Question about Daewoo Washing Machines
I have a daewoo washing machine model DWD-F1011
I have a daewoo washing machine model DWD-F1011 and it stops before the last spin and gives error code EO . Any idea what that might be?
    Problem Solver:
  • 5 Answers
I believe the EO code means the pump is blocked, and you will have to clear the pump for it to work again.
Posted on Oct 12, 2013
2 Suggested Answers
SOURCE: daewoo DWD-F1011 PFE error code
I hd zs problem before,no problems in z water outlet,z pump
Posted on Dec 19, 2011
Daewoo washer DWD-F1011, WATER OVERFLOWING, HOW TO SOLVE THIS PROBLEM???
replace the water shutoff solenoid valve assembly
in the mean time when the machine is full turn the tap off
change the hot water hose over to the cold water tap and use the hot water solenoid button
Sep 05, 2016 | Daewoo Washing Machines
Daewoo DWD-F1011 1E error code I have a daewoo washing machine model DWD-F1011 and it start working the wash before no working spin and gives error code 1E. Any idea what that might be?
I do not believe that is a 1E I think it's an IE error code which would be water inlet wiring or something like that. Here is the code list, scroll down until you find IE, Daewoo errors start at E2, hope this helps.
http://removeandreplace.com/2015/11/02/daewoo-washing-machine-error-fault-codes/
Aug 30, 2016 | Daewoo Washing Machines
I have a Daewoo washing machine DWD-F1011 S, 7 KG..IT STOPS AND gave us an error with code E8.. HOW CAN WE SOLVE IT?
this is what I found E8 Washing machine motor error detectedA fault has been detected with the main drive motor.
  • Check motor connection block
  • Abnormal loading condition
Mar 13, 2015 | Daewoo Washing Machines
E9 message and machine stops
Jayshree, E9 error, pressure sensor error/water sensor error.
Replace water level sensor. The error display disappears if power button is turned off and on.This is what the service manual states.
Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Daewoo DWD M103 Service Manual Page 15 of 16
Daewoo CV701PC Service Manual Page 26 of 52
Daewoo Washing Machine Error Fault Codes
Washing Machine pressure switch
Apr 20, 2014 | Daewoo DWD M1031
Where is daewoo's company in cairo, egypt? I have any problem with my washing machine.
I have DAEWOO Washing machine DWD F1011. Whithin few years water started leaking through the drive shaft and ball bearing damaged. I need service manual for how to change the ball bearing or is there any repairer in Heliopolis, Cairo area?
How many year the machine is guaranteed??
Thanks lot.
Panchal
Aug 19, 2010 | Washing Machines
Daewoo DWD-F1011 PFE error code
Nov 16, 2009 | Daewoo Washing Machines
Error codes
If this machine is like other of its type then you may find the manual taped to the inside of the machine near the bottom side panel.
open the bottom access panel (3 screws on bottom front lip) and look for it as it will have the codes. near where the filter is .
while you were down there cleaning the filter did you check that the pump impellers move freely and were not clogged with any debris.
Jan 28, 2008 | Maytag EPIC MFW9700S Front Load Washer
Error codes
if this is a fridgidaire washer, I guess it's a clogged coin catcher. You have remove the front access panel and clean it out. I am working on that now.
Nov 05, 2007 | Washing Machines
Washing Machines Logo
278 people viewed this question
Top Daewoo Washing Machines Experts
Owen Barnes
dweatherby
Are you a Daewoo Washing Machine Expert? Answer questions, earn points and help others
