does not reach proper spin speeds as a result.really about checking through the above.replacement boards are expensive but sometimes it is possible to source parts from eBay.
Nov 19, 2014 | Frigidaire Washing Machines
E010
IR330, step 1- this Error is the main motor fails to rotate normally, does the main motor rotate until E010 turn on? if yes go step 5, if no step 2- harness wiring connectors around the main motor normal? if no correct the wiring, if yes step 3- does the voltage of J102-B12 on the controller pcb change to 0 VDC while the main motor is rotating?, if no replace main motor ( main motor driver pcb), if yes step 4-is there 24 VDC generated between J204-3 and J204-4 on the composite power supply PCB, if no replace the composite power supply PCB, if yes step 5 is the voltage of J102-B11 on the DC controller PCB about 5 VDC during WMUP? if no replace DC controller PCB. if yes step 6- Is there continuity of the harness between the image processor PCB and DC controller PCB normal J714-A14 to J113-A7 also 714-A16 to J113-A5 if yes to if no replace the harness if yes replace the DC controller PCB and the Image processor PCB.
Nov 30, 2013 | Printer Essentials Canon Gpr-2...
Ge Washer GSLP1100D0WW keep getting a dr code near the end of the cycle it stops at 28 mins and then when i hit start it counts at 30 gets down to 28 again and does the same dr code again
Your problem lies in the PCB assembly, or pump motor, most likely the PCB assembly.
1. open lid
2. remove control panel screw covers & screws
3.lift control panel
4. remove screws connecting PCB assembly to control panel
5. Remove PCB from control panel by pushing PCB from right to left.
6. Disconnect wire harness connectors from PCB.
Hope this helps!
Jan 04, 2011 | GE Spacemaker WSLP1100D Top Load Washer
When i print using my docuprint 203A fuji xerox, the printout result paper was cover with black all over. what does this mean?
This is a rebadged Brother Printer.
Possible causes for a solid black output:
1 Corona failure
Is the corona wire dirty?
Clean the corona wire with the wire cleaner.
2 Corona wire broken?
Replace the drum unit
3 Are the charge electrodes between the printer body and
the drum unit dirty?
Clean both electrodes.
4 Harness connections?
Is the laser unit connected to the main PCB correctly?
Connect the harness between the laser unit and the main PCB
correctly.
5 High-voltage power supply PCB failure
Is the problem solved after replacing the high-voltage
power supply PCB?
Replace the highvoltage power supply PCB.
6 Main PCB failure
Is the problem solved after replacing the main PCB?
Replace the main PCB.
7 Laser unit failure
Is the problem solved after replacing the laser unit?
Replace the laser unit.
Good Luck!
May 12, 2010 | Fuji Xerox® DocuPrint C3055DX Laser...
Machine wont start after replacing blown pcb module
Check whether you rcd the right version of the PCB model. Compare with the old one.
Mar 31, 2010 | Siemens WXLM112GB Front Load Washer
Nothing comes on. Outlet has power. 2 yrs 1 month old.
This sounds like the main PCB is blown. it may be worth checking the main PCB for damage and a blow fuse if you can locate one- caused likely by a power surge (maybe claim insurance), faulty dryer motor, faulty element or wiring fault in dryer. cheers
Mar 23, 2009 | Fisher and Paykel DEGX1 Electric Dryer
Servis washing machine fills but wont turn
is it a brush motor? if so the brushes may be worn, secondly the motor control pcb may have blown. also check the wiring.
Mar 18, 2009 | Washing Machines
I NEED PCB BOARD FOR HOTPOINT WF865 WASHING MACHINE
I have checked the Hotpoint web site, and a pcb is £114.00.
You also need the eprom which plugs into the pcb,this is another £24.00, and is unprogrammed, this means that it is a blank memory chip, and has to have the programmes put into memory.
This is something that only Hotpoint can do, so you have to add the cost of calling an enginner to the cost of the parts.
This as you can see, makes it very expensive to repair.
It would be in excess of £200.00.
There is one other alternative, and that is, if the washer is less than 5 years old, then you should be covered by the Hotpoint 5 year part guarantee, but you would have to confirm this with Hotpoint.
It would certainley be cheaper to do it this way.
Plz rate my solution.
Thanks,
Jan 11, 2009 | Hotpoint Ultima WF865 Front Load Washer
PCB replacement
it seems that you are talking about the two wires that fit onto the back of the board where there is a black component that is square on the right hand side when looking from the front the wires fit within the black unit. i cannot remember which way around though. i will post again when i next do a wma repair ,tony.
May 22, 2007 | Hotpoint Aquarius WF000 Front Load Washer
Samsung WF328AAW Front Load Washer Logo
128 people viewed this question
Top Samsung Washing Machines Experts
Jaime Hernandez
shaun taylor
Are you a Samsung Washing Machine Expert? Answer questions, earn points and help others
