Question about SK Hand Tool Altenator / Power Steer / Air Pump Pulley Puller
Put new power steering hoses on 1999 olds alero now only getting power steering turning left no power turning right
    Sergeant:
  • 216 Answers
This is generally cause from a air locked system. You will have to arm strong turn the wheel to the side that isn't working and back several times to get the air out of the system to get it working again.
I recommend jacking up the car to make this task easier.
You will also have to add more power steering fluid to the system.
Posted on Oct 20, 2013
99 Olds alero will only turn to the right. On quick inspection found that the rack and pinion moves with turning the wheels. Is it supposed to?
The whole rack & pinion does NOT move! Only the rod out of either end of it. If the main body, where the hoses connect, is moving the mounting bolts are missing, or broken.
Normally any vehicle with rack & pinion steering, that will not turn left equals a bad rack & pinion.
The "wont turn left" is the classic industry wide indicator that the rack & pinion is worn out.
Aug 21, 2011 | 1999 Oldsmobile Alero
On a 99 Olds Alero, in the return lines of the power steering hoses, which place does the high pressure hose attach to?
RETURN TURN LINE GOES TO THE LEFT OF RACK PINION AND HIGH PRESSURE HOSE GOES TO THE RIGHT OF RACK PINION.LOOKING AT POWER STEERING PUMP HIGH PRESSURE HOSE THICK HOSE SCREWS INTO POWER STEERING PUMP.WHILE LOW PRESSURE HOSE HAS A HOSE WITH A CLAMP THE LOW PRESSURE HOSE HOOKS TO TOP OF POWER STEERING PUMP.LOW PRESSURE DONT SCREW INTO POWER STEERING PUMP IT IS HELD IN PLACE BY A HOSE SMALL CLAMP.
Jun 24, 2011 | 1999 Oldsmobile Alero
Changeing a power steering pump
CHANGING POWER STEERING PUMP YOU HAVE TO PLACE A DRAIN PAN UNDER THE VECHICLE. SIPHON OUT POWER STEERING FLUID WITH A SIPHONER DONT USE YOUR MOUTH TO SIPHON SWALLOWING POWER STEERING FLUID CAN BE FATAL MAKE YOU SICK.WHEN ALL POWER STEERING FLUID IS REMOVED FROM POWER STEERING PUMP.REMOVE DRIVE BELT.THEN REMOVE THE POWER STEERING PUMP.THEN YOU HAVE TO REMOVE THE POWER STEERING PUMP PULLEY THE NEW POWER STEERING PUMP DONT HAVE A PULLEY YOU HAVE TO HAVE REMOVE PULLEY FROM THE OLD POWER STEERING PUMP.YOU NEED A PUMP PULLEY REMOVER AND A PULLEY INSTALLER.YOU CAN TAKE OLD POWER STEERING PUMP AND NEW POWER STEERING PUMP TO A MACHINE SHOP.THEY WILL REMOVE PULLEY OFF OLD PUMP PRESS IT ON NEW POWER STEERING PUMP.THAT WOULD BE CHEAPER THAN BUYING THE PULLER AND INSTALLER.GO TO AUTO PARTS STORE BUY NEW HIGH PRESSURE LINE O RING GOES TO PRESSURE LINE GOING INTO POWER STEERING PUMP.ONCE YOU GET NEW PUMP READY PULLEY BEEN PRESSED ON.TAKE POWER STEERING PUMP HOME PUT IT ON. BLEED POWER STEERING SYSTEM.WHAT YOU DO WHEN YOU GET NEW PUMP INSTALLED HIGH PRESSURE LINE IN PLACE.PUMP BOLTED IN DRIVE BELT ON POUR POWER STEERING FLUID IN POWER STEERING PUMP UNTIL FLUID LEVEL STOP DROPPING AND YOUR LEVEL ON POWER STEERING DIP STICK AT COLD LEVEL.NOW START CAR UP LET IT IDLE FOR 3 MINUTES.THEN TURN OFF ENGINE CHECK POWER STEERING FLUID IF FLUID LEVEL DROP ADD LITTLE MORE UNTIL LEVEL ON DIP STICK ON COLD MARK DONT OVER FILL.NOW SAFELY RAISE SUPPORT FRONT OF VECHICLE. START THE ENGINE.TURN STEERING WHEEL FROM ALL THE WAY FROM LEFT TO RIGHT DONT STOP LOCK WHEEL .GO LEFT TO RIGHT SEVERAL TIMES.THEN TURN OFF ENGINE CHECK FLUID LEVEL.IF ALL IS GOOD LET VECHICLE BACK DOWN LET IT SIT FOR A WHILE CHECK FLUID AGAIN.DONT DRIVE VECHICLE IF POWER STEERING PUMP MAKE NOISES OR YOUR STEERING FEEL STIFF HARD TO TURN.JUST MAKE SURE FLUID LEVEL RIGHT AND DRIVE BELT TIGHT GOOD LUCK.
Nov 02, 2010 | 1999 Oldsmobile Alero
Where is the camshaft position sensor on 1999 olds alero?
ON THE 4 CYLINER ENGINE CAMSHAFT SENSOR LOCATED AT THE LEFT DRIVERS SIDE OF THE TIMING COVER. THE V - 6 ENGINES CAMSHAFT POSITION SENSOR LOCATED AT THE FRONT OF ENGINE BLOCK BELOW THE POWER STEERING PUMP.
Feb 13, 2010 | 1999 Oldsmobile Alero
Which hose is on the bottom of the power steering pump of a 1999 Oldsmobile Alero?
LOOKING AT POWER STEERING PUMP YOUR LOW PRESSURE IS THE HOSE WITH A HOSE CLAMP.THE HIGH PRESSURE HOSE IS BIGGER AND HAS METAL LINE ATTACH TO IT.
Feb 08, 2010 | 1999 Oldsmobile Alero
Remove/replace power steering pump on a 2002 Olds alero. Works perfect-except whining noise-after I emptied/refilled the sump with new prestone power steering fliud!
Make sure that u get all the air out by turning the steering wheel from left to right.. And most important make sure the power steering fluid is for GM product.
Hope this helps..
Jan 26, 2010 | 2002 Oldsmobile Alero
I have a olds alero. I just replaced the pulley and power steering pump. after I replaced it and put back the hoses and belt. I turned my car on and got a loud grinding noise and some smoking out from the...
seems like the pressure line to the rack&pinion is plugged.open the line at the rack see if fluid flows if not replace line if fluid flows then replace the rack.
Jan 14, 2010 | 2000 Oldsmobile Alero
How do you replace power steering hoses on 1999 Alero with 3.4l
disconnect battery make sure your radio is turn off first so you want lose radio code. you have to reprogram it again before it plays. you need to remove drive belt . alternator and air filter. to get your arm to it.have to remove the lower transmission mount its going to be in your way.remove power steering fluid with a siphoner or large syringe. good luck.
Apr 02, 2009 | 1999 Oldsmobile Alero
SK Hand Tool  Altenator / Power Steer / Air Pump Pulley Puller Logo
64 people viewed this question
Top SK Plumbing Experts
Gil Shultz
Tony Crow
Dan Apthorp
Are you a SK Plumbing Expert? Answer questions, earn points and help others
