Question about SK Hand Tool Altenator / Power Steer / Air Pump Pulley Puller
New power steering hoses replaced power steering only works turning left do hoses need to be bled?1999 olds alero 6 cyl.
  • 3,382 Answers
Sounds good but this is a pluming area not an automotive area.
Posted on Jun 17, 2014
Put new power steering hoses on 1999 olds alero now only getting power steering turning left no power turning right
This is generally cause from a air locked system. You will have to arm strong turn the wheel to the side that isn't working and back several times to get the air out of the system to get it working again.
I recommend jacking up the car to make this task easier.
You will also have to add more power steering fluid to the system.
Oct 12, 2013 | SK Hand Tool Altenator / Power Steer /...
99 Olds alero will only turn to the right. On quick inspection found that the rack and pinion moves with turning the wheels. Is it supposed to?
The whole rack & pinion does NOT move! Only the rod out of either end of it. If the main body, where the hoses connect, is moving the mounting bolts are missing, or broken.
Normally any vehicle with rack & pinion steering, that will not turn left equals a bad rack & pinion.
The "wont turn left" is the classic industry wide indicator that the rack & pinion is worn out.
Aug 21, 2011 | 1999 Oldsmobile Alero
On a 99 Olds Alero, in the return lines of the power steering hoses, which place does the high pressure hose attach to?
RETURN TURN LINE GOES TO THE LEFT OF RACK PINION AND HIGH PRESSURE HOSE GOES TO THE RIGHT OF RACK PINION.LOOKING AT POWER STEERING PUMP HIGH PRESSURE HOSE THICK HOSE SCREWS INTO POWER STEERING PUMP.WHILE LOW PRESSURE HOSE HAS A HOSE WITH A CLAMP THE LOW PRESSURE HOSE HOOKS TO TOP OF POWER STEERING PUMP.LOW PRESSURE DONT SCREW INTO POWER STEERING PUMP IT IS HELD IN PLACE BY A HOSE SMALL CLAMP.
Jun 24, 2011 | 1999 Oldsmobile Alero
Where is the camshaft position sensor on 1999 olds alero?
ON THE 4 CYLINER ENGINE CAMSHAFT SENSOR LOCATED AT THE LEFT DRIVERS SIDE OF THE TIMING COVER. THE V - 6 ENGINES CAMSHAFT POSITION SENSOR LOCATED AT THE FRONT OF ENGINE BLOCK BELOW THE POWER STEERING PUMP.
Feb 13, 2010 | 1999 Oldsmobile Alero
Which hose is on the bottom of the power steering pump of a 1999 Oldsmobile Alero?
LOOKING AT POWER STEERING PUMP YOUR LOW PRESSURE IS THE HOSE WITH A HOSE CLAMP.THE HIGH PRESSURE HOSE IS BIGGER AND HAS METAL LINE ATTACH TO IT.
Feb 08, 2010 | 1999 Oldsmobile Alero
Remove/replace power steering pump on a 2002 Olds alero. Works perfect-except whining noise-after I emptied/refilled the sump with new prestone power steering fliud!
Make sure that u get all the air out by turning the steering wheel from left to right.. And most important make sure the power steering fluid is for GM product.
Hope this helps..
Jan 26, 2010 | 2002 Oldsmobile Alero
I have a olds alero. I just replaced the pulley and power steering pump. after I replaced it and put back the hoses and belt. I turned my car on and got a loud grinding noise and some smoking out from the...
seems like the pressure line to the rack&pinion is plugged.open the line at the rack see if fluid flows if not replace line if fluid flows then replace the rack.
Jan 14, 2010 | 2000 Oldsmobile Alero
2001 Jeep Grand Cherokee, steering noise, restricted lock
There's a technical bulletin on that from Chrysler....The power steering lines need to be replaced. I have the same problem as you see this link - http://www.wjjeeps.com/tsb.htm#STEERING
SUBJECT:
Steering Honk On 4.0L And 4.7L LHD Grand Cherokee Vehicles
OVERVIEW:
This bulletin involves the replacement of the power steering pressure
and return hoses and tube.
MODELS:
1999 - 2002 (WJ) Grand Cherokee (Domestic and International Markets)
2001 - 2002 (WG) Grand Cherokee (International Markets)
NOTE: THIS BULLETIN APPLIES TO 1999 - 2000 4.7L AND 1999 - 2002 4.0L
GRAND CHEROKEE VEHICLES THAT ARE LEFT HAND DRIVE (LHD) AND
ARE NOT EQUIPPED WITH HYDRAULIC COOLING.
SYMPTOM/CONDITION:
Some vehicles may exhibit a honk-like sound from the power steering
system. This sound occurs most often during a low speed right hand turn,
as would occur during parking lot maneuvers.
DIAGNOSIS:
If the customer indicates that the above condition is present, perform the section of
the Repair Procedure that is appropriate for the equipped engine.
PARTS REQUIRED:
Qty. Part No. Description
1 04883077 Fluid, Power Steering (MS-5931 quart)
1 05080950AA Hose, Pressure (4.7L)
1 52088116AB Fitting, Pressure Hose - Quick Connect At Pump (4.7L)
19-005-02 -2-
1 05080951AA Hose, Return (4.7L)
2 **06504502** Clamp, Hose (4.0L or 4.7L)
1 **52088452AE** Hose, Pressure (4.0L)
1 **52088774AC** Hose, Return (4.0L)
1 **52088775AB** Tube, Return (4.0L)
6 **34201631** Rivet, Plastic Black (Front Fascia - 4.0L)
1 **06102141AA** Screw, Pressure Hose (6 mm - 4.0L)
REPAIR PROCEDURE:
**IF VEHICLE IS EQUIPPED WITH A 4.0L ENGINE:**
1. Remove the front fascia panel.
Fig.
Aug 24, 2009 | 2001 Jeep Grand Cherokee
How do you replace power steering hoses on 1999 Alero with 3.4l
disconnect battery make sure your radio is turn off first so you want lose radio code. you have to reprogram it again before it plays. you need to remove drive belt . alternator and air filter. to get your arm to it.have to remove the lower transmission mount its going to be in your way.remove power steering fluid with a siphoner or large syringe. good luck.
Apr 02, 2009 | 1999 Oldsmobile Alero
SK Hand Tool  Altenator / Power Steer / Air Pump Pulley Puller Logo
54 people viewed this question
Top SK Plumbing Experts
Gil Shultz
Dan Apthorp
Jim Goldsmith
Jim Goldsmith
Are you a SK Plumbing Expert? Answer questions, earn points and help others
